Hi TI Team,
Is it normal that when I use the Easylink_abort, I can still receive packets from Eeasylink.receiveAsync() command?
If yes, what commands should I use to cancel the Easylink.receiveAsync?
Jonathan
Hi TI Team,
Jonathan
Hi M-W,
That's weird but I got a return status of 0 (which I have inspected on enum that it is equivalent to success)
Jonathan
Hi M-W
Sorry for the late response. I was able to verify it because I was still able to receive packets even i have already executed Easylink_abort();
Hi Jonathan,
Can you share a project that has this error which I can test? I can't see any issues, I wonder if it could be that you happen to restart the RX right away? More context around the application you run is always helpful.
