May I know the TS3A227E can support 4-port pass through mode without I2C control? If not, Do you have related solution like TS3A227 and support 4-port pass through? Thanks
This device has the ability to detect 4 port AUX through the DET_TRIGGER or with i2c control. However, if you do not wish to use i2c, you would just need to pull them up and not use them. The DET_TRIGGER will automatically tell the switch what kind of port it is interfacing with.
However, I am unfamiliar with pass through, could you provide some more details around this application?
Thank you,
Louie
Yes this device does offer automatic detect for 4 or 3 pole detect without the use of i2c.
We have a family of parts which behave similarly to one another in terms of manual detection. If you do not use the i2c line (SDA, SCL) simply tie them high with a 10k resistor. This can be found in our datasheet on page 17, 21-22.
Please find the links below as other resources explaining out the manual detect works:
Thank you,
Louie
