Other Parts Discussed in Thread: CC1352P,
Hi All,
I working on sensor_sm_CC1352R1_ LAUNCHXL_tirtos_ccs and Collectr_sm_CC1352R1_ LAUNCHXL_tirtos_ccs examples. Until restart sensor and collector, codes are working fine.
when i restarted collector, sensor enter into rejoined and orphan modes continuously.
I attached logs, please find attachments.
9/13/2019 17:49:44.164 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:49:45.570 [RX] - SM: Will Retry Sending previous Packet SM: SMMsgs_cmdIds_processRequest command sent: Retry Attempt 9/13/2019 17:49:53.236 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:50:00.673 [RX] - SM: Will Retry Sending previous Packet SM: SMMsgs_cmdIds_processRequest command sent: Retry Attempt 9/13/2019 17:50:02.326 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:50:11.454 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:50:15.777 [RX] - SM: Will Retry Sending previous Packet SM: SMMsgs_cmdIds_processRequest command sent: Retry Attempt 9/13/2019 17:50:20.557 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:50:29.649 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:50:30.881 [RX] - SM: Will Retry Sending previous Packet SM: SMMsgs_cmdIds_processRequest command sent: Retry Attempt 9/13/2019 17:50:38.740 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:50:45.985 [RX] - SM: Will Retry Sending previous Packet SM: SMMsgs_cmdIds_processRequest command sent: Retry Attempt 9/13/2019 17:50:47.835 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:50:56.925 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:51:01.088 [RX] - SM: Will Retry Sending previous Packet SM: Failed to send a packet: exceeded Max Attempts! SM: Changing State to SM_states_finish_fail SM: unknown error code SM: Changing State to SM_states_entry Commissioning Postponed: 0x1 9/13/2019 17:51:06.020 [RX] - Orphaned Sensor Re-Joined: 0x1 Key Recovery is done 9/13/2019 17:51:15.130 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:51:24.224 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:51:33.346 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:51:42.461 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:51:51.550 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:52:00.658 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:52:09.763 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:52:18.850 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:52:27.954 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:52:37.050 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:52:46.153 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:52:55.272 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:53:04.382 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:54:00.934 [RX] - !Responding: 0x1 9/13/2019 17:54:19.805 [RX] - !Responding: 0x1 9/13/2019 17:54:38.676 [RX] - !Responding: 0x1 9/13/2019 17:54:57.547 [RX] - !Responding: 0x1 9/13/2019 17:55:16.418 [RX] - !Responding: 0x1 9/13/2019 17:55:35.289 [RX] - !Responding: 0x1 9/13/2019 17:55:54.160 [RX] - !Responding: 0x1 9/13/2019 17:56:13.031 [RX] - !Responding: 0x1 9/13/2019 17:56:31.902 [RX] - !Responding: 0x1 9/13/2019 17:56:50.773 [RX] - !Responding: 0x1 9/13/2019 17:57:09.644 [RX] - !Responding: 0x1 9/13/2019 17:57:28.515 [RX] - !Responding: 0x1 9/13/2019 17:57:47.386 [RX] - !Responding: 0x1 9/13/2019 17:58:06.257 [RX] - !Responding: 0x1 9/13/2019 17:58:25.128 [RX] - !Responding: 0x1 9/13/2019 17:58:43.999 [RX] - !Responding: 0x1 9/13/2019 17:58:58.640 [RX] - TI Collector Restarted Key Recovery Mode Channel: 0 Commissioning Started: 0x1 SM: Changing State to SM_states_start SM: SMMsgs_cmdIds_processRequest command sent 9/13/2019 17:58:59.140 [RX] - Orph� 9/13/2019 17:58:59.262 [RX] - TI Collector Restarted Key Recovery Mode Channel: 0 Commissioning Started: 0x1 SM: Changing State to SM_states_start SM: SMMsgs_cmdIds_processRequest command sent 9/13/2019 17:59:12.873 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:59:14.366 [RX] - SM: Will Retry Sending previous Packet SM: SMMsgs_cmdIds_processRequest command sent: Retry Attempt 9/13/2019 17:59:21.970 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:59:29.470 [RX] - SM: Will Retry Sending previous Packet SM: SMMsgs_cmdIds_processRequest command sent: Retry Attempt 9/13/2019 17:59:31.083 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:59:40.204 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:59:44.574 [RX] - SM: Will Retry Sending previous Packet SM: SMMsgs_cmdIds_processRequest command sent: Retry Attempt 9/13/2019 17:59:49.292 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 17:59:57.215 [RX] - SM: SMMsgs_cmdIds_processResponse command received SM: Changing State to SM_states_auth_method SM: SMMsgs_cmdIds_processMethodConfirm command sent 9/13/2019 18:00:03.233 [RX] - SM: SMMsgs_cmdIds_processPasskeyConfirm command received SM: Changing State to SM_states_passkey SM: SMMsgs_cmdIds_processPasskeyConfirm command sent 9/13/2019 18:00:03.960 [RX] - SM: SMMsgs_cmdIds_processPublicKey command received SM: Changing State to SM_states_key_exchange 9/13/2019 18:00:04.190 [RX] - SM: SMMsgs_cmdIds_processPublicKey command sent 9/13/2019 18:00:04.558 [RX] - SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 0 received SM: Changing State to SM_states_authentication SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 0 sent 9/13/2019 18:00:04.751 [RX] - SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 1 received SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 1 sent 9/13/2019 18:00:05.047 [RX] - SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 2 received SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 2 sent 9/13/2019 18:00:05.341 [RX] - SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 3 received SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 3 sent 9/13/2019 18:00:05.641 [RX] - SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 4 received SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 4 sent 9/13/2019 18:00:05.946 [RX] - SM: SMMsgs_cmdIds_processInfo128SecurityVal command received SM: Changing State to SM_states_key_gen SM: Beginning Key Generation SM: SMMsgs_cmdIds_processInfo128SecurityVal command sent 9/13/2019 18:00:06.229 [RX] - SM: SMMsgs_cmdIds_processSuccess command received SM: Changing State to SM_states_finish_success SM: Changing State to SM_states_entry SM: SMMsgs_cmdIds_processSuccess command sent Commissioned: 0x1 9/13/2019 18:00:06.494 [RX] - Key Recovery is done 9/13/2019 18:00:06.829 [RX] - ConfigRsp: 0x1 9/13/2019 18:00:21.032 [RX] - !Responding: 0x1 9/13/2019 18:00:30.828 [RX] - ConfigRsp: 0x1 9/13/2019 18:01:09.757 [RX] - Sensor 0x1 9/13/2019 18:02:39.751 [RX] - Sensor 0x1 9/13/2019 18:04:09.737 [RX] - Sensor 0x1 9/13/2019 18:05:27.675 [RX] - TI Collector Restarted Key Recovery Mode Channel: 0 Commissioning Started: 0x1 SM: Changing State to SM_states_start SM: SMMsgs_cmdIds_processRequest command sent 9/13/2019 18:05:28.507 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:05:37.614 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:05:42.800 [RX] - SM: Will Retry Sending previous Packet SM: SMMsgs_cmdIds_processRequest command sent: Retry Attempt 9/13/2019 18:05:46.692 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:05:55.808 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:05:57.904 [RX] - SM: Will Retry Sending previous Packet SM: SMMsgs_cmdIds_processRequest command sent: Retry Attempt 9/13/2019 18:06:04.915 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:06:13.008 [RX] - SM: Will Retry Sending previous Packet SM: SMMsgs_cmdIds_processRequest command sent: Retry Attempt 9/13/2019 18:06:14.019 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:06:23.123 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:06:28.112 [RX] - SM: Will Retry Sending previous Packet SM: SMMsgs_cmdIds_processRequest command sent: Retry Attempt 9/13/2019 18:06:32.223 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:06:41.324 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:06:43.216 [RX] - SM: Will Retry Sending previous Packet SM: SMMsgs_cmdIds_processRequest command sent: Retry Attempt 9/13/2019 18:06:50.432 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:06:58.319 [RX] - SM: Will Retry Sending previous Packet SM: Failed to send a packet: exceeded Max Attempts! SM: Changing State to SM_states_finish_fail SM: unknown error code SM: Changing State to SM_states_entry Commissioning Postponed: 0x1 9/13/2019 18:06:59.539 [RX] - Orphaned Sensor Re-Joined: 0x1 Key Recovery is done 9/13/2019 18:07:08.639 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:07:17.724 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:07:26.862 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:07:35.977 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:07:45.078 [RX] - Orphaned Sensor Re-Joined: 0x1 9/13/2019 18:08:55.264 [RX] - !Responding: 0x1 9/13/2019 18:09:14.135 [RX] - !Responding: 0x1 9/13/2019 18:09:33.006 [RX] - !Responding: 0x1 9/13/2019 18:09:51.876 [RX] - !Responding: 0x1 9/13/2019 18:09:58.473 [RX] - �TI Collector Restarted Key Recovery Mode Channel: 0 Commissioning Started: 0x1 SM: Changing State to SM_states_start SM: SMMsgs_cmdIds_processRequest command sent 9/13/2019 18:10:00.326 [RX] - SM: SMMsgs_cmdIds_processResponse command received SM: Changing State to SM_states_auth_method SM: SMMsgs_cmdIds_processMethodConfirm command sent 9/13/2019 18:10:06.328 [RX] - SM: SMMsgs_cmdIds_processPasskeyConfirm command received SM: Changing State to SM_states_passkey SM: SMMsgs_cmdIds_processPasskeyConfirm command sent 9/13/2019 18:10:06.756 [RX] - SM: SMMsgs_cmdIds_processPublicKey command received SM: Changing State to SM_states_key_exchange 9/13/2019 18:10:06.985 [RX] - SM: SMMsgs_cmdIds_processPublicKey command sent 9/13/2019 18:10:07.370 [RX] - SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 0 received SM: Changing State to SM_states_authentication SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 0 sent 9/13/2019 18:10:07.544 [RX] - SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 1 received SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 1 sent 9/13/2019 18:10:07.840 [RX] - SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 2 received SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 2 sent 9/13/2019 18:10:08.143 [RX] - SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 3 received SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 3 sent 9/13/2019 18:10:08.443 [RX] - SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 4 received SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 4 sent 9/13/2019 18:10:08.742 [RX] - SM: SMMsgs_cmdIds_processInfo128SecurityVal command received SM: Changing State to SM_states_key_gen SM: Beginning Key Generation SM: SMMsgs_cmdIds_processInfo128SecurityVal command sent 9/13/2019 18:10:09.036 [RX] - SM: SMMsgs_cmdIds_processSuccess command received SM: Changing State to SM_states_finish_success SM: Changing State to SM_states_entry SM: SMMsgs_cmdIds_processSuccess command sent Commissioned: 0x1 9/13/2019 18:10:09.297 [RX] - Key Recovery is done 9/13/2019 18:10:09.633 [RX] - ConfigRsp: 0x1 Sensor 0x1 9/13/2019 18:11:39.707 [RX] - Sensor 0x1 9/13/2019 18:13:09.700 [RX] - Sensor 0x1 9/13/2019 18:14:39.695 [RX] - Sensor 0x1
13-09-2019 17:59:31.128 [RX] - State Changed: 4<CR><LF> 13-09-2019 17:59:39.293 [RX] - State Changed: 5<CR><LF> 13-09-2019 17:59:40.250 [RX] - State Changed: 4<CR><LF> 13-09-2019 17:59:48.383 [RX] - State Changed: 5<CR><LF> 13-09-2019 17:59:49.340 [RX] - State Changed: 4<CR><LF> 13-09-2019 17:59:56.309 [RX] - <NUL> 13-09-2019 17:59:57.154 [RX] - �<NUL>TI Sensor<CR><LF> KeyInfo recovered<CR><LF> State Changed: 2<CR><LF> Restarted: 0x1<CR><LF> Channel: 1<CR><LF> State Changed: 4<CR><LF> SM: Timer stopped<LF><CR> <LF> Commissioning Started: 0x1<CR><LF> SM: Changing State to SM_states_auth_method<CR><LF> SM: SMMsgs_cmdIds_processResponse command sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:00:03.273 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processMethodConfirm command received<CR><LF> SM: Changing State to SM_states_passkey<CR><LF> SM: SMMsgs_cmdIds_processPasskeyConfirm command sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:00:03.847 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processPasskeyConfirm command received<CR><LF> SM: Changing State to SM_states_key_exchange<CR><LF> 13-09-2019 18:00:03.964 [RX] - SM: SMMsgs_cmdIds_processPublicKey command sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:00:04.466 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processPublicKey command received<CR><LF> 13-09-2019 18:00:04.645 [RX] - SM: Changing State to SM_states_authentication<CR><LF> SM: Derived shared secret:<LF><CR> <LF> 0xbd 0x40 0x14 0x7a 0x6d 0x6a 0x61 0x7e<CR><LF> 0x40 0x14 0x7a 0x6d 0x6a 0x61 0x7e 0x18<CR><LF> 0x14 0x7a 0x6d 0x6a 0x61 0x7e 0x18 0x5f<CR><LF> 0x7a 0x6d 0x6a 0x61 0x7e 0x18 0x5f 0xd1<CR><LF> 0x6d 0x6a 0x61 0x7e 0x18 0x5f 0xd1 0xef<CR><LF> 0x6a 0x61 0x7e 0x18 0x5f 0xd1 0xef 0xd0<CR><LF> 0x61 0x7e 0x18 0x5f 0xd1 0xef 0xd0 0xc9<CR><LF> 0x7e 0x18 0x5f 0xd1 0xef 0xd0 0xc9 0x35<CR><LF> <LF> <LF> SM: Authentication: Iteration Number = 0<CR><LF> SM: Authentication: Iteration Pass Key = 1<CR><LF> <LF> SM: Authentication: Locally generated Nonce :<CR><LF> 0xbc 0x50 0x1c 0xe4 0x6b 0xd3 0xa6 0xb6<CR><LF> <LF> SM: Authentication: Locally generated Code :<CR><LF> 0x4d 0xfa 0xff 0x9c 0xc4 0xdf 0xa7 0x72<CR><LF> <LF> SM: Authentication: Sending Code and Nonce<CR><LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 0 sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:00:04.757 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 0 received<CR><LF> <LF> SM: Authentication: Received Code :<CR><LF> 0x21 0xb4 0x61 0xca 0x79 0xdf 0x47 0x9f<CR><LF> <LF> SM: Authentication: Received Nonce :<CR><LF> 0xb1 0xed 0xb3 0xc6 0xca 0x87 0x1f 0x59<CR><LF> <LF> SM: Authentication: Locally computed Foreign Code :<CR><LF> 0x21 0xb4 0x61 0xca 0x79 0xdf 0x47 0x9f<CR><LF> <LF> <LF> SM: Authentication: Iteration Number = 1<CR><LF> SM: Authentication: Iteration Pass Key = 2<CR><LF> <LF> SM: Authentication: Locally generated Nonce :<CR><LF> 0x75 0xcc 0xed 0xf8 0x24 0xda 0xf5 0xdd<CR><LF> <LF> SM: Authentication: Locally generated Code :<CR><LF> 0x5c 0x22 0xb7 0xfa 0xc8 0x2d 0xb4 0xf2<CR><LF> <LF> SM: Authentication: Sending Code and Nonce<CR><LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 1 sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:00:05.055 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 1 received<CR><LF> <LF> SM: Authentication: Received Code :<CR><LF> 0x60 0xea 0x54 0x70 0x69 0xb9 0x39 0x6<CR><LF> <LF> SM: Authentication: Received Nonce :<CR><LF> 0xa 0x2d 0xc0 0x96 0xcb 0xbf 0x2d 0x18<CR><LF> <LF> SM: Authentication: Locally computed Foreign Code :<CR><LF> 0x60 0xea 0x54 0x70 0x69 0xb9 0x39 0x6<CR><LF> <LF> <LF> SM: Authentication: Iteration Number = 2<CR><LF> SM: Authentication: Iteration Pass Key = 3<CR><LF> <LF> SM: Authentication: Locally generated Nonce :<CR><LF> 0x6a 0xb4 0x26 0x6 0xb7 0x6e 0x66 0x7d<CR><LF> <LF> SM: Authentication: Locally generated Code :<CR><LF> 0x9d 0xbb 0x59 0x2b 0xc1 0x7b 0x53 0xa0<CR><LF> <LF> SM: Authentication: Sending Code and Nonce<CR><LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 2 sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:00:05.444 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 2 received<CR><LF> <LF> SM: Authentication: Received Code :<CR><LF> 0x6f 0xc 0x9c 0x21 0xee 0xec 0xb3 0x1c<CR><LF> <LF> SM: Authentication: Received Nonce :<CR><LF> 0x6f 0xd0 0x7f 0x6a 0x73 0x4f 0x54 0xdf<CR><LF> <LF> SM: Authentication: Locally computed Foreign Code :<CR><LF> 0x6f 0xc 0x9c 0x21 0xee 0xec 0xb3 0x1c<CR><LF> <LF> <LF> SM: Authentication: Iteration Number = 3<CR><LF> SM: Authentication: Iteration Pass Key = 4<CR><LF> <LF> SM: Authentication: Locally generated Nonce :<CR><LF> 0x72 0xac 0xe1 0x47 0xd6 0x2f 0xf6 0xe3<CR><LF> <LF> SM: Authentication: Locally generated Code :<CR><LF> 0x53 0x10 0xeb 0x3d 0xa6 0x25 0xc2 0x4b<CR><LF> <LF> SM: Authentication: Sending Code and Nonce<CR><LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 3 sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:00:05.725 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 3 received<CR><LF> <LF> SM: Authentication: Received Code :<CR><LF> 0xb3 0x61 0x7 0x32 0x34 0x62 0x82 0x84<CR><LF> <LF> SM: Authentication: Received Nonce :<CR><LF> 0xf7 0xf 0x3b 0x56 0x7f 0x5 0x9e 0xa2<CR><LF> <LF> SM: Authentication: Locally computed Foreign Code :<CR><LF> 0xb3 0x61 0x7 0x32 0x34 0x62 0x82 0x84<CR><LF> <LF> <LF> SM: Authentication: Iteration Number = 4<CR><LF> SM: Authentication: Iteration Pass Key = 5<CR><LF> <LF> SM: Authentication: Locally generated Nonce :<CR><LF> 0x93 0x86 0x6 0x76 0x52 0x9b 0xfa 0xd2<CR><LF> <LF> SM: Authentication: Locally generated Code :<CR><LF> 0xbd 0x4b 0x5b 0x8c 0x5f 0x7b 0x87 0x18<CR><LF> <LF> SM: Authentication: Sending Code and Nonce<CR><LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 4 sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:00:06.051 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 4 received<CR><LF> <LF> SM: Authentication: Received Code :<CR><LF> 0xcf 0xe7 0x70 0x5c 0x92 0x2d 0xc3 0x61<CR><LF> <LF> SM: Authentication: Received Nonce :<CR><LF> 0x48 0xe4 0x8e 0xb4 0xd8 0xea 0x15 0x1e<CR><LF> <LF> SM: Authentication: Locally computed Foreign Code :<CR><LF> 0xcf 0xe7 0x70 0x5c 0x92 0x2d 0xc3 0x61<CR><LF> SM: Authentication: Successful<CR><LF> SM: Changing State to SM_states_key_gen<CR><LF> SM: Beginning Key Generation<CR><LF> <LF> SM: Key Gen: Generated keys (Concat'd):<CR><LF> 0xcb 0x1d 0xae 0x98 0xb9 0x22 0x56 0x71<CR><LF> 0xb6 0xd3 0x6a 0xce 0x89 0x9b 0x1 0x99<CR><LF> 0xb 0xd6 0xd4 0x9e 0x84 0xb2 0xaf 0xd3<CR><LF> 0x37 0x89 0x4c 0xf6 0x18 0xd9 0x8f 0xe5<CR><LF> <LF> SM: Key Gen: Local Security Val:<CR><LF> 0x4a 0x6a 0x95 0x3 0x3e 0xdb 0x2d 0xed<CR><LF> 0xdc 0xbf 0x98 0x44 0x8b 0xfc 0x7d 0x86<CR><LF> <LF> SM: Key Gen: Expected Security Val:<CR><LF> 0x1d 0x22 0xec 0xb0 0xc4 0x67 0x75 0x20<CR><LF> 0x8f 0x3d 0x99 0x27 0x7c 0xdf 0x25 0x6c<CR><LF> SM: SMMsgs_cmdIds_processInfo128SecurityVal command sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:00:06.242 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processInfo128SecurityVal command received<CR><LF> SM: Key Gen: Security constant received:<CR><LF> 0x1d 0x22 0xec 0xb0 0xc4 0x67 0x75 0x20<CR><LF> 0x8f 0x3d 0x99 0x27 0x7c 0xdf 0x25 0x6c<CR><LF> SM: SMMsgs_cmdIds_processSuccess command sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:00:06.545 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processSuccess command received<CR><LF> SM: Changing State to SM_states_finish_success<CR><LF> SM: Changing State to SM_states_entry<CR><LF> Commissioned: 0x1<CR><LF> 13-09-2019 18:05:27.601 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:05:28.558 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:05:36.707 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:05:37.663 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:05:45.781 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:05:46.738 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:05:54.902 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:05:55.859 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:06:04.008 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:06:04.965 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:06:13.114 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:06:14.070 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:06:22.203 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:06:23.176 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:06:31.309 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:06:32.266 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:06:40.415 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:06:41.372 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:06:49.520 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:06:50.477 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:06:58.626 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:06:59.583 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:07:07.716 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:07:08.689 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:07:16.822 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:07:17.779 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:07:25.944 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:07:26.916 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:07:35.066 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:07:36.022 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:07:44.171 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:07:45.128 [RX] - State Changed: 4<CR><LF> 13-09-2019 18:07:53.246 [RX] - State Changed: 5<CR><LF> 13-09-2019 18:07:54.585 [RX] - <NUL> 13-09-2019 18:07:57.120 [RX] - �<NUL>TI Sensor<CR><LF> KeyInfo recovered<CR><LF> State Changed: 2<CR><LF> Restarted: 0x1<CR><LF> Channel: 1<CR><LF> State Changed: 4<CR><LF> 13-09-2019 18:09:05.469 [RX] - <NUL> 13-09-2019 18:09:06.282 [RX] - �<NUL>TI Sensor<CR><LF> KeyInfo recovered<CR><LF> State Changed: 2<CR><LF> Restarted: 0x1<CR><LF> Channel: 1<CR><LF> State Changed: 4<CR><LF> 13-09-2019 18:10:00.361 [RX] - SM: Timer stopped<LF><CR> <LF> Commissioning Started: 0x1<CR><LF> SM: Changing State to SM_states_auth_method<CR><LF> SM: SMMsgs_cmdIds_processResponse command sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:10:06.341 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processMethodConfirm command received<CR><LF> SM: Changing State to SM_states_passkey<CR><LF> SM: SMMsgs_cmdIds_processPasskeyConfirm command sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:10:06.664 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processPasskeyConfirm command received<CR><LF> SM: Changing State to SM_states_key_exchange<CR><LF> 13-09-2019 18:10:06.773 [RX] - SM: SMMsgs_cmdIds_processPublicKey command sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:10:07.276 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processPublicKey command received<CR><LF> 13-09-2019 18:10:07.455 [RX] - SM: Changing State to SM_states_authentication<CR><LF> SM: Derived shared secret:<LF><CR> <LF> 0x4b 0x3e 0xca 0xf1 0xf8 0xac 0x96 0x1d<CR><LF> 0x3e 0xca 0xf1 0xf8 0xac 0x96 0x1d 0x6b<CR><LF> 0xca 0xf1 0xf8 0xac 0x96 0x1d 0x6b 0x19<CR><LF> 0xf1 0xf8 0xac 0x96 0x1d 0x6b 0x19 0xcc<CR><LF> 0xf8 0xac 0x96 0x1d 0x6b 0x19 0xcc 0x2e<CR><LF> 0xac 0x96 0x1d 0x6b 0x19 0xcc 0x2e 0xb9<CR><LF> 0x96 0x1d 0x6b 0x19 0xcc 0x2e 0xb9 0xfc<CR><LF> 0x1d 0x6b 0x19 0xcc 0x2e 0xb9 0xfc 0xf6<CR><LF> <LF> <LF> SM: Authentication: Iteration Number = 0<CR><LF> SM: Authentication: Iteration Pass Key = 1<CR><LF> <LF> SM: Authentication: Locally generated Nonce :<CR><LF> 0xba 0x91 0xec 0x3 0x32 0xa1 0xc8 0xca<CR><LF> <LF> SM: Authentication: Locally generated Code :<CR><LF> 0x20 0x20 0x61 0x13 0xd 0xf9 0x55 0x37<CR><LF> <LF> SM: Authentication: Sending Code and Nonce<CR><LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 0 sent<CR><LF> SM: Timer started<LF><CR> <LF> SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processInfo128Co 13-09-2019 18:10:07.625 [RX] - deNonce command : Pkt Num = 0 received<CR><LF> <LF> SM: Authentication: Received Code :<CR><LF> 0xed 0x75 0xa2 0xc8 0xee 0x49 0xeb 0xcc<CR><LF> <LF> SM: Authentication: Received Nonce :<CR><LF> 0x6 0x7c 0x52 0x63 0x69 0xdd 0xc2 0xcf<CR><LF> <LF> SM: Authentication: Locally computed Foreign Code :<CR><LF> 0xed 0x75 0xa2 0xc8 0xee 0x49 0xeb 0xcc<CR><LF> <LF> <LF> SM: Authentication: Iteration Number = 1<CR><LF> SM: Authentication: Iteration Pass Key = 2<CR><LF> <LF> SM: Authentication: Locally generated Nonce :<CR><LF> 0x37 0xef 0xa1 0xe6 0x9c 0xfa 0xdb 0xa2<CR><LF> <LF> SM: Authentication: Locally generated Code :<CR><LF> 0xe4 0x16 0xa7 0x81 0x6 0x33 0x79 0x70<CR><LF> <LF> SM: Authentication: Sending Code and Nonce<CR><LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 1 sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:10:07.849 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 1 received<CR><LF> <LF> SM: Authentication: Received Code :<CR><LF> 0x9c 0xa7 0x4d 0xc6 0x84 0xe2 0xb2 0x4a<CR><LF> <LF> SM: Authentication: Received Nonce :<CR><LF> 0x53 0x88 0xc4 0x77 0xac 0x26 0xc2 0xac<CR><LF> <LF> SM: Authentication: Locally computed Foreign Code :<CR><LF> 0x9c 0xa7 0x4d 0xc6 0x84 0xe2 0xb2 0x4a<CR><LF> <LF> <LF> SM: Authentication: Iteration Number = 2<CR><LF> SM: Authentication: Iteration Pass Key = 3<CR><LF> <LF> SM: Authentication: Locally generated Nonce :<CR><LF> 0xa3 0x98 0x16 0x32 0x3f 0x55 0x2c 0xf4<CR><LF> <LF> SM: Authentication: Locally generated Code :<CR><LF> 0xdc 0x45 0x7e 0x89 0x74 0x62 0x7 0x3e<CR><LF> <LF> SM: Authentication: Sending Code and Nonce<CR><LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 2 sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:10:08.230 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 2 received<CR><LF> <LF> SM: Authentication: Received Code :<CR><LF> 0xe7 0x2e 0xea 0x94 0x7d 0xbb 0x28 0x1a<CR><LF> <LF> SM: Authentication: Received Nonce :<CR><LF> 0x2b 0xef 0x81 0xca 0x90 0xd8 0x46 0xbe<CR><LF> <LF> SM: Authentication: Locally computed Foreign Code :<CR><LF> 0xe7 0x2e 0xea 0x94 0x7d 0xbb 0x28 0x1a<CR><LF> <LF> <LF> SM: Authentication: Iteration Number = 3<CR><LF> SM: Authentication: Iteration Pass Key = 4<CR><LF> <LF> SM: Authentication: Locally generated Nonce :<CR><LF> 0x4f 0xc8 0x35 0x5c 0x4f 0x69 0xe7 0x7b<CR><LF> <LF> SM: Authentication: Locally generated Code :<CR><LF> 0x9d 0x10 0x1a 0x71 0xa9 0x1d 0x27 0x87<CR><LF> <LF> SM: Authentication: Sending Code and Nonce<CR><LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 3 sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:10:08.454 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 3 received<CR><LF> <LF> SM: Authentication: Received Code :<CR><LF> 0x2e 0xd8 0x94 0xf7 0x68 0xc3 0x3c 0x80<CR><LF> <LF> SM: Authentication: Received Nonce :<CR><LF> 0x8c 0xa 0x20 0x66 0xc2 0x97 0x6f 0xf4<CR><LF> <LF> SM: Authentication: Locally computed Foreign Code :<CR><LF> 0x2e 0xd8 0x94 0xf7 0x68 0xc3 0x3c 0x80<CR><LF> <LF> <LF> SM: Authentication: Iteration Number = 4<CR><LF> SM: Authentication: Iteration Pass Key = 5<CR><LF> <LF> SM: Authentication: Locally generated Nonce :<CR><LF> 0xf1 0x8f 0xe8 0xab 0xf2 0xdf 0xbf 0xfd<CR><LF> <LF> SM: Authentication: Locally generated Code :<CR><LF> 0xf0 0x14 0xba 0xca 0xcc 0x80 0xbd 0xd6<CR><LF> <LF> SM: Authentication: Sending Code and Nonce<CR><LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 4 sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:10:08.752 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processInfo128CodeNonce command : Pkt Num = 4 received<CR><LF> <LF> SM: Authentication: Received Code :<CR><LF> 0xfd 0x5e 0xd0 0xf9 0x2 0xc7 0x55 0x4a<CR><LF> <LF> SM: Authentication: Received Nonce :<CR><LF> 0xc5 0x3f 0x6 0xd3 0x1d 0x78 0xcf 0xab<CR><LF> <LF> SM: Authentication: Locally computed Foreign Code :<CR><LF> 0xfd 0x5e 0xd0 0xf9 0x2 0xc7 0x55 0x4a<CR><LF> SM: Authentication: Successful<CR><LF> SM: Changing State to SM_states_key_gen<CR><LF> SM: Beginning Key Generation<CR><LF> <LF> SM: Key Gen: Generated keys (Concat'd):<CR><LF> 0x9e 0xe5 0xdc 0xae 0xb8 0xb9 0x5b 0x11<CR><LF> 0x78 0x70 0x35 0x64 0x4e 0xaa 0xdf 0x87<CR><LF> 0x3c 0xf 0x52 0x39 0xcb 0x8e 0xa7 0xe7<CR><LF> 0x14 0xab 0xad 0x8b 0x75 0x39 0x6 0x85<CR><LF> <LF> SM: Key Gen: Local Security Val:<CR><LF> 0x6f 0x45 0xf7 0x4f 0xdf 0x19 0x78 0xcf<CR><LF> 0x7c 0x8b 0xf4 0x80 0xb 0x55 0x63 0xb5<CR><LF> <LF> SM: Key Gen: Expected Security Val:<CR><LF> 0xd7 0xbd 0x4f 0xd7 0xcd 0x82 0xdb 0xd9<CR><LF> 0xb0 0x97 0x90 0xae 0x8e 0xba 0x67 0xe5<CR><LF> SM: SMMsgs_cmdIds_processInfo128SecurityVal command sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:10:09.078 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processInfo128SecurityVal command received<CR><LF> SM: Key Gen: Security constant received:<CR><LF> 0xd7 0xbd 0x4f 0xd7 0xcd 0x82 0xdb 0xd9<CR><LF> 0xb0 0x97 0x90 0xae 0x8e 0xba 0x67 0xe5<CR><LF> SM: SMMsgs_cmdIds_processSuccess command sent<CR><LF> SM: Timer started<LF><CR> <LF> 13-09-2019 18:10:09.370 [RX] - SM: Timer stopped<LF><CR> <LF> SM: SMMsgs_cmdIds_processSuccess command received<CR><LF> SM: Changing State to SM_states_finish_success<CR><LF> SM: Changing State to SM_states_entry<CR><LF> Commissioned: 0x1<CR><LF>
