Good morning
I'm doing exercises with "Getting Started With the Tiva C Series TM4C123G LaunchPad".
Now "Lab 14b: Sensor Library Usage".
Its part: "GUI Composer". Page 14-31.
There is described access to the global variable using the "GUI Composer v1" functionality.
It was an easy way - without changing the code.
Now there is no Composer V1 and there is Composer V2.
The solution described in Lab14b does not work anymore.
How to connect the global variable in the code for LunchPad TM4C123G with the widget on the PC screen in the simplest way?
This code reads sensors from Sensors BosterPack.
LunchPad TM4C123G probably does not have XDS.
How to make such a connection without writing a lot of new code?
Adam
