  • TI Thinks Resolved
WEBENCH® Tools/LM25116: lm25116
Prodigy 20 points
Part Number: LM25116
i have designed the lm25116 pcb board for 12v @ 25 amps and used the quick start calaulator values
i got the output voltage as 12v , but when i put some load , the output voltage reduces to 2 or 3v
even i can vary the input voltage the output voltage stays constant ,this is true , but when i connect the load the output voltage goes to 2-3v
please help me out ,
pleasse let me know th error
  • Hi alagar,
      Can you share your quick start file so that I can check your spec?  Your given information is limited.  We can't guess the root cause.
     And try to reduce your output cap to see any improvement.
    Gavin
  • In reply to alagar krishna:
    Hi ,
      I reviewed your schematic, two suggestions:
    1.  Try to reduce your output cap to see any improvement.
    2. Try to change Rramp=470k to see any improvement.
    Gavin
