  • Resolved
LAUNCHXL-CC1350-4: sub-1G confuctive test report of LP CC1350-4
Expert 4410 points
Part Number: LAUNCHXL-CC1350-4
HI,
one of my customer put cc1350-4 LP as a bench mark reference for the 433MHz band.
could you provide a test report of the band? tx power and sensitivity is okay.
BR. Albin
  • Guru 240310 points
    The performance in the 433 MHz band could be found in the datasheet. Since the launchpad has a switch that select either 433 MHz or 2.4 GHz the loss in this has to be taken into account when comparing the data. See also www.ti.com/.../swra543a.pdf
     OOO until September 30th. If your thread is not answered by someone after 2-3 days after your last post, please repost with a link referring to your original post.
  • In reply to TER:
    www.ti.com/.../swra543a.pdf is exactly what we need. thanks.
    BR. Albin
  • In reply to TER:
    Hi TER,
    It's come from one project.
    http://www.ti.com/lit/an/swra543a/swra543a.pdf
    The sensitivity test on this board is -110dBm at 433MHz.
    We test the sensitivity of this board by default SmartRF Studio setting:
    The test result it worse than us. Is there any test condition different?
    431:-109(packet:33%,BER:0.83%)
    434:-104.5(packet:37.7%,BER:0.98%)
    438:-104(packet:24%,BER:0.57%)
    In reply to Daniel Fang:
    I find it strange that you get the expected value for the lowest frequency but not at the two others. Have you checked if you have a high background noise floor on these frequencies that could affect the measurements?
