Other Parts Discussed in Thread: TS5A12301E, TS5A22362
Using for video signal switching.
When the analog switch is switched from pin 3 to 1, a voltage of 3.3+Video appears at pin 3, and because of this voltage, Vout cannot switch back to pin 3.
We find a surge voltage(because of Integrated inductance) at Vcc when the switching happened. And the datasheet of SN74LVC1G3157 recommends waiting until VCC has ramped to a level in Recommended Operating Conditions before applying any signals, so we suspect that if this surge voltage of Vcc cause the problem.
So will the unstable of Vcc causes the switching failure? If not, then is there any other probability may cause the problem?
Sincerely thanks for your help!
