Other Parts Discussed in Thread: CC2650, CC2652R
Tool/software: TI-RTOS
Hi Ti team,
What is the TI-RTOS version we can use for TIDA-00756 ?
Walter
Hi Ti team,
Walter
Hi Walter,
The firmware was developed using TI-RTOS 2.14.03.28. If you want to make modifications to the existing firmware refer to the build instructions given in the read me file in the TIDA-00756 firmware installer.
Walter,
Looks like those SDKs you mentioned do not support CC2650. From this link, you can use SDK 2.21.01.08. However, you would have to port the TIDA-00756 application code to that newer SDK.
Hi Walter,
Walter Macamos said:we want to port to latest zigbee simplelink_cc26x2_sdk_2_30_00_34. Is it possible?
That SDK is for the newer CC2652R multi-standard device. I doesn't support the CC2650.
Walter Macamos said:For hardware, what will be the needed change to use this reference design for smoke detector (stand-alone).
1. trans-impedance amplifier design?
2. sensor?
It would require a full re-design. TIDA-00756 measures CO using an electro-chemical CO sensor. The mechanism for measuring smoke is entirely different using either photoelectric or ionization method. Please take a look at our Smoke and Heat Detector end equipment page. You can find several resources there.
Note, back to your original question, if you end goal is smoke detection using ZigBee for communication, then TIDA-00756 will not help you much & a new design would be needed. At that point I would suggest picking the latest ZigBee Simplelink Radio (i.e. CC2652R) using the latest SDK.
