I am trying to send certificate file for postman to http server using PUT/POST
In dynamic callback i am able to receive all certificate but my problem is i am getting total size of file how to find each file size ?
[Link local task] HTTP PUT Request [Link local task] characteristic is: filename [Provisioning task] detected device is CC3220SF [Link local task] Received OTA filename p, len = 3952 Payload - ----------------------------386565428615719092736900 Content-Disposition: form-data; name=""; filename="cacert.pem" Content-Type: application/x-x509-ca-cert alue":ø len-162 Next-recv - -----BEGIN CERTIFICATE----- MIICizCCAfQCCQC9wRaASarXVzANBgkqhkiG9w0BAQUFADCBiTELMAkGA1UEBhMC VVMxEzARBgNVBAgMCkNhbGlmb3JuaWExDzANBgNVBAcMBkdvbGV0YTELMAkGA1UE CgwCVEkxEzARBgNVBAsMCmR1bW15X3Jvb3QxEzARBgNVBAMMCmR1bW15X3Jvb3Qx HTAbBgkqhkiG9w0BCQEWDnJvb3RAZHVtbXkuY29tMB4XDTE3MTEyNzE4MDcwOFoX DTI3MTEyNTE4MDcwOFowgYkxCzAJBgNVBAYTAlVTMRMwEQYDVQQIDApDYWxpZm9y bmlhMQ8wDQYDVQQHDAZHb2xldGExCzAJBgNVBAoMAlRJMRMwEQYDVQQLDApkdW1t eV9yb290MRMwEQYDVQQDDApkdW1teV9yb290MR0wGwYJKoZIhvcNAQkBFg5yb290 QGR1bW15LmNvbTCBnzANBgkqhkiG9w0BAQEFAAOBjQAwgYkCgYEAttRn99pMw3no PZzoWjwRO1KMVFztsYHvC06Pct753DKtMn4Zc4F3YIfIDzPx80ZOkX2oMj2RHTKI 2hzXOp7qHGC8fnFPebguyESkXWtPLGzmt7vQfCNeLKAKclOtoKK6vs98mqtQjxZP H3V89cvdV6Lanzw2KhvHSYv+qiPzoc8CAwEAATANBgkqhkiG9w0BAQUFAAOBgQB+ osjP1mDGxcRN6ZtptXI6Ocq6mL7YusoOiBUmcnjqzBruotcPz+ofbSl58J3twEKG HdGDz1CTFEo6h5pgsaYDa66LjCnkInqfPI5+RcmwZ6sULNfNAPL4V40L+KnyP+hd U2JLkdWgnZAEsb1S5DZEsFzz+Eq/nWLslFdhbwWgZw== -----END CERTIFICATE----- ----------------------------386565428615719092736900 Content-Disposition: form-data; name=""; filename="caKey.pem" Content-Type: application/x-x509-ca-cert -----BEGIN ENCRYPTED PRIVATE KEY----- MIICxjBABgkqhkiG9w0BBQ0wMzAbBgkqhkiG9w0BBQwwDgQI09sSYjBiS9ICAggA MBQGCCqGSIb3DQMHBAjfwou8sMGkgwSCAoDixgKDU8PQJp8myoBHXdis814nFBnh Rkwz/XNyZYpyViOwS8KDxwRz0DQsRFJ82sSbp6JwQYE+nPqpHgNR4b4ZhwaTXdoO mX0S0p8aFPkBl6w3u93MKitZ [Link local task] sl_NetAppRecv payload=1364, flags=1 Next-recv - XvwCrUQdJSJ19tHrojYbzcMDP+nClXwti3QM1Nvu SnpvTS/VPiBRulJSvAaDtHP0kwt5WUwfEUUFstfhcz49k4NQfdUVaMpd2otT560 [Link local task] sl_NetAppRecv payload=104, flags=1 Next-recv - 7 xvvLybK+drGiOqaecMw4mWv/3iwmKL1ff873Ik8R/vDhbMqhEzb2fOjOjCuS2JRp NLPXMZwY5PjrbH8GxJjXqDsv32Ha5FL0IdSuOiIF9cy1NEb98uJzoE5rUKlL+T7q Vv7Vl5/afQ8ZwaLkpIivY/Bw7C8eCVSwBhSNchkxwzobUvkjwZ5GpdpRFNpQBtbe nr0mLu8BPllQZLgu1NaJvjAC3lWuRqZuMJZlxM3dGrbbVzWZ7kpbUJSiy+6bwii7 KBN1HbeC7VRDndR5clLhBHmnGVhRISO65OFc1esz641nYg43umk7Uy4kOdBZ81uU gsS5alKfMv7e9petLJn76FtNvUB8OvyVA3yzwC1Y5o7GNc4Je7gRJYUSRlhZxZIu n7U2Xtc8UKiuyyHgIXqp6+THg6j7K6y+pb9yE6dpA/d1kQGbRStiC2DPtLZY9HTA Ea4JkWh62wQxP3iqMCOKBPSuEGhPV7vZ2PEY6enT86on6vzq4uWUTpGrQoI0sBwC QPIyCBZexZzFeyFb05RIhVjSYm67EkdbTAWVtyPOaVh9iQcOv1AUxADh37PEkr8y opBpfkcL5qhv3xkbdcjSV3dOxjGFmglPdRvpsWrkur8zaGxjnWkDRYyM -----END ENCRYPTED PRIVATE KEY----- ----------------------------386565428615719092736900 Content-Disposition: form-data; name=""; filename="servercert.pem" Content-Type: application/x-x509-ca-cert -----BEGIN CERTIFICATE----- MIICkTCCAfoCCQCppMM/xH86ITANBgkqhkiG9w0BAQUFADCBiTELMAkGA1UEBhMC VVMxEzARBgNVBAgMCkNhbGlmb3JuaWExDzANBgNVBAcMBkdvbGV0YTELMAkGA1UE CgwCVEkxEzARBgNVBAsMCmR1bW15X3Jvb3QxEzARBgNVBAMMCmR1bW15X3Jvb3Qx HTAbBgkqhkiG9w0BCQEWDnJvb3RAZHVtbXkuY29tMB4XDTE3MTEyNzE4MTE1NFoX DTI3MTEyNTE4MTE1NFowgY8xCzAJBgNVBAYTAlVTMRMwEQYDVQQIDApDYWxpZm9y bmlhMQ8wDQYDVQQHDAZHb2xldGExCzAJBgNVBAoMAlRJMRUwEwYDVQQLDAxkdW1t eV9zZXJ2ZXIxFTATBgNVBAMMDGR1bW15X3NlcnZlcjEfMB0GCSqGSIb3DQEJARYQ c2VydmVyQGR1bW15LmNvbTCBnzANBgkqh [Link local task] sl_NetAppRecv payload=1364, flags=1 Next-recv - kiG9w0BAQEFAAOBjQAwgYkCgYEAz0EQ B30L687NYQj7NOMbf9O1gauVQSqc3NLdYhSiGQ8QnUvX28GXrABl63s1N49XPaze MoC/XX1 [Link local task] sl_NetAppRecv payload=104, flags=1 Next-recv - IZRplVFYnJNHGMt0koe2arWYpWqsUAvNJpZW8X5M3SCdxOW2v3aF/SO6B 1F+CSYdyeaxGwed1KyNXd48BfzvBzLGKA/SG7oUCAwEAATANBgkqhkiG9w0BAQUF AAOBgQAiZM4W81a8h5iGxjOoNgux3iqhJD8RvcewwXrloIpREbqqoZVGFL7xfKFo b7U+bTinyRHmjwcYbAzY74g3R+IdB9/2fSdP4sz2CgXcNGewn4FhGOb4G6lG8Eev I7WJ4t/HQGW7+SnA990ZYL/5l3d21UFTpAmFk9Co+oMtq6ONqg== -----END CERTIFICATE----- ----------------------------386565428615719092736900
1) How to find each file size ?
2) while sending end of this i am getting some junk data why (----------------------------386565428615719092736900) ?
3) can i send json data(mqtt config) application/son (To use the HTTP API processing built into the NWP, the request must be set as MIME type application/x-www-form-urlencoded as the content-type in the HTTP header - by Bryan Kahler) ?
Thank You
Vasu
