Other Parts Discussed in Thread: Z-STACK, , Z-STACK-ARCHIVE, CC2652R, CC1352P, CC2538
Hi All,
I have a zigbee network with a coordinator, 20 routers (using zstack 3.0.1) and 5 end devices. The network is using many to one routing and source routing.
I am trying to understand some routing problems in the network.
For instance the end devices should send a report every 10 minutes to the coordinator, but the coordinator does not always receive them.
I tracked down the issue to routing failures reported by the routers by a "Network status: many to one route failure".
Attached you can find a sniffer trace of the situation, for example packet number 137820 is a report from the end device followed by a route failure.
Questions:
- What could cause this issue?
- Can someone explain to me why the route failure message contains as "network status destination address" the network address of the device sending the report?
