Hello. I am trying to run HSR project on IDK_AM437x, and my connect target message is below :
IcePick_D_0: Error connecting to the target: (Error -151 @ 0x0) One of the FTDI driver functions used during the connect returned bad status or an error. The cause may be one or more of: no XDS100 is plugged in, invalid XDS100 serial number, blank XDS100 EEPROM, missing FTDI drivers, faulty USB cable. Use the xds100serial command-line utility in the 'common/uscif' folder to verify the XDS100 can be located. (Emulation package 6.0.407.3)
CortexA9: Output: **** AM437x IDK EVM Initialization is in progress ..........
CortexA9: Output: **** Device Type: GP
CortexA9: GEL Output: System input clock is 24MHz
CortexA9: GEL Output: **** AM43xx OPP100 with CLKIN=24MHz is in progress .........
CortexA9: GEL Output: **** Going to Bypass...
CortexA9: GEL Output: **** Bypassed, changing values...
CortexA9: Output: **** Locking PLL
CortexA9: GEL Output: **** MPU PLL locked
CortexA9: GEL Output: **** Core Bypassed
CortexA9: GEL Output: **** Now locking Core...
CortexA9: GEL Output: **** Core locked
CortexA9: GEL Output: **** Calculated PER SD Divisor=4
CortexA9: GEL Output: **** PER DPLL Bypassed
CortexA9: GEL Output: **** PER DPLL Locked
CortexA9: GEL Output: **** Calculated EXTDEV SD Divisor=4
CortexA9: GEL Output: **** EXTDEV DPLL Bypassed
CortexA9: GEL Output: **** EXTDEV DPLL Locked
CortexA9: GEL Output: **** DISP PLL Config is in progress ..........
CortexA9: GEL Output: **** DISP PLL Locked
CortexA9: GEL Output: **** DDR DPLL Bypassed
CortexA9: GEL Output: **** DDR DPLL Locked
CortexA9: GEL Output: **** Setting DDR3 = 400MHz
CortexA9: GEL Output: **** AM43xx OPP100 configuration is done .........
CortexA9: GEL Output: Starting DDR3 configuration...
CortexA9: Output: EMIF PRCM is in progress .......
CortexA9: Output: EMIF PRCM Done
CortexA9: GEL Output: EMIF CLK enabled...
CortexA9: GEL Output: Waiting for VTP Ready .......
CortexA9: GEL Output: VTP is Ready!
CortexA9: GEL Output: VTP controller enabled
CortexA9: GEL Output: Checking if DLL is ready...
CortexA9: GEL Output: DLL is ready
CortexA9: GEL Output: Configuring DDR IOs and Control Module registers...
CortexA9: GEL Output: Configuration of Control Module registers complete
CortexA9: GEL Output: Setting up DDR3 H/W leveling configuration...
CortexA9: GEL Output: Starting EMIF controller configuration...
DDR3 Hardware leveling incomplete with errors !!!
DDR3 CONFIGURATION FAILED!!! Could not read/write first DDR location.
CortexA9: GEL Output: Expected 0xA5A5A5A5, Read: 0x00000000
CortexA9: GEL Output: Turning on EDMA...
CortexA9: GEL Output: EDMA is turned on...
CortexA9: Output: **** AM437x IDK EVM Initialization is Done ******************
JTAG is XDS100v2, CCS version is 6.2.0.
Please give me any tips to solve the error. Thanks.
