I'm using a CC1310 RSM package 4x4mm.
On this board I am trying to run the EasyLinkTx example.
The board is connected to a XDS110 debug probe on my launchpad through 2 wire JTAG (TCK, TMS, RESET, GND an 3V3).
When I use the board in smartRf Studio it works just fine. The software detects it and I can send and receive packets.
When I flash the program onto the custom board nothing happens. I power it up via a lab power supply at 3.3V and it shows about 6mA of current consumption.
So I assume the board powers up but does not do any RF stuff, because the current is very stable, also I can't receive anything with smartrf studio.
I already modified the board files according to the custom hardware guide. Setting the unused pins as "PIN_UNASSIGNED" .
Edit: maybe it is worth mentioning, that I don't have a 32kHz crystal on my custom board.
/* * Copyright (c) 2015-2019, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /** ============================================================================ * @file CC1310_LAUNCHXL.h * * @brief CC1310 LaunchPad Board Specific header file. * * The CC1310_LAUNCHXL header file should be included in an application as * follows: * @code * #include "CC1310_LAUNCHXL.h" * @endcode * * ============================================================================ */ #ifndef __CC1310_LAUNCHXL_BOARD_H__ #define __CC1310_LAUNCHXL_BOARD_H__ #ifdef __cplusplus extern "C" { #endif /* Includes */ #include <ti/drivers/PIN.h> #include <ti/devices/cc13x0/driverlib/ioc.h> /* Externs */ extern const PIN_Config BoardGpioInitTable[]; /* Defines */ #define CC1310_LAUNCHXL /* Mapping of pins to board signals using general board aliases * <board signal alias> <pin mapping> <comments> */ /* Analog capable DIOs */ #define CC1310_LAUNCHXL_DIO23_ANALOG IOID_23 #define CC1310_LAUNCHXL_DIO24_ANALOG IOID_24 #define CC1310_LAUNCHXL_DIO25_ANALOG IOID_25 #define CC1310_LAUNCHXL_DIO26_ANALOG IOID_26 #define CC1310_LAUNCHXL_DIO27_ANALOG PIN_UNASSIGNED #define CC1310_LAUNCHXL_DIO28_ANALOG PIN_UNASSIGNED #define CC1310_LAUNCHXL_DIO29_ANALOG PIN_UNASSIGNED #define CC1310_LAUNCHXL_DIO30_ANALOG PIN_UNASSIGNED /* Digital IOs */ #define CC1310_LAUNCHXL_DIO0 IOID_8 #define CC1310_LAUNCHXL_DIO1 IOID_9 #define CC1310_LAUNCHXL_DIO12 PIN_UNASSIGNED #define CC1310_LAUNCHXL_DIO15 PIN_UNASSIGNED #define CC1310_LAUNCHXL_DIO16_TDO PIN_UNASSIGNED #define CC1310_LAUNCHXL_DIO17_TDI PIN_UNASSIGNED #define CC1310_LAUNCHXL_DIO21 PIN_UNASSIGNED #define CC1310_LAUNCHXL_DIO22 PIN_UNASSIGNED /* Discrete Inputs */ #define CC1310_LAUNCHXL_PIN_BTN1 IOID_22 #define CC1310_LAUNCHXL_PIN_BTN2 PIN_UNASSIGNED /* GPIO */ #define CC1310_LAUNCHXL_GPIO_LED_ON 1 #define CC1310_LAUNCHXL_GPIO_LED_OFF 0 /* I2C */ #define CC1310_LAUNCHXL_I2C0_SCL0 PIN_UNASSIGNED #define CC1310_LAUNCHXL_I2C0_SDA0 PIN_UNASSIGNED /* I2S */ #define CC1310_LAUNCHXL_I2S_ADO PIN_UNASSIGNED #define CC1310_LAUNCHXL_I2S_ADI PIN_UNASSIGNED #define CC1310_LAUNCHXL_I2S_BCLK PIN_UNASSIGNED #define CC1310_LAUNCHXL_I2S_MCLK PIN_UNASSIGNED #define CC1310_LAUNCHXL_I2S_WCLK PIN_UNASSIGNED /* LEDs */ #define CC1310_LAUNCHXL_PIN_LED_ON 1 #define CC1310_LAUNCHXL_PIN_LED_OFF 0 #define CC1310_LAUNCHXL_PIN_RLED IOID_16 #define CC1310_LAUNCHXL_PIN_GLED PIN_UNASSIGNED /* PWM Outputs */ #define CC1310_LAUNCHXL_PWMPIN0 CC1310_LAUNCHXL_PIN_RLED #define CC1310_LAUNCHXL_PWMPIN1 PIN_UNASSIGNED #define CC1310_LAUNCHXL_PWMPIN2 PIN_UNASSIGNED #define CC1310_LAUNCHXL_PWMPIN3 PIN_UNASSIGNED #define CC1310_LAUNCHXL_PWMPIN4 PIN_UNASSIGNED #define CC1310_LAUNCHXL_PWMPIN5 PIN_UNASSIGNED #define CC1310_LAUNCHXL_PWMPIN6 PIN_UNASSIGNED #define CC1310_LAUNCHXL_PWMPIN7 PIN_UNASSIGNED /* SPI */ #define CC1310_LAUNCHXL_SPI_FLASH_CS PIN_UNASSIGNED #define CC1310_LAUNCHXL_FLASH_CS_ON 0 #define CC1310_LAUNCHXL_FLASH_CS_OFF 1 /* SPI Board */ #define CC1310_LAUNCHXL_SPI0_MISO PIN_UNASSIGNED /* RF1.20 */ #define CC1310_LAUNCHXL_SPI0_MOSI PIN_UNASSIGNED /* RF1.18 */ #define CC1310_LAUNCHXL_SPI0_CLK PIN_UNASSIGNED /* RF1.16 */ #define CC1310_LAUNCHXL_SPI0_CSN PIN_UNASSIGNED #define CC1310_LAUNCHXL_SPI1_MISO PIN_UNASSIGNED #define CC1310_LAUNCHXL_SPI1_MOSI PIN_UNASSIGNED #define CC1310_LAUNCHXL_SPI1_CLK PIN_UNASSIGNED #define CC1310_LAUNCHXL_SPI1_CSN PIN_UNASSIGNED /* UART Board */ #define CC1310_LAUNCHXL_UART_RX PIN_UNASSIGNED /* RXD */ #define CC1310_LAUNCHXL_UART_TX PIN_UNASSIGNED /* TXD */ #define CC1310_LAUNCHXL_UART_CTS PIN_UNASSIGNED /* CTS */ #define CC1310_LAUNCHXL_UART_RTS PIN_UNASSIGNED /* RTS */ /*! * @brief Initialize the general board specific settings * * This function initializes the general board specific settings. */ void CC1310_LAUNCHXL_initGeneral(void); /*! * @brief Turn off the external flash on LaunchPads * */ void CC1310_LAUNCHXL_shutDownExtFlash(void); /*! * @brief Wake up the external flash present on the board files * * This function toggles the chip select for the amount of time needed * to wake the chip up. */ void CC1310_LAUNCHXL_wakeUpExtFlash(void); /*! * @def CC1310_LAUNCHXL_ADCBufName * @brief Enum of ADCBufs */ typedef enum CC1310_LAUNCHXL_ADCBufName { CC1310_LAUNCHXL_ADCBUF0 = 0, CC1310_LAUNCHXL_ADCBUFCOUNT } CC1310_LAUNCHXL_ADCBufName; /*! * @def CC1310_LAUNCHXL_ADCBuf0SourceName * @brief Enum of ADCBuf channels */ typedef enum CC1310_LAUNCHXL_ADCBuf0ChannelName { CC1310_LAUNCHXL_ADCBUF0CHANNEL0 = 0, CC1310_LAUNCHXL_ADCBUF0CHANNEL1, CC1310_LAUNCHXL_ADCBUF0CHANNEL2, CC1310_LAUNCHXL_ADCBUF0CHANNEL3, CC1310_LAUNCHXL_ADCBUF0CHANNEL4, CC1310_LAUNCHXL_ADCBUF0CHANNEL5, CC1310_LAUNCHXL_ADCBUF0CHANNEL6, CC1310_LAUNCHXL_ADCBUF0CHANNEL7, CC1310_LAUNCHXL_ADCBUF0CHANNELVDDS, CC1310_LAUNCHXL_ADCBUF0CHANNELDCOUPL, CC1310_LAUNCHXL_ADCBUF0CHANNELVSS, CC1310_LAUNCHXL_ADCBUF0CHANNELCOUNT } CC1310_LAUNCHXL_ADCBuf0ChannelName; /*! * @def CC1310_LAUNCHXL_ADCName * @brief Enum of ADCs */ typedef enum CC1310_LAUNCHXL_ADCName { CC1310_LAUNCHXL_ADC0 = 0, CC1310_LAUNCHXL_ADC1, CC1310_LAUNCHXL_ADC2, CC1310_LAUNCHXL_ADC3, CC1310_LAUNCHXL_ADC4, CC1310_LAUNCHXL_ADC5, CC1310_LAUNCHXL_ADC6, CC1310_LAUNCHXL_ADC7, CC1310_LAUNCHXL_ADCDCOUPL, CC1310_LAUNCHXL_ADCVSS, CC1310_LAUNCHXL_ADCVDDS, CC1310_LAUNCHXL_ADCCOUNT } CC1310_LAUNCHXL_ADCName; /*! * @def CC1310_LAUNCHXL_CryptoName * @brief Enum of Crypto names */ typedef enum CC1310_LAUNCHXL_CryptoName { CC1310_LAUNCHXL_CRYPTO0 = 0, CC1310_LAUNCHXL_CRYPTOCOUNT } CC1310_LAUNCHXL_CryptoName; /*! * @def CC1310_LAUNCHXL_AESCCMName * @brief Enum of AESCCM names */ typedef enum CC1310_LAUNCHXL_AESCCMName { CC1310_LAUNCHXL_AESCCM0 = 0, CC1310_LAUNCHXL_AESCCMCOUNT } CC1310_LAUNCHXL_AESCCMName; /*! * @def CC1310_LAUNCHXL_AESGCMName * @brief Enum of AESGCM names */ typedef enum CC1310_LAUNCHXL_AESGCMName { CC1310_LAUNCHXL_AESGCM0 = 0, CC1310_LAUNCHXL_AESGCMCOUNT } CC1310_LAUNCHXL_AESGCMName; /*! * @def CC1310_LAUNCHXL_AESCBCName * @brief Enum of AESCBC names */ typedef enum CC1310_LAUNCHXL_AESCBCName { CC1310_LAUNCHXL_AESCBC0 = 0, CC1310_LAUNCHXL_AESCBCCOUNT } CC1310_LAUNCHXL_AESCBCName; /*! * @def CC1310_LAUNCHXL_AESCTRName * @brief Enum of AESCTR names */ typedef enum CC1310_LAUNCHXL_AESCTRName { CC1310_LAUNCHXL_AESCTR0 = 0, CC1310_LAUNCHXL_AESCTRCOUNT } CC1310_LAUNCHXL_AESCTRName; /*! * @def CC1310_LAUNCHXL_AESECBName * @brief Enum of AESECB names */ typedef enum CC1310_LAUNCHXL_AESECBName { CC1310_LAUNCHXL_AESECB0 = 0, CC1310_LAUNCHXL_AESECBCOUNT } CC1310_LAUNCHXL_AESECBName; /*! * @def CC1310_LAUNCHXL_AESCTRDRBGName * @brief Enum of AESCTRDRBG names */ typedef enum CC1310_LAUNCHXL_AESCTRDRBGName { CC1310_LAUNCHXL_AESCTRDRBG0 = 0, CC1310_LAUNCHXL_AESCTRDRBGCOUNT } CC1310_LAUNCHXL_AESCTRDRBGName; /*! * @def CC1310_LAUNCHXL_TRNGName * @brief Enum of TRNG names */ typedef enum CC1310_LAUNCHXL_TRNGName { CC1310_LAUNCHXL_TRNG0 = 0, CC1310_LAUNCHXL_TRNGCOUNT } CC1310_LAUNCHXL_TRNGName; /*! * @def CC1310_LAUNCHXL_GPIOName * @brief Enum of GPIO names */ typedef enum CC1310_LAUNCHXL_GPIOName { CC1310_LAUNCHXL_GPIO_S1 = 0, CC1310_LAUNCHXL_GPIO_S2, CC1310_LAUNCHXL_SPI_MASTER_READY, CC1310_LAUNCHXL_SPI_SLAVE_READY, CC1310_LAUNCHXL_GPIO_LED_GREEN, CC1310_LAUNCHXL_GPIO_LED_RED, CC1310_LAUNCHXL_GPIO_TMP116_EN, CC1310_LAUNCHXL_GPIO_SPI_FLASH_CS, CC1310_LAUNCHXL_SDSPI_CS, CC1310_LAUNCHXL_GPIO_LCD_CS, CC1310_LAUNCHXL_GPIO_LCD_POWER, CC1310_LAUNCHXL_GPIO_LCD_ENABLE, CC1310_LAUNCHXL_GPIOCOUNT } CC1310_LAUNCHXL_GPIOName; /*! * @def CC1310_LAUNCHXL_GPTimerName * @brief Enum of GPTimer parts */ typedef enum CC1310_LAUNCHXL_GPTimerName { CC1310_LAUNCHXL_GPTIMER0A = 0, CC1310_LAUNCHXL_GPTIMER0B, CC1310_LAUNCHXL_GPTIMER1A, CC1310_LAUNCHXL_GPTIMER1B, CC1310_LAUNCHXL_GPTIMER2A, CC1310_LAUNCHXL_GPTIMER2B, CC1310_LAUNCHXL_GPTIMER3A, CC1310_LAUNCHXL_GPTIMER3B, CC1310_LAUNCHXL_GPTIMERPARTSCOUNT } CC1310_LAUNCHXL_GPTimerName; /*! * @def CC1310_LAUNCHXL_GPTimers * @brief Enum of GPTimers */ typedef enum CC1310_LAUNCHXL_GPTimers { CC1310_LAUNCHXL_GPTIMER0 = 0, CC1310_LAUNCHXL_GPTIMER1, CC1310_LAUNCHXL_GPTIMER2, CC1310_LAUNCHXL_GPTIMER3, CC1310_LAUNCHXL_GPTIMERCOUNT } CC1310_LAUNCHXL_GPTimers; /*! * @def CC1310_LAUNCHXL_I2CName * @brief Enum of I2C names */ typedef enum CC1310_LAUNCHXL_I2CName { CC1310_LAUNCHXL_I2C0 = 0, CC1310_LAUNCHXL_I2CCOUNT } CC1310_LAUNCHXL_I2CName; /*! * @def CC1310_LAUNCHXL_I2SName * @brief Enum of I2S names */ typedef enum CC1310_LAUNCHXL_I2SName { CC1310_LAUNCHXL_I2S0 = 0, CC1310_LAUNCHXL_I2SCOUNT } CC1310_LAUNCHXL_I2SName; /*! * @def CC1310_LAUNCHXL_NVSName * @brief Enum of NVS names */ typedef enum CC1310_LAUNCHXL_NVSName { #ifndef Board_EXCLUDE_NVS_INTERNAL_FLASH CC1310_LAUNCHXL_NVSCC26XX0 = 0, #endif #ifndef Board_EXCLUDE_NVS_EXTERNAL_FLASH CC1310_LAUNCHXL_NVSSPI25X0, #endif CC1310_LAUNCHXL_NVSCOUNT } CC1310_LAUNCHXL_NVSName; /*! * @def CC1310_LAUNCHXL_PWM * @brief Enum of PWM outputs */ typedef enum CC1310_LAUNCHXL_PWMName { CC1310_LAUNCHXL_PWM0 = 0, CC1310_LAUNCHXL_PWM1, CC1310_LAUNCHXL_PWM2, CC1310_LAUNCHXL_PWM3, CC1310_LAUNCHXL_PWM4, CC1310_LAUNCHXL_PWM5, CC1310_LAUNCHXL_PWM6, CC1310_LAUNCHXL_PWM7, CC1310_LAUNCHXL_PWMCOUNT } CC1310_LAUNCHXL_PWMName; /*! * @def CC1310_LAUNCHXL_SDName * @brief Enum of SD names */ typedef enum CC1310_LAUNCHXL_SDName { CC1310_LAUNCHXL_SDSPI0 = 0, CC1310_LAUNCHXL_SDCOUNT } CC1310_LAUNCHXL_SDName; /*! * @def CC1310_LAUNCHXL_SPIName * @brief Enum of SPI names */ typedef enum CC1310_LAUNCHXL_SPIName { CC1310_LAUNCHXL_SPI0 = 0, CC1310_LAUNCHXL_SPI1, CC1310_LAUNCHXL_SPICOUNT } CC1310_LAUNCHXL_SPIName; /*! * @def CC1310_LAUNCHXL_UARTName * @brief Enum of UARTs */ typedef enum CC1310_LAUNCHXL_UARTName { CC1310_LAUNCHXL_UART0 = 0, CC1310_LAUNCHXL_UARTCOUNT } CC1310_LAUNCHXL_UARTName; /*! * @def CC1310_LAUNCHXL_UDMAName * @brief Enum of DMA buffers */ typedef enum CC1310_LAUNCHXL_UDMAName { CC1310_LAUNCHXL_UDMA0 = 0, CC1310_LAUNCHXL_UDMACOUNT } CC1310_LAUNCHXL_UDMAName; /*! * @def CC1310_LAUNCHXL_WatchdogName * @brief Enum of Watchdogs */ typedef enum CC1310_LAUNCHXL_WatchdogName { CC1310_LAUNCHXL_WATCHDOG0 = 0, CC1310_LAUNCHXL_WATCHDOGCOUNT } CC1310_LAUNCHXL_WatchdogName; #ifdef __cplusplus } #endif #endif /* __CC1310_LAUNCHXL_BOARD_H__ */
/* * Copyright (c) 2015-2019, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* * ====================== CC1310_LAUNCHXL.c =================================== * This file is responsible for setting up the board specific items for the * CC1310_LAUNCHXL board. */ #include <stdbool.h> #include <stddef.h> #include <stdint.h> #include <ti/devices/cc13x0/driverlib/ioc.h> #include <ti/devices/cc13x0/driverlib/udma.h> #include <ti/devices/cc13x0/inc/hw_ints.h> #include <ti/devices/cc13x0/inc/hw_memmap.h> #include "CC1310_LAUNCHXL.h" /* * =============================== ADCBuf =============================== */ #include <ti/drivers/ADCBuf.h> #include <ti/drivers/adcbuf/ADCBufCC26XX.h> ADCBufCC26XX_Object adcBufCC26xxObjects[CC1310_LAUNCHXL_ADCBUFCOUNT]; /* * This table converts a virtual adc channel into a dio and internal analogue * input signal. This table is necessary for the functioning of the adcBuf * driver. Comment out unused entries to save flash. Dio and internal signal * pairs are hardwired. Do not remap them in the table. You may reorder entire * entries. The mapping of dio and internal signals is package dependent. */ const ADCBufCC26XX_AdcChannelLutEntry ADCBufCC26XX_adcChannelLut[CC1310_LAUNCHXL_ADCBUF0CHANNELCOUNT] = { /*{CC1310_LAUNCHXL_DIO23_ANALOG, ADC_COMPB_IN_AUXIO7}, {CC1310_LAUNCHXL_DIO24_ANALOG, ADC_COMPB_IN_AUXIO6}, {CC1310_LAUNCHXL_DIO25_ANALOG, ADC_COMPB_IN_AUXIO5}, {CC1310_LAUNCHXL_DIO26_ANALOG, ADC_COMPB_IN_AUXIO4}, {CC1310_LAUNCHXL_DIO27_ANALOG, ADC_COMPB_IN_AUXIO3}, {CC1310_LAUNCHXL_DIO28_ANALOG, ADC_COMPB_IN_AUXIO2}, {CC1310_LAUNCHXL_DIO29_ANALOG, ADC_COMPB_IN_AUXIO1}, {CC1310_LAUNCHXL_DIO30_ANALOG, ADC_COMPB_IN_AUXIO0},*/ {PIN_UNASSIGNED, ADC_COMPB_IN_VDDS}, {PIN_UNASSIGNED, ADC_COMPB_IN_DCOUPL}, {PIN_UNASSIGNED, ADC_COMPB_IN_VSS}, }; const ADCBufCC26XX_HWAttrs adcBufCC26xxHWAttrs[CC1310_LAUNCHXL_ADCBUFCOUNT] = { { .intPriority = ~0, .swiPriority = 0, .adcChannelLut = ADCBufCC26XX_adcChannelLut, } }; const ADCBuf_Config ADCBuf_config[CC1310_LAUNCHXL_ADCBUFCOUNT] = { { &ADCBufCC26XX_fxnTable, &adcBufCC26xxObjects[CC1310_LAUNCHXL_ADCBUF0], &adcBufCC26xxHWAttrs[CC1310_LAUNCHXL_ADCBUF0] }, }; const uint_least8_t ADCBuf_count = CC1310_LAUNCHXL_ADCBUFCOUNT; /* * =============================== ADC =============================== */ #include <ti/drivers/ADC.h> #include <ti/drivers/adc/ADCCC26XX.h> ADCCC26XX_Object adcCC26xxObjects[CC1310_LAUNCHXL_ADCCOUNT]; const ADCCC26XX_HWAttrs adcCC26xxHWAttrs[CC1310_LAUNCHXL_ADCCOUNT] = { { .adcDIO = CC1310_LAUNCHXL_DIO23_ANALOG, .adcCompBInput = ADC_COMPB_IN_AUXIO7, .refSource = ADCCC26XX_FIXED_REFERENCE, .samplingDuration = ADCCC26XX_SAMPLING_DURATION_2P7_US, .inputScalingEnabled = true, .triggerSource = ADCCC26XX_TRIGGER_MANUAL, .returnAdjustedVal = false }, { .adcDIO = CC1310_LAUNCHXL_DIO24_ANALOG, .adcCompBInput = ADC_COMPB_IN_AUXIO6, .refSource = ADCCC26XX_FIXED_REFERENCE, .samplingDuration = ADCCC26XX_SAMPLING_DURATION_2P7_US, .inputScalingEnabled = true, .triggerSource = ADCCC26XX_TRIGGER_MANUAL, .returnAdjustedVal = false }, { .adcDIO = CC1310_LAUNCHXL_DIO25_ANALOG, .adcCompBInput = ADC_COMPB_IN_AUXIO5, .refSource = ADCCC26XX_FIXED_REFERENCE, .samplingDuration = ADCCC26XX_SAMPLING_DURATION_2P7_US, .inputScalingEnabled = true, .triggerSource = ADCCC26XX_TRIGGER_MANUAL, .returnAdjustedVal = false }, { .adcDIO = CC1310_LAUNCHXL_DIO26_ANALOG, .adcCompBInput = ADC_COMPB_IN_AUXIO4, .refSource = ADCCC26XX_FIXED_REFERENCE, .samplingDuration = ADCCC26XX_SAMPLING_DURATION_2P7_US, .inputScalingEnabled = true, .triggerSource = ADCCC26XX_TRIGGER_MANUAL, .returnAdjustedVal = false }, { .adcDIO = CC1310_LAUNCHXL_DIO27_ANALOG, .adcCompBInput = ADC_COMPB_IN_AUXIO3, .refSource = ADCCC26XX_FIXED_REFERENCE, .samplingDuration = ADCCC26XX_SAMPLING_DURATION_2P7_US, .inputScalingEnabled = true, .triggerSource = ADCCC26XX_TRIGGER_MANUAL, .returnAdjustedVal = false }, { .adcDIO = CC1310_LAUNCHXL_DIO28_ANALOG, .adcCompBInput = ADC_COMPB_IN_AUXIO2, .refSource = ADCCC26XX_FIXED_REFERENCE, .samplingDuration = ADCCC26XX_SAMPLING_DURATION_2P7_US, .inputScalingEnabled = true, .triggerSource = ADCCC26XX_TRIGGER_MANUAL, .returnAdjustedVal = false }, { .adcDIO = CC1310_LAUNCHXL_DIO29_ANALOG, .adcCompBInput = ADC_COMPB_IN_AUXIO1, .refSource = ADCCC26XX_FIXED_REFERENCE, .samplingDuration = ADCCC26XX_SAMPLING_DURATION_2P7_US, .inputScalingEnabled = true, .triggerSource = ADCCC26XX_TRIGGER_MANUAL, .returnAdjustedVal = false }, { .adcDIO = CC1310_LAUNCHXL_DIO30_ANALOG, .adcCompBInput = ADC_COMPB_IN_AUXIO0, .refSource = ADCCC26XX_FIXED_REFERENCE, .samplingDuration = ADCCC26XX_SAMPLING_DURATION_10P9_MS, .inputScalingEnabled = true, .triggerSource = ADCCC26XX_TRIGGER_MANUAL, .returnAdjustedVal = false }, { .adcDIO = PIN_UNASSIGNED, .adcCompBInput = ADC_COMPB_IN_DCOUPL, .refSource = ADCCC26XX_FIXED_REFERENCE, .samplingDuration = ADCCC26XX_SAMPLING_DURATION_2P7_US, .inputScalingEnabled = true, .triggerSource = ADCCC26XX_TRIGGER_MANUAL, .returnAdjustedVal = false }, { .adcDIO = PIN_UNASSIGNED, .adcCompBInput = ADC_COMPB_IN_VSS, .refSource = ADCCC26XX_FIXED_REFERENCE, .samplingDuration = ADCCC26XX_SAMPLING_DURATION_2P7_US, .inputScalingEnabled = true, .triggerSource = ADCCC26XX_TRIGGER_MANUAL, .returnAdjustedVal = false }, { .adcDIO = PIN_UNASSIGNED, .adcCompBInput = ADC_COMPB_IN_VDDS, .refSource = ADCCC26XX_FIXED_REFERENCE, .samplingDuration = ADCCC26XX_SAMPLING_DURATION_2P7_US, .inputScalingEnabled = true, .triggerSource = ADCCC26XX_TRIGGER_MANUAL, .returnAdjustedVal = false } }; const ADC_Config ADC_config[CC1310_LAUNCHXL_ADCCOUNT] = { {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC1310_LAUNCHXL_ADC0], &adcCC26xxHWAttrs[CC1310_LAUNCHXL_ADC0]}, {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC1310_LAUNCHXL_ADC1], &adcCC26xxHWAttrs[CC1310_LAUNCHXL_ADC1]}, {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC1310_LAUNCHXL_ADC2], &adcCC26xxHWAttrs[CC1310_LAUNCHXL_ADC2]}, {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC1310_LAUNCHXL_ADC3], &adcCC26xxHWAttrs[CC1310_LAUNCHXL_ADC3]}, {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC1310_LAUNCHXL_ADC4], &adcCC26xxHWAttrs[CC1310_LAUNCHXL_ADC4]}, {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC1310_LAUNCHXL_ADC5], &adcCC26xxHWAttrs[CC1310_LAUNCHXL_ADC5]}, {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC1310_LAUNCHXL_ADC6], &adcCC26xxHWAttrs[CC1310_LAUNCHXL_ADC6]}, {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC1310_LAUNCHXL_ADC7], &adcCC26xxHWAttrs[CC1310_LAUNCHXL_ADC7]}, {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC1310_LAUNCHXL_ADCDCOUPL], &adcCC26xxHWAttrs[CC1310_LAUNCHXL_ADCDCOUPL]}, {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC1310_LAUNCHXL_ADCVSS], &adcCC26xxHWAttrs[CC1310_LAUNCHXL_ADCVSS]}, {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC1310_LAUNCHXL_ADCVDDS], &adcCC26xxHWAttrs[CC1310_LAUNCHXL_ADCVDDS]}, }; const uint_least8_t ADC_count = CC1310_LAUNCHXL_ADCCOUNT; /* * =============================== Crypto =============================== */ /*#include <ti/drivers/crypto/CryptoCC26XX.h> CryptoCC26XX_Object cryptoCC26XXObjects[CC1310_LAUNCHXL_CRYPTOCOUNT]; const CryptoCC26XX_HWAttrs cryptoCC26XXHWAttrs[CC1310_LAUNCHXL_CRYPTOCOUNT] = { { .baseAddr = CRYPTO_BASE, .powerMngrId = PowerCC26XX_PERIPH_CRYPTO, .intNum = INT_CRYPTO_RESULT_AVAIL_IRQ, .intPriority = ~0, } }; const CryptoCC26XX_Config CryptoCC26XX_config[CC1310_LAUNCHXL_CRYPTOCOUNT] = { { .object = &cryptoCC26XXObjects[CC1310_LAUNCHXL_CRYPTO0], .hwAttrs = &cryptoCC26XXHWAttrs[CC1310_LAUNCHXL_CRYPTO0] } }; */ /* * =============================== AESCCM =============================== */ #include <ti/drivers/AESCCM.h> #include <ti/drivers/aesccm/AESCCMCC26XX.h> AESCCMCC26XX_Object aesccmCC26XXObjects[CC1310_LAUNCHXL_AESCCMCOUNT]; const AESCCMCC26XX_HWAttrs aesccmCC26XXHWAttrs[CC1310_LAUNCHXL_AESCCMCOUNT] = { { .intPriority = ~0, } }; const AESCCM_Config AESCCM_config[CC1310_LAUNCHXL_AESCCMCOUNT] = { { .object = &aesccmCC26XXObjects[CC1310_LAUNCHXL_AESCCM0], .hwAttrs = &aesccmCC26XXHWAttrs[CC1310_LAUNCHXL_AESCCM0] }, }; const uint_least8_t AESCCM_count = CC1310_LAUNCHXL_AESCCMCOUNT; /* * =============================== AESGCM =============================== */ #include <ti/drivers/AESGCM.h> #include <ti/drivers/aesgcm/AESGCMCC26XX.h> AESGCMCC26XX_Object aesgcmCC26XXObjects[CC1310_LAUNCHXL_AESGCMCOUNT]; const AESGCMCC26XX_HWAttrs aesgcmCC26XXHWAttrs[CC1310_LAUNCHXL_AESGCMCOUNT] = { { .intPriority = ~0, } }; const AESGCM_Config AESGCM_config[CC1310_LAUNCHXL_AESGCMCOUNT] = { { .object = &aesgcmCC26XXObjects[CC1310_LAUNCHXL_AESGCM0], .hwAttrs = &aesgcmCC26XXHWAttrs[CC1310_LAUNCHXL_AESGCM0] }, }; const uint_least8_t AESGCM_count = CC1310_LAUNCHXL_AESGCMCOUNT; /* * =============================== AESCBC =============================== */ #include <ti/drivers/AESCBC.h> #include <ti/drivers/aescbc/AESCBCCC26XX.h> AESCBCCC26XX_Object aescbcCC26XXObjects[CC1310_LAUNCHXL_AESCBCCOUNT]; const AESCBCCC26XX_HWAttrs aescbcCC26XXHWAttrs[CC1310_LAUNCHXL_AESCBCCOUNT] = { { .intPriority = ~0, } }; const AESCBC_Config AESCBC_config[CC1310_LAUNCHXL_AESCBCCOUNT] = { { .object = &aescbcCC26XXObjects[CC1310_LAUNCHXL_AESCBC0], .hwAttrs = &aescbcCC26XXHWAttrs[CC1310_LAUNCHXL_AESCBC0] }, }; const uint_least8_t AESCBC_count = CC1310_LAUNCHXL_AESCBCCOUNT; /* * =============================== AESCTR =============================== */ #include <ti/drivers/AESCTR.h> #include <ti/drivers/aesctr/AESCTRCC26XX.h> AESCTRCC26XX_Object aesctrCC26XXObjects[CC1310_LAUNCHXL_AESCTRCOUNT]; const AESCTRCC26XX_HWAttrs aesctrCC26XXHWAttrs[CC1310_LAUNCHXL_AESCTRCOUNT] = { { .intPriority = ~0, } }; const AESCTR_Config AESCTR_config[CC1310_LAUNCHXL_AESCTRCOUNT] = { { .object = &aesctrCC26XXObjects[CC1310_LAUNCHXL_AESCTR0], .hwAttrs = &aesctrCC26XXHWAttrs[CC1310_LAUNCHXL_AESCTR0] }, }; const uint_least8_t AESCTR_count = CC1310_LAUNCHXL_AESCTRCOUNT; /* * =============================== AESECB =============================== */ #include <ti/drivers/AESECB.h> #include <ti/drivers/aesecb/AESECBCC26XX.h> AESECBCC26XX_Object aesecbCC26XXObjects[CC1310_LAUNCHXL_AESECBCOUNT]; const AESECBCC26XX_HWAttrs aesecbCC26XXHWAttrs[CC1310_LAUNCHXL_AESECBCOUNT] = { { .intPriority = ~0, } }; const AESECB_Config AESECB_config[CC1310_LAUNCHXL_AESECBCOUNT] = { { .object = &aesecbCC26XXObjects[CC1310_LAUNCHXL_AESECB0], .hwAttrs = &aesecbCC26XXHWAttrs[CC1310_LAUNCHXL_AESECB0] }, }; const uint_least8_t AESECB_count = CC1310_LAUNCHXL_AESECBCOUNT; /* * =============================== AESCTRDRBG =============================== */ #include <ti/drivers/AESCTRDRBG.h> #include <ti/drivers/aesctrdrbg/AESCTRDRBGXX.h> AESCTRDRBGXX_Object aesctrdrbgXXObjects[CC1310_LAUNCHXL_AESCTRDRBGCOUNT]; const AESCTRDRBGXX_HWAttrs aesctrdrbgXXHWAttrs[CC1310_LAUNCHXL_AESCTRDRBGCOUNT] = { { .aesctrIndex = CC1310_LAUNCHXL_AESCTR0, } }; const AESCTRDRBG_Config AESCTRDRBG_config[CC1310_LAUNCHXL_AESCTRDRBGCOUNT] = { { .object = &aesctrdrbgXXObjects[CC1310_LAUNCHXL_AESCTRDRBG0], .hwAttrs = &aesctrdrbgXXHWAttrs[CC1310_LAUNCHXL_AESCTRDRBG0] }, }; const uint_least8_t AESCTRDRBG_count = CC1310_LAUNCHXL_AESCTRDRBGCOUNT; /* * =============================== TRNG =============================== */ #include <ti/drivers/TRNG.h> #include <ti/drivers/trng/TRNGCC26XX.h> TRNGCC26XX_Object trngCC26XXObjects[CC1310_LAUNCHXL_TRNGCOUNT]; const TRNGCC26XX_HWAttrs trngCC26X2HWAttrs[CC1310_LAUNCHXL_TRNGCOUNT] = { { .intPriority = ~0, .swiPriority = 0, .samplesPerCycle = 240000, } }; const TRNG_Config TRNG_config[CC1310_LAUNCHXL_TRNGCOUNT] = { { .object = &trngCC26XXObjects[CC1310_LAUNCHXL_TRNG0], .hwAttrs = &trngCC26X2HWAttrs[CC1310_LAUNCHXL_TRNG0] }, }; const uint_least8_t TRNG_count = CC1310_LAUNCHXL_TRNGCOUNT; /* * =============================== Display =============================== */ #include <ti/display/Display.h> #include <ti/display/DisplayUart.h> #include <ti/display/DisplaySharp.h> #ifndef BOARD_DISPLAY_UART_STRBUF_SIZE #define BOARD_DISPLAY_UART_STRBUF_SIZE 128 #endif /* This value can be changed to 96 for use with the 430BOOST-SHARP96 BoosterPack. */ #define BOARD_DISPLAY_SHARP_SIZE 128 DisplayUart_Object displayUartObject; DisplaySharp_Object displaySharpObject; static char uartStringBuf[BOARD_DISPLAY_UART_STRBUF_SIZE]; static uint_least8_t sharpDisplayBuf[BOARD_DISPLAY_SHARP_SIZE * BOARD_DISPLAY_SHARP_SIZE / 8]; const DisplayUart_HWAttrs displayUartHWAttrs = { .uartIdx = CC1310_LAUNCHXL_UART0, .baudRate = 115200, .mutexTimeout = (unsigned int)(-1), .strBuf = uartStringBuf, .strBufLen = BOARD_DISPLAY_UART_STRBUF_SIZE, }; const DisplaySharp_HWAttrsV1 displaySharpHWattrs = { .spiIndex = CC1310_LAUNCHXL_SPI0, .csPin = CC1310_LAUNCHXL_GPIO_LCD_CS, .powerPin = CC1310_LAUNCHXL_GPIO_LCD_POWER, .enablePin = CC1310_LAUNCHXL_GPIO_LCD_ENABLE, .pixelWidth = BOARD_DISPLAY_SHARP_SIZE, .pixelHeight = BOARD_DISPLAY_SHARP_SIZE, .displayBuf = sharpDisplayBuf, }; #ifndef BOARD_DISPLAY_USE_UART #define BOARD_DISPLAY_USE_UART 1 #endif #ifndef BOARD_DISPLAY_USE_UART_ANSI #define BOARD_DISPLAY_USE_UART_ANSI 0 #endif #ifndef BOARD_DISPLAY_USE_LCD #define BOARD_DISPLAY_USE_LCD 0 #endif /* * This #if/#else is needed to workaround a problem with the * IAR compiler. The IAR compiler doesn't like the empty array * initialization. (IAR Error[Pe1345]) */ #if (BOARD_DISPLAY_USE_UART || BOARD_DISPLAY_USE_LCD) const Display_Config Display_config[] = { #if (BOARD_DISPLAY_USE_UART) { # if (BOARD_DISPLAY_USE_UART_ANSI) .fxnTablePtr = &DisplayUartAnsi_fxnTable, # else /* Default to minimal UART with no cursor placement */ .fxnTablePtr = &DisplayUartMin_fxnTable, # endif .object = &displayUartObject, .hwAttrs = &displayUartHWAttrs, }, #endif #if (BOARD_DISPLAY_USE_LCD) { .fxnTablePtr = &DisplaySharp_fxnTable, .object = &displaySharpObject, .hwAttrs = &displaySharpHWattrs }, #endif }; const uint_least8_t Display_count = sizeof(Display_config) / sizeof(Display_Config); #else const Display_Config *Display_config = NULL; const uint_least8_t Display_count = 0; #endif /* (BOARD_DISPLAY_USE_UART || BOARD_DISPLAY_USE_LCD) */ /* * =============================== GPIO =============================== */ #include <ti/drivers/GPIO.h> #include <ti/drivers/gpio/GPIOCC26XX.h> /* * Array of Pin configurations * NOTE: The order of the pin configurations must coincide with what was * defined in CC1310_LAUNCHXL.h * NOTE: Pins not used for interrupts should be placed at the end of the * array. Callback entries can be omitted from callbacks array to * reduce memory usage. */ GPIO_PinConfig gpioPinConfigs[] = { /* Input pins */ GPIOCC26XX_DIO_13 | GPIO_DO_NOT_CONFIG, /* Button 0 */ GPIOCC26XX_DIO_14 | GPIO_DO_NOT_CONFIG, /* Button 1 */ GPIOCC26XX_DIO_15 | GPIO_DO_NOT_CONFIG, /* CC1310_LAUNCHXL_SPI_MASTER_READY */ GPIOCC26XX_DIO_21 | GPIO_DO_NOT_CONFIG, /* CC1310_LAUNCHXL_SPI_SLAVE_READY */ /* Output pins */ GPIOCC26XX_DIO_07 | GPIO_DO_NOT_CONFIG, /* Green LED */ GPIOCC26XX_DIO_06 | GPIO_DO_NOT_CONFIG, /* Red LED */ GPIOCC26XX_DIO_30 | GPIO_DO_NOT_CONFIG, /* TMP116_EN */ /* SPI Flash CSN */ GPIOCC26XX_DIO_20 | GPIO_DO_NOT_CONFIG, /* SD CS */ GPIOCC26XX_DIO_21 | GPIO_DO_NOT_CONFIG, /* Sharp Display - GPIO configurations will be done in the Display files */ GPIOCC26XX_DIO_24 | GPIO_DO_NOT_CONFIG, /* SPI chip select */ GPIOCC26XX_DIO_22 | GPIO_DO_NOT_CONFIG, /* LCD power control */ GPIOCC26XX_DIO_23 | GPIO_DO_NOT_CONFIG, /*LCD enable */ }; /* * Array of callback function pointers * NOTE: The order of the pin configurations must coincide with what was * defined in CC1310_LAUNCH.h * NOTE: Pins not used for interrupts can be omitted from callbacks array to * reduce memory usage (if placed at end of gpioPinConfigs array). */ GPIO_CallbackFxn gpioCallbackFunctions[] = { NULL, /* Button 0 */ NULL, /* Button 1 */ NULL, /* CC1310_LAUNCHXL_SPI_MASTER_READY */ NULL, /* CC1310_LAUNCHXL_SPI_SLAVE_READY */ }; const GPIOCC26XX_Config GPIOCC26XX_config = { .pinConfigs = (GPIO_PinConfig *)gpioPinConfigs, .callbacks = (GPIO_CallbackFxn *)gpioCallbackFunctions, .numberOfPinConfigs = CC1310_LAUNCHXL_GPIOCOUNT, .numberOfCallbacks = sizeof(gpioCallbackFunctions)/sizeof(GPIO_CallbackFxn), .intPriority = (~0) }; /* * =============================== GPTimer =============================== * Remove unused entries to reduce flash usage both in Board.c and Board.h */ #include <ti/drivers/timer/GPTimerCC26XX.h> GPTimerCC26XX_Object gptimerCC26XXObjects[CC1310_LAUNCHXL_GPTIMERCOUNT]; const GPTimerCC26XX_HWAttrs gptimerCC26xxHWAttrs[CC1310_LAUNCHXL_GPTIMERPARTSCOUNT] = { { .baseAddr = GPT0_BASE, .intNum = INT_GPT0A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT0, .pinMux = GPT_PIN_0A, }, { .baseAddr = GPT0_BASE, .intNum = INT_GPT0B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT0, .pinMux = GPT_PIN_0B, }, { .baseAddr = GPT1_BASE, .intNum = INT_GPT1A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT1, .pinMux = GPT_PIN_1A, }, { .baseAddr = GPT1_BASE, .intNum = INT_GPT1B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT1, .pinMux = GPT_PIN_1B, }, { .baseAddr = GPT2_BASE, .intNum = INT_GPT2A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT2, .pinMux = GPT_PIN_2A, }, { .baseAddr = GPT2_BASE, .intNum = INT_GPT2B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT2, .pinMux = GPT_PIN_2B, }, { .baseAddr = GPT3_BASE, .intNum = INT_GPT3A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT3, .pinMux = GPT_PIN_3A, }, { .baseAddr = GPT3_BASE, .intNum = INT_GPT3B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT3, .pinMux = GPT_PIN_3B, }, }; const GPTimerCC26XX_Config GPTimerCC26XX_config[CC1310_LAUNCHXL_GPTIMERPARTSCOUNT] = { { &gptimerCC26XXObjects[CC1310_LAUNCHXL_GPTIMER0], &gptimerCC26xxHWAttrs[CC1310_LAUNCHXL_GPTIMER0A], GPT_A }, { &gptimerCC26XXObjects[CC1310_LAUNCHXL_GPTIMER0], &gptimerCC26xxHWAttrs[CC1310_LAUNCHXL_GPTIMER0B], GPT_B }, { &gptimerCC26XXObjects[CC1310_LAUNCHXL_GPTIMER1], &gptimerCC26xxHWAttrs[CC1310_LAUNCHXL_GPTIMER1A], GPT_A }, { &gptimerCC26XXObjects[CC1310_LAUNCHXL_GPTIMER1], &gptimerCC26xxHWAttrs[CC1310_LAUNCHXL_GPTIMER1B], GPT_B }, { &gptimerCC26XXObjects[CC1310_LAUNCHXL_GPTIMER2], &gptimerCC26xxHWAttrs[CC1310_LAUNCHXL_GPTIMER2A], GPT_A }, { &gptimerCC26XXObjects[CC1310_LAUNCHXL_GPTIMER2], &gptimerCC26xxHWAttrs[CC1310_LAUNCHXL_GPTIMER2B], GPT_B }, { &gptimerCC26XXObjects[CC1310_LAUNCHXL_GPTIMER3], &gptimerCC26xxHWAttrs[CC1310_LAUNCHXL_GPTIMER3A], GPT_A }, { &gptimerCC26XXObjects[CC1310_LAUNCHXL_GPTIMER3], &gptimerCC26xxHWAttrs[CC1310_LAUNCHXL_GPTIMER3B], GPT_B }, }; /* * =============================== I2C =============================== */ #include <ti/drivers/I2C.h> #include <ti/drivers/i2c/I2CCC26XX.h> I2CCC26XX_Object i2cCC26xxObjects[CC1310_LAUNCHXL_I2CCOUNT]; const I2CCC26XX_HWAttrsV1 i2cCC26xxHWAttrs[CC1310_LAUNCHXL_I2CCOUNT] = { { .baseAddr = I2C0_BASE, .powerMngrId = PowerCC26XX_PERIPH_I2C0, .intNum = INT_I2C_IRQ, .intPriority = ~0, .swiPriority = 0, .sdaPin = CC1310_LAUNCHXL_I2C0_SDA0, .sclPin = CC1310_LAUNCHXL_I2C0_SCL0, } }; const I2C_Config I2C_config[CC1310_LAUNCHXL_I2CCOUNT] = { { .fxnTablePtr = &I2CCC26XX_fxnTable, .object = &i2cCC26xxObjects[CC1310_LAUNCHXL_I2C0], .hwAttrs = &i2cCC26xxHWAttrs[CC1310_LAUNCHXL_I2C0] } }; const uint_least8_t I2C_count = CC1310_LAUNCHXL_I2CCOUNT; /* * =============================== I2S =============================== */ #include <ti/drivers/I2S.h> #include <ti/drivers/i2s/I2SCC26XX.h> I2SCC26XX_Object i2sCC26XXObjects[CC1310_LAUNCHXL_I2SCOUNT]; const I2SCC26XX_HWAttrs i2sCC26XXHWAttrs[CC1310_LAUNCHXL_I2SCOUNT] = { { .pinSD1 = CC1310_LAUNCHXL_I2S_ADI, .pinSD0 = CC1310_LAUNCHXL_I2S_ADO, .pinSCK = CC1310_LAUNCHXL_I2S_BCLK, .pinMCLK = CC1310_LAUNCHXL_I2S_MCLK, .pinWS = CC1310_LAUNCHXL_I2S_WCLK, .intPriority = ~0, } }; const I2S_Config I2S_config[CC1310_LAUNCHXL_I2SCOUNT] = { { .object = &i2sCC26XXObjects[CC1310_LAUNCHXL_I2S0], .hwAttrs = &i2sCC26XXHWAttrs[CC1310_LAUNCHXL_I2S0] }, }; const uint_least8_t I2S_count = CC1310_LAUNCHXL_I2SCOUNT; /* * =============================== NVS =============================== */ #include <ti/drivers/NVS.h> #include <ti/drivers/nvs/NVSSPI25X.h> #include <ti/drivers/nvs/NVSCC26XX.h> #define NVS_REGIONS_BASE 0x1A000 #define SECTORSIZE 0x1000 #define REGIONSIZE (SECTORSIZE * 4) #ifndef Board_EXCLUDE_NVS_INTERNAL_FLASH /* * Reserve flash sectors for NVS driver use by placing an uninitialized byte * array at the desired flash address. */ #if defined(__TI_COMPILER_VERSION__) /* * Place uninitialized array at NVS_REGIONS_BASE */ #pragma LOCATION(flashBuf, NVS_REGIONS_BASE); #pragma NOINIT(flashBuf); static char flashBuf[REGIONSIZE]; #elif defined(__IAR_SYSTEMS_ICC__) /* * Place uninitialized array at NVS_REGIONS_BASE */ static __no_init char flashBuf[REGIONSIZE] @ NVS_REGIONS_BASE; #elif defined(__GNUC__) /* * Place the flash buffers in the .nvs section created in the gcc linker file. * The .nvs section enforces alignment on a sector boundary but may * be placed anywhere in flash memory. If desired the .nvs section can be set * to a fixed address by changing the following in the gcc linker file: * * .nvs (FIXED_FLASH_ADDR) (NOLOAD) : AT (FIXED_FLASH_ADDR) { * *(.nvs) * } > REGION_TEXT */ __attribute__ ((section (".nvs"))) static char flashBuf[REGIONSIZE]; #endif /* Allocate objects for NVS Internal Regions */ NVSCC26XX_Object nvsCC26xxObjects[1]; /* Hardware attributes for NVS Internal Regions */ const NVSCC26XX_HWAttrs nvsCC26xxHWAttrs[1] = { { .regionBase = (void *)flashBuf, .regionSize = REGIONSIZE, }, }; #endif /* Board_EXCLUDE_NVS_INTERNAL_FLASH */ #ifndef Board_EXCLUDE_NVS_EXTERNAL_FLASH #define SPISECTORSIZE 0x1000 #define SPIREGIONSIZE (SPISECTORSIZE * 32) #define VERIFYBUFSIZE 64 static uint8_t verifyBuf[VERIFYBUFSIZE]; /* Allocate objects for NVS External Regions */ NVSSPI25X_Object nvsSPI25XObjects[1]; /* Hardware attributes for NVS External Regions */ const NVSSPI25X_HWAttrs nvsSPI25XHWAttrs[1] = { { .regionBaseOffset = 0, .regionSize = SPIREGIONSIZE, .sectorSize = SPISECTORSIZE, .verifyBuf = verifyBuf, .verifyBufSize = VERIFYBUFSIZE, .spiHandle = NULL, .spiIndex = 0, .spiBitRate = 4000000, .spiCsnGpioIndex = CC1310_LAUNCHXL_GPIO_SPI_FLASH_CS, .statusPollDelayUs = 100, }, }; #endif /* Board_EXCLUDE_NVS_EXTERNAL_FLASH */ /* NVS Region index 0 and 1 refer to NVS and NVS SPI respectively */ const NVS_Config NVS_config[CC1310_LAUNCHXL_NVSCOUNT] = { #ifndef Board_EXCLUDE_NVS_INTERNAL_FLASH { .fxnTablePtr = &NVSCC26XX_fxnTable, .object = &nvsCC26xxObjects[0], .hwAttrs = &nvsCC26xxHWAttrs[0], }, #endif #ifndef Board_EXCLUDE_NVS_EXTERNAL_FLASH { .fxnTablePtr = &NVSSPI25X_fxnTable, .object = &nvsSPI25XObjects[0], .hwAttrs = &nvsSPI25XHWAttrs[0], }, #endif }; const uint_least8_t NVS_count = CC1310_LAUNCHXL_NVSCOUNT; /* * =============================== PIN =============================== */ #include <ti/drivers/PIN.h> #include <ti/drivers/pin/PINCC26XX.h> const PIN_Config BoardGpioInitTable[] = { CC1310_LAUNCHXL_PIN_RLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX, /* LED initially off */ CC1310_LAUNCHXL_PIN_GLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX, /* LED initially off */ CC1310_LAUNCHXL_PIN_BTN1 | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_BOTHEDGES | PIN_HYSTERESIS, /* Button is active low */ CC1310_LAUNCHXL_PIN_BTN2 | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_BOTHEDGES | PIN_HYSTERESIS, /* Button is active low */ CC1310_LAUNCHXL_SPI_FLASH_CS | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MIN, /* External flash chip select */ CC1310_LAUNCHXL_UART_RX | PIN_INPUT_EN | PIN_PULLDOWN, /* UART RX via debugger back channel */ CC1310_LAUNCHXL_UART_TX | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL, /* UART TX via debugger back channel */ CC1310_LAUNCHXL_SPI0_MOSI | PIN_INPUT_EN | PIN_PULLDOWN, /* SPI master out - slave in */ CC1310_LAUNCHXL_SPI0_MISO | PIN_INPUT_EN | PIN_PULLDOWN, /* SPI master in - slave out */ CC1310_LAUNCHXL_SPI0_CLK | PIN_INPUT_EN | PIN_PULLDOWN, /* SPI clock */ PIN_TERMINATE }; const PINCC26XX_HWAttrs PINCC26XX_hwAttrs = { .intPriority = ~0, .swiPriority = 0 }; /* * =============================== Power =============================== */ #include <ti/drivers/Power.h> #include <ti/drivers/power/PowerCC26XX.h> const PowerCC26XX_Config PowerCC26XX_config = { .policyInitFxn = NULL, .policyFxn = &PowerCC26XX_standbyPolicy, .calibrateFxn = &PowerCC26XX_calibrate, .enablePolicy = true, .calibrateRCOSC_LF = true, .calibrateRCOSC_HF = true, }; /* * =============================== PWM =============================== * Remove unused entries to reduce flash usage both in Board.c and Board.h */ #include <ti/drivers/PWM.h> #include <ti/drivers/pwm/PWMTimerCC26XX.h> PWMTimerCC26XX_Object pwmtimerCC26xxObjects[CC1310_LAUNCHXL_PWMCOUNT]; const PWMTimerCC26XX_HwAttrs pwmtimerCC26xxHWAttrs[CC1310_LAUNCHXL_PWMCOUNT] = { { .pwmPin = CC1310_LAUNCHXL_PWMPIN0, .gpTimerUnit = CC1310_LAUNCHXL_GPTIMER0A }, { .pwmPin = CC1310_LAUNCHXL_PWMPIN1, .gpTimerUnit = CC1310_LAUNCHXL_GPTIMER0B }, { .pwmPin = CC1310_LAUNCHXL_PWMPIN2, .gpTimerUnit = CC1310_LAUNCHXL_GPTIMER1A }, { .pwmPin = CC1310_LAUNCHXL_PWMPIN3, .gpTimerUnit = CC1310_LAUNCHXL_GPTIMER1B }, { .pwmPin = CC1310_LAUNCHXL_PWMPIN4, .gpTimerUnit = CC1310_LAUNCHXL_GPTIMER2A }, { .pwmPin = CC1310_LAUNCHXL_PWMPIN5, .gpTimerUnit = CC1310_LAUNCHXL_GPTIMER2B }, { .pwmPin = CC1310_LAUNCHXL_PWMPIN6, .gpTimerUnit = CC1310_LAUNCHXL_GPTIMER3A }, { .pwmPin = CC1310_LAUNCHXL_PWMPIN7, .gpTimerUnit = CC1310_LAUNCHXL_GPTIMER3B }, }; const PWM_Config PWM_config[CC1310_LAUNCHXL_PWMCOUNT] = { { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC1310_LAUNCHXL_PWM0], &pwmtimerCC26xxHWAttrs[CC1310_LAUNCHXL_PWM0] }, { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC1310_LAUNCHXL_PWM1], &pwmtimerCC26xxHWAttrs[CC1310_LAUNCHXL_PWM1] }, { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC1310_LAUNCHXL_PWM2], &pwmtimerCC26xxHWAttrs[CC1310_LAUNCHXL_PWM2] }, { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC1310_LAUNCHXL_PWM3], &pwmtimerCC26xxHWAttrs[CC1310_LAUNCHXL_PWM3] }, { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC1310_LAUNCHXL_PWM4], &pwmtimerCC26xxHWAttrs[CC1310_LAUNCHXL_PWM4] }, { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC1310_LAUNCHXL_PWM5], &pwmtimerCC26xxHWAttrs[CC1310_LAUNCHXL_PWM5] }, { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC1310_LAUNCHXL_PWM6], &pwmtimerCC26xxHWAttrs[CC1310_LAUNCHXL_PWM6] }, { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC1310_LAUNCHXL_PWM7], &pwmtimerCC26xxHWAttrs[CC1310_LAUNCHXL_PWM7] }, }; const uint_least8_t PWM_count = CC1310_LAUNCHXL_PWMCOUNT; /* * =============================== RF Driver =============================== */ #include <ti/drivers/rf/RF.h> const RFCC26XX_HWAttrsV2 RFCC26XX_hwAttrs = { .hwiPriority = ~0, /* Lowest HWI priority */ .swiPriority = 0, /* Lowest SWI priority */ .xoscHfAlwaysNeeded = true, /* Keep XOSC dependency while in standby */ .globalCallback = NULL, /* No board specific callback */ .globalEventMask = 0 /* No events subscribed to */ }; /* * =============================== SD =============================== */ #include <ti/drivers/SD.h> #include <ti/drivers/sd/SDSPI.h> SDSPI_Object sdspiObjects[CC1310_LAUNCHXL_SDCOUNT]; const SDSPI_HWAttrs sdspiHWAttrs[CC1310_LAUNCHXL_SDCOUNT] = { { .spiIndex = CC1310_LAUNCHXL_SPI0, .spiCsGpioIndex = CC1310_LAUNCHXL_SDSPI_CS } }; const SD_Config SD_config[CC1310_LAUNCHXL_SDCOUNT] = { { .fxnTablePtr = &SDSPI_fxnTable, .object = &sdspiObjects[CC1310_LAUNCHXL_SDSPI0], .hwAttrs = &sdspiHWAttrs[CC1310_LAUNCHXL_SDSPI0] }, }; const uint_least8_t SD_count = CC1310_LAUNCHXL_SDCOUNT; /* * =============================== SPI DMA =============================== */ #include <ti/drivers/SPI.h> #include <ti/drivers/spi/SPICC26XXDMA.h> SPICC26XXDMA_Object spiCC26XXDMAObjects[CC1310_LAUNCHXL_SPICOUNT]; /* * NOTE: The SPI instances below can be used by the SD driver to communicate * with a SD card via SPI. The 'defaultTxBufValue' fields below are set to 0xFF * to satisfy the SDSPI driver requirement. */ const SPICC26XXDMA_HWAttrsV1 spiCC26XXDMAHWAttrs[CC1310_LAUNCHXL_SPICOUNT] = { { .baseAddr = SSI0_BASE, .intNum = INT_SSI0_COMB, .intPriority = ~0, .swiPriority = 0, .powerMngrId = PowerCC26XX_PERIPH_SSI0, .defaultTxBufValue = 0xFF, .rxChannelBitMask = 1<<UDMA_CHAN_SSI0_RX, .txChannelBitMask = 1<<UDMA_CHAN_SSI0_TX, .mosiPin = CC1310_LAUNCHXL_SPI0_MOSI, .misoPin = CC1310_LAUNCHXL_SPI0_MISO, .clkPin = CC1310_LAUNCHXL_SPI0_CLK, .csnPin = CC1310_LAUNCHXL_SPI0_CSN, .minDmaTransferSize = 10 }, { .baseAddr = SSI1_BASE, .intNum = INT_SSI1_COMB, .intPriority = ~0, .swiPriority = 0, .powerMngrId = PowerCC26XX_PERIPH_SSI1, .defaultTxBufValue = 0xFF, .rxChannelBitMask = 1<<UDMA_CHAN_SSI1_RX, .txChannelBitMask = 1<<UDMA_CHAN_SSI1_TX, .mosiPin = CC1310_LAUNCHXL_SPI1_MOSI, .misoPin = CC1310_LAUNCHXL_SPI1_MISO, .clkPin = CC1310_LAUNCHXL_SPI1_CLK, .csnPin = CC1310_LAUNCHXL_SPI1_CSN, .minDmaTransferSize = 10 } }; const SPI_Config SPI_config[CC1310_LAUNCHXL_SPICOUNT] = { { .fxnTablePtr = &SPICC26XXDMA_fxnTable, .object = &spiCC26XXDMAObjects[CC1310_LAUNCHXL_SPI0], .hwAttrs = &spiCC26XXDMAHWAttrs[CC1310_LAUNCHXL_SPI0] }, { .fxnTablePtr = &SPICC26XXDMA_fxnTable, .object = &spiCC26XXDMAObjects[CC1310_LAUNCHXL_SPI1], .hwAttrs = &spiCC26XXDMAHWAttrs[CC1310_LAUNCHXL_SPI1] }, }; const uint_least8_t SPI_count = CC1310_LAUNCHXL_SPICOUNT; /* * =============================== UART =============================== */ #include <ti/drivers/UART.h> #include <ti/drivers/uart/UARTCC26XX.h> UARTCC26XX_Object uartCC26XXObjects[CC1310_LAUNCHXL_UARTCOUNT]; uint8_t uartCC26XXRingBuffer[CC1310_LAUNCHXL_UARTCOUNT][32]; const UARTCC26XX_HWAttrsV2 uartCC26XXHWAttrs[CC1310_LAUNCHXL_UARTCOUNT] = { { .baseAddr = UART0_BASE, .powerMngrId = PowerCC26XX_PERIPH_UART0, .intNum = INT_UART0_COMB, .intPriority = ~0, .swiPriority = 0, .txPin = CC1310_LAUNCHXL_UART_TX, .rxPin = CC1310_LAUNCHXL_UART_RX, .ctsPin = PIN_UNASSIGNED, .rtsPin = PIN_UNASSIGNED, .ringBufPtr = uartCC26XXRingBuffer[CC1310_LAUNCHXL_UART0], .ringBufSize = sizeof(uartCC26XXRingBuffer[CC1310_LAUNCHXL_UART0]), .txIntFifoThr = UARTCC26XX_FIFO_THRESHOLD_1_8, .rxIntFifoThr = UARTCC26XX_FIFO_THRESHOLD_4_8, .errorFxn = NULL } }; const UART_Config UART_config[CC1310_LAUNCHXL_UARTCOUNT] = { { .fxnTablePtr = &UARTCC26XX_fxnTable, .object = &uartCC26XXObjects[CC1310_LAUNCHXL_UART0], .hwAttrs = &uartCC26XXHWAttrs[CC1310_LAUNCHXL_UART0] }, }; const uint_least8_t UART_count = CC1310_LAUNCHXL_UARTCOUNT; /* * =============================== UDMA =============================== */ #include <ti/drivers/dma/UDMACC26XX.h> UDMACC26XX_Object udmaObjects[CC1310_LAUNCHXL_UDMACOUNT]; const UDMACC26XX_HWAttrs udmaHWAttrs[CC1310_LAUNCHXL_UDMACOUNT] = { { .baseAddr = UDMA0_BASE, .powerMngrId = PowerCC26XX_PERIPH_UDMA, .intNum = INT_DMA_ERR, .intPriority = ~0 } }; const UDMACC26XX_Config UDMACC26XX_config[CC1310_LAUNCHXL_UDMACOUNT] = { { .object = &udmaObjects[CC1310_LAUNCHXL_UDMA0], .hwAttrs = &udmaHWAttrs[CC1310_LAUNCHXL_UDMA0] }, }; /* * =============================== Watchdog =============================== */ #include <ti/drivers/Watchdog.h> #include <ti/drivers/watchdog/WatchdogCC26XX.h> WatchdogCC26XX_Object watchdogCC26XXObjects[CC1310_LAUNCHXL_WATCHDOGCOUNT]; const WatchdogCC26XX_HWAttrs watchdogCC26XXHWAttrs[CC1310_LAUNCHXL_WATCHDOGCOUNT] = { { .baseAddr = WDT_BASE, .reloadValue = 1000 /* Reload value in milliseconds */ }, }; const Watchdog_Config Watchdog_config[CC1310_LAUNCHXL_WATCHDOGCOUNT] = { { .fxnTablePtr = &WatchdogCC26XX_fxnTable, .object = &watchdogCC26XXObjects[CC1310_LAUNCHXL_WATCHDOG0], .hwAttrs = &watchdogCC26XXHWAttrs[CC1310_LAUNCHXL_WATCHDOG0] }, }; const uint_least8_t Watchdog_count = CC1310_LAUNCHXL_WATCHDOGCOUNT; /* * Board-specific initialization function to disable external flash. * This function is defined in the file CC1310_LAUNCHXL_fxns.c */ extern void Board_initHook(void); /* * ======== CC1310_LAUNCHXL_initGeneral ======== */ void CC1310_LAUNCHXL_initGeneral(void) { Power_init(); if (PIN_init(BoardGpioInitTable) != PIN_SUCCESS) { /* Error with PIN_init */ while (1); } /* Perform board-specific initialization */ Board_initHook(); } /* * ======== Board_init ======== */ void Board_init(void) { CC1310_LAUNCHXL_initGeneral(); }
