I am testing the process to build Linux for the AM437x Starter Kit following the process described on the website documentation.
I ran the command MACHINE=am437x-evm bitbake arago-core-tisdk-image to begin the process. I did have an issue downloading packages during the process which I resolved by updating the mirrors and downloading a package that continued to have a problem.
Current issue is that I get the following error:
ERROR: icss-emac-lld-rtos-01.00.00.10A-r0.0 do_compile: Function failed: do_compile (log file is located at /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/temp/log.do_compile.23585)
ERROR: Logfile of failure stored in: /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/temp/log.do_compile.23585
When I looked at the referenced log file I see towards the bottom:
# Generating output header into am437x:pru_0:icss_dualemac into /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1/icss_dualemac_PRU0.bin...
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/hexpru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/pruss/PRU0_REV1_to_ARM.cmd /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/icss_dualemac_PRU0.out -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1/icss_dualemac_PRU0.bin
*** Error in `/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/hexpru': free(): invalid next size (fast): 0x09753010 ***
INTERNAL ERROR: /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/hexpru had an internal inconsistency and aborted
This is caused by a defect in the TI Hex Converter.
TI Customer Support may be able to suggest a workaround to avoid this.
Upgrading to the newest version of the compiler may fix this problem.
Contact TI in the E2E support forums at http://e2e.ti.com under
"Development Tools", "TI C/C++ Compiler". See the link titled
"Submitting an issue".
We need to see this ENTIRE error message and a complete, reproducable
test case including ALL of the command-line options.
I have seen a few other cases of this error but the circumstances were different. My coworker is building this on a dedicated Linux box and not having these issues. I am running on a Windows hosted VM, we both have Ubuntu 16.04 + latest updates.
The process to setup and prepare the environment goes across several TI documents so it is possible a step was missed along the way so I hope this specific error points to the best place to look.
I will paste the entire content of log.do_compile.23585 below to be complete. Since this takes a while I will begin the process to build the basic image and see if the result is the same.
Thanks, Pete
content of log.do_compile.23585:
DEBUG: Executing shell function do_compile
make libcores SOC=am437x
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac'
make lib_allendians CORE=a9host BUILD_PROFILE_a9host=release
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac'
make comp_libs ENDIAN=little
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac'
make -C /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac -f build/makefile.mk
make[4]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac'
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps
# Compiling am437x:a9host:release:icss_emac: src/icss_emacDrv.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps/icss_emacDrv.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -Isoc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacDrv.oa9fg src/icss_emacDrv.c
# Compiling am437x:a9host:release:icss_emac: src/icss_emacFwInit.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps/icss_emacFwInit.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -Isoc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacFwInit.oa9fg src/icss_emacFwInit.c
# Compiling am437x:a9host:release:icss_emac: src/icss_emacLearning.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps/icss_emacLearning.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -Isoc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacLearning.oa9fg src/icss_emacLearning.c
# Compiling am437x:a9host:release:icss_emac: src/icss_emacStatistics.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps/icss_emacStatistics.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -Isoc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacStatistics.oa9fg src/icss_emacStatistics.c
# Compiling am437x:a9host:release:icss_emac: src/icss_emacStormControl.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps/icss_emacStormControl.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -Isoc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacStormControl.oa9fg src/icss_emacStormControl.c
# Compiling am437x:a9host:release:icss_emac: src/icss_emacLoc.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps/icss_emacLoc.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -Isoc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacLoc.oa9fg src/icss_emacLoc.c
# Compiling am437x:a9host:release:icss_emac: soc/am437x/icss_emacSoc.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/.deps/icss_emacSoc.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -Isoc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacSoc.oa9fg soc/am437x/icss_emacSoc.c
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/am437x/a9/release
# Archiving am437x:a9host:release:icss_emac into /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/am437x/a9/release/ti.drv.icss_emac.aa9fg ...
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ar cr /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/am437x/a9/release/ti.drv.icss_emac.aa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacDrv.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacFwInit.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacLearning.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacStatistics.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacStormControl.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacLoc.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac/obj/am437x/a9/release/icss_emacSoc.oa9fg
make[4]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac'
make -C /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac -f build/makefile_indp.mk
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/.deps
# Compiling am437x:a9host:release:icss_emac_indp: src/icss_emacDrv.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/.deps/icss_emacDrv.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/opt/tools/edma3/edma3_lld_02_12_00_20/packages -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacDrv.oa9fg src/icss_emacDrv.c
# Compiling am437x:a9host:release:icss_emac_indp: src/icss_emacFwInit.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/.deps/icss_emacFwInit.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/opt/tools/edma3/edma3_lld_02_12_00_20/packages -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacFwInit.oa9fg src/icss_emacFwInit.c
# Compiling am437x:a9host:release:icss_emac_indp: src/icss_emacLearning.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/.deps/icss_emacLearning.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/opt/tools/edma3/edma3_lld_02_12_00_20/packages -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacLearning.oa9fg src/icss_emacLearning.c
# Compiling am437x:a9host:release:icss_emac_indp: src/icss_emacStatistics.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/.deps/icss_emacStatistics.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/opt/tools/edma3/edma3_lld_02_12_00_20/packages -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacStatistics.oa9fg src/icss_emacStatistics.c
# Compiling am437x:a9host:release:icss_emac_indp: src/icss_emacStormControl.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/.deps/icss_emacStormControl.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/opt/tools/edma3/edma3_lld_02_12_00_20/packages -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacStormControl.oa9fg src/icss_emacStormControl.c
# Compiling am437x:a9host:release:icss_emac_indp: src/icss_emacLoc.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/.deps/icss_emacLoc.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/opt/tools/edma3/edma3_lld_02_12_00_20/packages -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacLoc.oa9fg src/icss_emacLoc.c
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/a9/release
# Archiving am437x:a9host:release:icss_emac_indp into /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/a9/release/ti.drv.icss_emac.aa9fg ...
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ar cr /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/a9/release/ti.drv.icss_emac.aa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacDrv.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacFwInit.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacLearning.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacStatistics.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacStormControl.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_indp/obj/a9/release/icss_emacLoc.oa9fg
make -C /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac -f build/makefile_profile.mk
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps
# Compiling am437x:a9host:release:icss_emac_profile: src/icss_emacDrv.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps/icss_emacDrv.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -finstrument-functions -gdwarf-3 -g -D_ENABLE_BM -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -Isoc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacDrv.oa9fg src/icss_emacDrv.c
# Compiling am437x:a9host:release:icss_emac_profile: src/icss_emacFwInit.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps/icss_emacFwInit.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -finstrument-functions -gdwarf-3 -g -D_ENABLE_BM -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -Isoc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacFwInit.oa9fg src/icss_emacFwInit.c
# Compiling am437x:a9host:release:icss_emac_profile: src/icss_emacLearning.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps/icss_emacLearning.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -finstrument-functions -gdwarf-3 -g -D_ENABLE_BM -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -Isoc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacLearning.oa9fg src/icss_emacLearning.c
# Compiling am437x:a9host:release:icss_emac_profile: src/icss_emacStatistics.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps/icss_emacStatistics.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -finstrument-functions -gdwarf-3 -g -D_ENABLE_BM -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -Isoc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacStatistics.oa9fg src/icss_emacStatistics.c
# Compiling am437x:a9host:release:icss_emac_profile: src/icss_emacStormControl.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps/icss_emacStormControl.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -finstrument-functions -gdwarf-3 -g -D_ENABLE_BM -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -Isoc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacStormControl.oa9fg src/icss_emacStormControl.c
# Compiling am437x:a9host:release:icss_emac_profile: src/icss_emacLoc.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps/icss_emacLoc.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -finstrument-functions -gdwarf-3 -g -D_ENABLE_BM -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -Isoc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacLoc.oa9fg src/icss_emacLoc.c
# Compiling am437x:a9host:release:icss_emac_profile: soc/am437x/icss_emacSoc.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/.deps/icss_emacSoc.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -finstrument-functions -gdwarf-3 -g -D_ENABLE_BM -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -Isoc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacSoc.oa9fg soc/am437x/icss_emacSoc.c
# Archiving am437x:a9host:release:icss_emac_profile into /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/am437x/a9/release/ti.drv.icss_emac.profiling.aa9fg ...
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ar cr /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/am437x/a9/release/ti.drv.icss_emac.profiling.aa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacDrv.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacFwInit.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacLearning.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacStatistics.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacStormControl.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacLoc.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile/obj/am437x/a9/release/icss_emacSoc.oa9fg
make -C /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac -f build/makefile_profile_indp.mk
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/.deps
# Compiling am437x:a9host:release:icss_emac_profile_indp: src/icss_emacDrv.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/.deps/icss_emacDrv.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -finstrument-functions -gdwarf-3 -g -D_ENABLE_BM -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/opt/tools/edma3/edma3_lld_02_12_00_20/packages -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacDrv.oa9fg src/icss_emacDrv.c
# Compiling am437x:a9host:release:icss_emac_profile_indp: src/icss_emacFwInit.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/.deps/icss_emacFwInit.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -finstrument-functions -gdwarf-3 -g -D_ENABLE_BM -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/opt/tools/edma3/edma3_lld_02_12_00_20/packages -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacFwInit.oa9fg src/icss_emacFwInit.c
# Compiling am437x:a9host:release:icss_emac_profile_indp: src/icss_emacLearning.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/.deps/icss_emacLearning.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -finstrument-functions -gdwarf-3 -g -D_ENABLE_BM -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/opt/tools/edma3/edma3_lld_02_12_00_20/packages -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacLearning.oa9fg src/icss_emacLearning.c
# Compiling am437x:a9host:release:icss_emac_profile_indp: src/icss_emacStatistics.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/.deps/icss_emacStatistics.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -finstrument-functions -gdwarf-3 -g -D_ENABLE_BM -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/opt/tools/edma3/edma3_lld_02_12_00_20/packages -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacStatistics.oa9fg src/icss_emacStatistics.c
# Compiling am437x:a9host:release:icss_emac_profile_indp: src/icss_emacStormControl.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/.deps/icss_emacStormControl.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -finstrument-functions -gdwarf-3 -g -D_ENABLE_BM -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/opt/tools/edma3/edma3_lld_02_12_00_20/packages -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacStormControl.oa9fg src/icss_emacStormControl.c
# Compiling am437x:a9host:release:icss_emac_profile_indp: src/icss_emacLoc.c
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc -MD -MF /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/.deps/icss_emacLoc.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -mlong-calls -fdata-sections -c -mcpu=cortex-a9 -g -mtune=cortex-a9 -march=armv7-a -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -D__ARMv7 -Werror -O2 -s -DNDEBUG -finstrument-functions -gdwarf-3 -g -D_ENABLE_BM -DSOC_AM437x -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/arm-none-eabi/include/newlib-nano -I. -Isrc -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build -I/opt/tools/edma3/edma3_lld_02_12_00_20/packages -I/apps/apps_nonbam/inc -I/ -I/common -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacLoc.oa9fg src/icss_emacLoc.c
# Archiving am437x:a9host:release:icss_emac_profile_indp into /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/a9/release/ti.drv.icss_emac.profiling.aa9fg ...
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ar cr /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/lib/a9/release/ti.drv.icss_emac.profiling.aa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacDrv.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacFwInit.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacLearning.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacStatistics.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacStormControl.oa9fg /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/ti/drv/icss_emac/icss_emac_profile_indp/obj/a9/release/icss_emacLoc.oa9fg
make[3]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac'
make[2]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac'
make[1]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac'
make firmcores SOC=am437x
make[1]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac'
make firm_allhostcores CORE=pru_0
make[2]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac'
make firm_allversion HOSTCORE=a9host
make[3]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac'
make comp_firm PRUVERSION=REV1
make[4]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac'
make -C /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac -f ../../build/makefile_icss_dualemac.mk
make[5]: Entering directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac'
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/.deps
# Compiling am437x:pru_0:icss_dualemac: src/micro_scheduler.asm
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/clpru -DMAKEFILE_BUILD -v3 -g --endian=little -DICSS_REV1 --diag_wrap=off --diag_warning=225 --display_error_number --hardware_mac=on --preproc_with_compile -eo.opru -DPRU0 -Dpru0 -DICSS_DUAL_EMAC_BUILD -DPRU -DTTS -DHALF_DUPLEX_ENABLED -DSOC_AM437x -I/ccsv6/ccs_base/pru/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/include -Isrc/ -fr=/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 -fs=/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 --preproc_dependency="micro_scheduler.d" src/micro_scheduler.asm
# Compiling am437x:pru_0:icss_dualemac: src/emac_MII_Rcv.asm
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/clpru -DMAKEFILE_BUILD -v3 -g --endian=little -DICSS_REV1 --diag_wrap=off --diag_warning=225 --display_error_number --hardware_mac=on --preproc_with_compile -eo.opru -DPRU0 -Dpru0 -DICSS_DUAL_EMAC_BUILD -DPRU -DTTS -DHALF_DUPLEX_ENABLED -DSOC_AM437x -I/ccsv6/ccs_base/pru/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/include -Isrc/ -fr=/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 -fs=/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 --preproc_dependency="emac_MII_Rcv.d" src/emac_MII_Rcv.asm
# Compiling am437x:pru_0:icss_dualemac: src/emac_MII_Xmt.asm
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/clpru -DMAKEFILE_BUILD -v3 -g --endian=little -DICSS_REV1 --diag_wrap=off --diag_warning=225 --display_error_number --hardware_mac=on --preproc_with_compile -eo.opru -DPRU0 -Dpru0 -DICSS_DUAL_EMAC_BUILD -DPRU -DTTS -DHALF_DUPLEX_ENABLED -DSOC_AM437x -I/ccsv6/ccs_base/pru/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/include -Isrc/ -fr=/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 -fs=/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 --preproc_dependency="emac_MII_Xmt.d" src/emac_MII_Xmt.asm
# Compiling am437x:pru_0:icss_dualemac: src/emac_statistics.asm
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/clpru -DMAKEFILE_BUILD -v3 -g --endian=little -DICSS_REV1 --diag_wrap=off --diag_warning=225 --display_error_number --hardware_mac=on --preproc_with_compile -eo.opru -DPRU0 -Dpru0 -DICSS_DUAL_EMAC_BUILD -DPRU -DTTS -DHALF_DUPLEX_ENABLED -DSOC_AM437x -I/ccsv6/ccs_base/pru/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/include -Isrc/ -fr=/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 -fs=/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 --preproc_dependency="emac_statistics.d" src/emac_statistics.asm
# Compiling am437x:pru_0:icss_dualemac: src/emac_tts.asm
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/clpru -DMAKEFILE_BUILD -v3 -g --endian=little -DICSS_REV1 --diag_wrap=off --diag_warning=225 --display_error_number --hardware_mac=on --preproc_with_compile -eo.opru -DPRU0 -Dpru0 -DICSS_DUAL_EMAC_BUILD -DPRU -DTTS -DHALF_DUPLEX_ENABLED -DSOC_AM437x -I/ccsv6/ccs_base/pru/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/include -Isrc/ -fr=/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 -fs=/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0 --preproc_dependency="emac_tts.d" src/emac_tts.asm
# Linking into am437x:pru_0:icss_dualemac into /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/icss_dualemac_PRU0/icss_dualemac_PRU0.out...
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/clpru -v3 -g --endian=little --define=am437x --diag_wrap=off --diag_warning=225 --display_error_number --hardware_mac=on -z --stack_size=0 --heap_size=0 --reread_libs --warn_sections -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/include -I/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/lib --define=PRU0 --define=pru0 --entry_point=micro_scheduler /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/micro_scheduler.opru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/emac_MII_Rcv.opru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/emac_MII_Xmt.opru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/emac_statistics.opru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/emac_tts.opru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/src/pru.cmd -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/icss_dualemac_PRU0.out -m /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/icss_dualemac_PRU0.map --xml_link_info="/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/icss_dualemac_PRU0_linkInfo.xml" -l/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/lib/libc.a
<Linking>
/bin/mkdir -p /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1
# Generating output header into am437x:pru_0:icss_dualemac into /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1/icss_dualemac_PRU0.bin...
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/hexpru /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/pruss/PRU0_REV1_to_ARM.cmd /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/git/ti/drv/icss_emac/icss_dualemac/obj/am437x/a9host/REV1/pru_0/icss_dualemac_PRU0.out -o /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1/icss_dualemac_PRU0.bin
*** Error in `/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/hexpru': free(): invalid next size (fast): 0x09753010 ***
INTERNAL ERROR: /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-pru/bin/hexpru had an internal inconsistency and aborted
This is caused by a defect in the TI Hex Converter.
TI Customer Support may be able to suggest a workaround to avoid this.
Upgrading to the newest version of the compiler may fix this problem.
Contact TI in the E2E support forums at http://e2e.ti.com under
"Development Tools", "TI C/C++ Compiler". See the link titled
"Submitting an issue".
We need to see this ENTIRE error message and a complete, reproducable
test case including ALL of the command-line options.
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/makerules/rules_pru.mk:125: recipe for target '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1/icss_dualemac_PRU0.h' failed
make[5]: *** [/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac/bin/am437x/a9host/REV1/icss_dualemac_PRU0.h] Error 2
make[5]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac/firmware/icss_dualemac'
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/comp_top.mk:317: recipe for target 'icss_dualemac' failed
make[4]: *** [icss_dualemac] Error 2
make[4]: Leaving directory '/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/build/ti/drv/icss_emac'
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/comp_top.mk:181: recipe for target 'REV1_firm' failed
make[3]: *** [REV1_firm] Error 2
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/comp_top.mk:178: recipe for target 'a9host_firm' failed
make[2]: *** [a9host_firm] Error 2
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/comp_top.mk:175: recipe for target 'pru_0_firm' failed
make[1]: *** [pru_0_firm] Error 2
/home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am437x-evm/usr/share/ti/ti-pdk-tree/packages/ti/build/comp_top.mk:172: recipe for target 'am437x_firm' failed
make: *** [am437x_firm] Error 2
WARNING: /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/temp/run.do_compile.23585:1 exit 2 from 'make release LIMIT_SOCS="am437x" LIMIT_BOARDS="evmAM437x idkAM437x skAM437x" LIMIT_CORES="a15_0 ipu1_0 ipu1_1 ipu2_0 ipu2_1 c66x c66xdsp_1 c66xdsp_2 arm9_0 c674x a9host a8host pru_0 pru_1"'
ERROR: Function failed: do_compile (log file is located at /home/ubuntu/ti-processor-sdk-linux-am437x-evm-04.01.00.06/tisdk/build/arago-tmp-external-linaro-toolchain/work/am437x_evm-linux-gnueabi/icss-emac-lld-rtos/01.00.00.10A-r0.0/temp/log.do_compile.23585)
