Other Parts Discussed in Thread: SN75DPHY440SS
Hi Adam ,
You say the TS5MP646 device is a passive switch . So my understanding of your use of passive in this context is that no other inputs determine the (enabled) output .
In a different context ,to my understanding , elements that are passive degrade signal quality, where active (buffer/drivers) elements recondition and enhance signal quality ....Hence my question. :
I would like to extend the 'reach' of a mipi interface . I believe 25-30 cm is the spec for MIPI . Is the TS5MP646 an appropriate choice for this type of application ? If so, what PHY specs does it support :
1.1, 1.2 ...etc.
With a 0.4 mm / 15 mil pitch w/ the recommended pad size of .23 mm dia , what are the escape routes trace thickness expected to be : 3 mils or 4 mils ? should we neckdown on the escape and risk impedance mismatches , hence signal quality or keep the trace consistent from ball. Thank you in advance ..
best,a
