I want to know what will happen if i connect common output of the 4X SPDT analog switch together to use it as a 4:1 MUX? I want such configuration because i want low Ron resistance with low cost. The multiplexer available with low ON resistance are not fitting in our cost. We require component with cost lest than 0.3USD|1KU AND Ron less that 10ohm. So looking for some good solution.
can i use TS3A44159 part as 4:1 Mux with connecting COM out together ? How it will affect the system.
