Beginner on so many way but still need your expertise.
Have a 433MHz transmitter sending out a heartbeat every 1 Second when its powered on, there isn't any other function.
I can pick up the signal with a 2 transistor ASK receiver (too noisy, super regenerative receiver, bad PCB) and I can see it on my SDR.
Need help to pick up and decode this signal with Arduino-SpaceTeddy/CC1101 {example provided work as it can talk to each other (2x CC1101)}
My Register setting is from SmartRF Studio7
Tried with no sync, no preamble, 15/16 sync, 16/16 sync, address check on or off
Tried so many different setting and examples but either picking up nothing or noise on GO0
0x29, //IOCFG2 GDO2 OUTPUT PIN CONFIGURATION 0x2E, //IOCFG1 GDO1 OUTPUT PIN CONFIGURATION 0x06, //IOCFG0 GDO0 OUTPUT PIN CONFIGURATION 0x47, //FIFOTHR RX FIFO AND TX FIFO THRESHOLDS 0xD3, //SYNC1 SYNC WORD, HIGH BYTE 0x91, //SYNC0 SYNC WORD, LOW BYTE 0xFF, //PKTLEN PACKET LENGTH 0x04, //PKTCTRL1 PACKET AUTOMATION CONTROL 0x05, //PKTCTRL0 PACKET AUTOMATION CONTROL 0x00, //ADDR DEVICE ADDRESS 0x00, //CHANNR CHANNEL NUMBER 0x06, //FSCTRL1 FREQUENCY SYNTHESIZER CONTROL 0x00, //FSCTRL0 FREQUENCY SYNTHESIZER CONTROL 0x10, //FREQ2 FREQUENCY CONTROL WORD, HIGH BYTE 0xA7, //FREQ1 FREQUENCY CONTROL WORD, MIDDLE BYTE 0x62, //FREQ0 FREQUENCY CONTROL WORD, LOW BYTE 0xF7, //MDMCFG4 MODEM CONFIGURATION 0x22, //MDMCFG3 MODEM CONFIGURATION 0x39, //MDMCFG2 MODEM CONFIGURATION 0x00, //MDMCFG1 MODEM CONFIGURATION 0xF8, //MDMCFG0 MODEM CONFIGURATION 0x15, //DEVIATN MODEM DEVIATION SETTING 0x07, //MCSM2 MAIN RADIO CONTROL STATE MACHINE CONFIGURATION 0x30, //MCSM1 MAIN RADIO CONTROL STATE MACHINE CONFIGURATION 0x18, //MCSM0 MAIN RADIO CONTROL STATE MACHINE CONFIGURATION 0x16, //FOCCFG FREQUENCY OFFSET COMPENSATION CONFIGURATION 0x6C, //BSCFG BIT SYNCHRONIZATION CONFIGURATION 0x03, //AGCCTRL2 AGC CONTROL 0x40, //AGCCTRL1 AGC CONTROL 0x91, //AGCCTRL0 AGC CONTROL 0x87, //WOREVT1 HIGH BYTE EVENT0 TIMEOUT 0x6B, //WOREVT0 LOW BYTE EVENT0 TIMEOUT 0xFB, //WORCTRL WAKE ON RADIO CONTROL 0x56, //FREND1 FRONT END RX CONFIGURATION 0x11, //FREND0 FRONT END TX CONFIGURATION 0xE9, //FSCAL3 FREQUENCY SYNTHESIZER CALIBRATION 0x2A, //FSCAL2 FREQUENCY SYNTHESIZER CALIBRATION 0x00, //FSCAL1 FREQUENCY SYNTHESIZER CALIBRATION 0x1F, //FSCAL0 FREQUENCY SYNTHESIZER CALIBRATION 0x41, //RCCTRL1 RC OSCILLATOR CONFIGURATION 0x00, //RCCTRL0 RC OSCILLATOR CONFIGURATION 0x59, //FSTEST FREQUENCY SYNTHESIZER CALIBRATION CONTROL 0x7F, //PTEST PRODUCTION TEST 0x3F, //AGCTEST AGC TEST 0x81, //TEST2 VARIOUS TEST SETTINGS 0x35, //TEST1 VARIOUS TEST SETTINGS 0x09, //TEST0 VARIOUS TEST SETTINGS
