CCS: Changing the build configuration in TIREX
hi ,
I was trying to import and build one of the examples of the C2000ware TIREX
How can i change the build configuration of a project to build for all configurations ?
Basically use the "build all" option like we have in CCS local installation
Regards.
  • Meghana,
    There is no build in Resource Explorer.  Resource Explorer allows you browse through software packages and then download them or import examples into CCS Cloud.
    Based on your comment about wanting it to be like a local CCS installation I am guessing that you are importing an example from Resource Explorer into CCS Cloud.  Is that what you are trying to do?
    While the backend of the build system in CCS Cloud is identical to the one in CCS Desktop the User Interface is much more limited.  It does not provide a way to build all build configurations.
    John
  • hi John ,
    Yes that is what i was doing .
    That's what i wanted to check . So its basically building the default configuration . If we want to tamper with all configurations we can use the downloaded version...
    Anyways i guess this would be something good to enable even in the CCS cloud.
    Regards.
