Part Number: 1
HI.
I have just learned about cc2530 using TIMAC, I want to ask to transmit and receive data, what part of it should I edit in the TIMAC example
Hi Hung,
Are you looking for something other than TIMAC 1.5.2.43299\Projects\mac\Sample and the Mac Sample Application - Software Design PDF? Select the “Secure” or “Secure-Banked” project from the IAR workspace to enable MAC_SECURITY services.
Ryan
You can filter by device address inside the MSA_AssociateRsp function called by the MAC_MLME_ASSOCIATE_IND case. You will need to read all documentation to learn more about modifying the 15.4-Stack application.
Ryan
I read it already.
I like to know how to conifgure the
1.Link Key
2.Master Key
3.Network Key
where can i find the link and master key?
i understand that coordinator can assign the trust center.
will you please throw some light on how to use the TIMAC regarding the security ?
Thanks and Regards
You are referring to Zigbee terms, most likely picked up from the Non-Volatile Memory section of the OSAL API document. You should not be concerned with these since you are using TIMAC.
Ryan
