MAX14759ETA+T replacement
Other Parts Discussed in Thread: MUX509, TS12A4514, CD4016B
Does TI have anything that competes directly with MAX14759ETA+T.? It does not need to be pin to pin.
Thanks for your help!
  • Sonia,
    You can search for TI devices that are similar to competitor parts with the TI.com cross reference tool.
    In addition to the TS12A4514 device TI has higher voltage product families such as the MUX509 and CD4016B.
    To help narrow down you selection can you provide us some more information on how you are using the Maxim device in your application?  What signal are you switching?  What is the voltage range? Are there any key performance parameters we should consider optimizing?
    Thank you,
    Adam
