Part Number: CC3220
With one customer I get the error SL_WLAN_DISCONNECT_ASSOC_TIMEOUT on our device using the cc3220, followed by a connection timeout.
The radius server reports the error: Supplicant stopped responding to ISE after sending it the first EAP-TLS message
With another device using the cc3200 and the exact same certificate set it's working fine.
And on our test setup the cc3220 works fine with a similar TLS connection.
Can you give me some clues as to when SL_WLAN_DISCONNECT_ASSOC_TIMEOUT is raised?
