I have an LSM6DSM IMU connected to a CC1310 via SPI. I recently updated to the latest SDK and the interrupts for this
device are no longer working. Is there something changed in the interrupt configuration API that I need to change when
updating to SDK 3_20_00_23?
My driver for the device is attached:
/* * lsm6dsm.c * * Created on: Jul 26, 2018 * Author: Victor Valencia * Copyright: Willowview Consulting 2018 */ #include <string.h> #include <stdint.h> #include <stdio.h> #include <ti/drivers/GPIO.h> #include <ti/drivers/SPI.h> #include <ti/drivers/rf/RF.h> #include <ti/drivers/PIN.h> #include <ti/drivers/pin/PINCC26XX.h> #include <ti/sysbios/knl/task.h> #include <ti/sysbios/knl/event.h> #include "board.h" #include "swdefs.h" #include "lsm6dsm_reg.h" #include "lsm6dsm.h" #include "bolusProto.h" #include "wvcSpi.h" #include "timeFuncs.h" #include "trace.h" #include "stats.h" #define ACCEL_DEBUG(fmt, ...) \ do { if (_ACCEL_DEBUG == 1) printf(fmt, ##__VA_ARGS__); \ if ((_ACCEL_DEBUG == 1) && (_TRACE_ENABLED == 1)) {snprintf(tracePrintBuf, sizeof(tracePrintBuf), fmt, ##__VA_ARGS__); \ trace(tracePrintBuf); } \ } while (0) axis3bit16_t data_raw_acceleration; axis1bit16_t data_raw_temperature; uint8_t whoamI; uint8_t rst; lsm6dsm_ctx_t accel_ctx; accelConfig lsm6dsmDefaultConfiguration = { .accelDataRate = 1, // 12.5 hz .gyroDataRate = 0, .accelScale = LSM6DSM_2g, .gyroScale = 0, .accelFilter = LSM6DSM_XL_ANA_BW_400Hz, .gyroFilteringChain = 0, .fifoThreshold = FIFO_THRESHOLD, .accelDecimation = LSM6DSM_FIFO_XL_NO_DEC, }; uint16_t getWordsInFifo(void); int16_t accelClearFifo(void); /* * For debug... */ void printAccelConfig(void) { uint8_t idx; uint8_t regVal; for (idx = 0; idx < 0x75; idx++) { lsm6dsm_read_reg(&accel_ctx, idx, ®Val, 1); printf("[0x%02.02x] = 0x%02.02x\n", idx, regVal); } } RET_CODE accelLoadConfig(accelConfig *cfg) { /* * Check device ID. */ whoamI = 0; lsm6dsm_device_id_get(&accel_ctx, &whoamI); if ( whoamI != LSM6DSM_ID ) return(RET_CODE_ERROR); /* device not found */ /* * Restore default configuration. */ lsm6dsm_reset_set(&accel_ctx, PROPERTY_ENABLE); do { lsm6dsm_reset_get(&accel_ctx, &rst); } while (rst); /* * id samples that are taken prior to settling time */ lsm6dsm_filter_settling_mask_set(&accel_ctx, 1); /* * Set Output Data Rate. */ lsm6dsm_xl_data_rate_set(&accel_ctx, (lsm6dsm_odr_xl_t)cfg->accelDataRate); /* * Set low-power mode */ lsm6dsm_xl_power_mode_set(&accel_ctx, (lsm6dsm_xl_hm_mode_t)LSM6DSM_XL_NORMAL); /* * Power down gyro */ lsm6dsm_gy_data_rate_set(&accel_ctx, LSM6DSM_GY_ODR_OFF); /* * Set fifo interrupt threshold */ lsm6dsm_fifo_watermark_set(&accel_ctx, cfg->fifoThreshold); /* * Set decimation */ lsm6dsm_fifo_xl_batch_set(&accel_ctx, (lsm6dsm_dec_fifo_xl_t)cfg->accelDecimation); /* * Set fifo mode */ lsm6dsm_fifo_mode_set(&accel_ctx, LSM6DSM_FIFO_MODE); /* * Set to stop on watermark */ lsm6dsm_fifo_stop_on_wtm_set(&accel_ctx, PROPERTY_ENABLE); /* * Set fifo data rate */ lsm6dsm_fifo_data_rate_set(&accel_ctx, LSM6DSM_FIFO_12Hz5); /* * Enable Block Data Update. Required since we're using * the FIFO. */ lsm6dsm_block_data_update_set(&accel_ctx, PROPERTY_ENABLE); /* * Enable auto-increment. Required since we're using * the FIFO. */ lsm6dsm_auto_increment_set(&accel_ctx, PROPERTY_ENABLE); /* * We are not providing an external sampling trigger. */ lsm6dsm_den_mode_set(&accel_ctx, LSM6DSM_DEN_DISABLE); /* * Set interrupt output to active low */ lsm6dsm_pin_polarity_set(&accel_ctx, LSM6DSM_ACTIVE_LOW); /* * Set interrupt routing */ lsm6dsm_int1_route_t intRouting = { .int1_full_flag = 1, }; lsm6dsm_pin_int1_route_set(&accel_ctx, (lsm6dsm_int1_route_t)intRouting); /* * Set the interrupt mode */ lsm6dsm_data_ready_mode_set(&accel_ctx, LSM6DSM_DRDY_LATCHED); lsm6dsm_xl_data_rate_set(&accel_ctx, (lsm6dsm_odr_xl_t)cfg->accelDataRate); /* * Set full scale. */ lsm6dsm_xl_full_scale_set(&accel_ctx, (lsm6dsm_fs_xl_t)cfg->accelScale); /* * Configure filtering chain(No aux interface). */ /* * Accelerometer - analog filter. */ lsm6dsm_xl_filter_analog_set(&accel_ctx, (lsm6dsm_bw0_xl_t)cfg->accelFilter); /* * Accelerometer - LPF1 path ( LPF2 not used ). */ //lsm6dsm_xl_lp1_bandwidth_set(&accel_ctx, LSM6DSM_XL_LP1_ODR_DIV_4); /* * Accelerometer - LPF1 + LPF2 path. */ lsm6dsm_xl_lp2_bandwidth_set(&accel_ctx, (lsm6dsm_input_composite_t)cfg->accelBandwidth); /* * Accelerometer - High Pass / Slope path. */ //lsm6dsm_xl_reference_mode_set(&accel_ctx, PROPERTY_DISABLE); //lsm6dsm_xl_hp_bandwidth_set(&accel_ctx, LSM6DSM_XL_HP_ODR_DIV_100); return(RET_CODE_OK); } /* * Get number of 16-bit words remaining in the fifo */ uint16_t getWordsInFifo(void) { uint8_t tmp[2]; lsm6dsm_read_reg(&accel_ctx, LSM6DSM_FIFO_STATUS1, tmp, 2); return(tmp[0] | ((tmp[1] & 0x7) << 8)); } /* * In order to restart fifo after a read we must * change modes. */ void accelFifoRestart(void) { lsm6dsm_fifo_mode_set(&accel_ctx, LSM6DSM_BYPASS_MODE); lsm6dsm_fifo_mode_set(&accel_ctx, LSM6DSM_FIFO_MODE); } /* * Read in a loop until the fifo is empty */ int16_t accelClearFifo(void) { int16_t accelData[3]; int16_t count = 0; while(getWordsInFifo() != 0) { accelReadFifo(accelData); count++; } return(count); } /* * Interrupt handler for accelerometer fifo full. */ void accelInterrupt(uint8_t index) { updateStatsIncCounter(&(getStats()->accelInterrupts)); Event_post(mainThreadEvent, EVENT_ACCEL_DATA_READY); return; } /* * Kick off accelerometer interrupts */ void accelStart(void) { /* Enable interrupts */ GPIO_enableInt(4); accelFifoRestart(); return; } void accelStop(void) { /* Disable interrupts */ GPIO_disableInt(4); return; } void accelInit(void) { accel_ctx.write_reg = (lsm6dsm_write_ptr)spi_write; accel_ctx.read_reg = (lsm6dsm_read_ptr)spi_read; accel_ctx.handle = 0; /* * configure the device registers */ if (accelLoadConfig(&lsm6dsmDefaultConfiguration) != RET_CODE_OK) { ACCEL_DEBUG("Error initializing accelerometer\n"); return; } else { ACCEL_DEBUG("Accelerometer initialized.\n"); } /* * Clear fifo so that we * catch the first falling edge. */ int16_t numReads = accelClearFifo(); int16_t temperature = accelGetTemp(); lsm6dsm_reg_t reg; lsm6dsm_status_reg_get(&accel_ctx, ®.status_reg); /* config interrupt pin for falling-edge */ GPIO_setConfig(4, GPIO_CFG_IN_PU | GPIO_CFG_IN_INT_FALLING); /* install interrupt callback */ GPIO_setCallback(4, accelInterrupt); } /* * Read a single-byte register */ RET_CODE accelReadReg(uint8_t regIdx, uint8_t *value) { return(lsm6dsm_read_reg(&accel_ctx, regIdx, value, 1)); } /* * Snag the current accelerometer values */ RET_CODE accelReadAccelXYZ(int16_t *accelX, int16_t *accelY, int16_t *accelZ) { lsm6dsm_acceleration_raw_get(&accel_ctx, data_raw_acceleration.u8bit); *accelX = LSM6DSM_FROM_FS_2g_TO_mg(data_raw_acceleration.i16bit[0]); *accelY = LSM6DSM_FROM_FS_2g_TO_mg(data_raw_acceleration.i16bit[1]); *accelZ = LSM6DSM_FROM_FS_2g_TO_mg(data_raw_acceleration.i16bit[2]); return(RET_CODE_OK); } /* * Read the current accelerometer values from the fifo */ RET_CODE accelReadFifo(int16_t *buf) { int16_t tmpBuf[3]; lsm6dsm_fifo_raw_data_get(&accel_ctx, (uint8_t*)&tmpBuf[0], 2); buf[0] = LSM6DSM_FROM_FS_2g_TO_mg(tmpBuf[0]); lsm6dsm_fifo_raw_data_get(&accel_ctx, (uint8_t*)&tmpBuf[1], 2); buf[1] = LSM6DSM_FROM_FS_2g_TO_mg(tmpBuf[1]); lsm6dsm_fifo_raw_data_get(&accel_ctx, (uint8_t*)&tmpBuf[2], 2); buf[2] = LSM6DSM_FROM_FS_2g_TO_mg(tmpBuf[2]); return(RET_CODE_OK); } /* * Snag the temperature. It is not stored in the fifo. */ int16_t accelGetTemp(void) { lsm6dsm_temperature_raw_get(&accel_ctx, data_raw_temperature.u8bit); return(LSM6DSM_FROM_LSB_TO_degC( data_raw_temperature.i16bit )); }
The initialization function is named "accelInit()". After the initialization is complete the main routine calls "accelStart()". An interrupt
should be generated about every 52 seconds when the accelerometer FIFO is full.
Victor
