Hi Champs,
Could you please tell us still C2000 no support for "Packed attribute" at latest c2000 compiler?
Kz777
Hi Champs,
Kz777
Unfortunately, the C2000 compiler continues to not support the packed attribute for structs.
Thanks and regards,
-George
If you are trying to match the data layout imposed by some other part of your system ... Consider writing a set of routines that transfer structures between the two systems. Only within these routines are both data layouts known and explicitly dealt with. Elsewhere, the data layout used is the one imposed by the compiler (or other constraints) for that part of the system. If the other part of your system deals with 8-bit bytes, then you probably have to use __byte intrinsic. Please read more about it in the article Byte Accesses with the C28x CPU.
Thanks and regards,
-George
