Other Parts Discussed in Thread: TS5A22362
Hello Sir/Madam,
Hope you are doing well.
This is Akshay Pathak working as a Embedded Hardware Engineer in Teksun Microsys Pvt Ltd.
We evaluated one audio application in which we used "TS5A23157" Analog Switch.
Query :-
- We need information regarding the parameters about On resistance(Ron) and Charge injection, in this part Ron is 18ohm.
- So my query is will this much On resistance affect the audio signal and if yes then how much should be the preferable ?
- As per my understanding Ron 3 to 8 ohm will not affect the audio signal while switching ,so is this correct or not and if not can you guide me through ?
- Also can you tell us what should be the preferable charge injection so that it won't affect the audio signal.
Thanks & Regards
Akshay Pathak
