Other Parts Discussed in Thread: CC3200AUDBOOST
I have the launch pad MSP-EXP432P401R, CC2564MODA Bluetooth module and Code Composer Studio (CCS) v7.3.0. Also i downloaded the TI Dual-mode Bluetooth Stack for MSP432 MCUs.
I imported the SPPDemo on CCS based on User's Guide (swru453b) but i when build the project the compoling error are indicated. The consoles' output is:
**** Build of configuration Debug for project SPPDemo ****
"C:\\TI\\ccsv7\\utils\\bin\\gmake" -k all
gmake: *** No rule to make target 'C:/LEDGAT/workspace/Main.c', needed by 'Application/Main.obj'.
gmake: *** No rule to make target 'C:/LEDGAT/workspace/SPPDemo.c', needed by 'Application/SPPDemo.obj'.
gmake: *** No rule to make target 'C:/Bluetopia/btpskrnl/BTPSKRNL.c', needed by 'Bluetopia/btpskrnl/BTPSKRNL.obj'.
gmake: *** No rule to make target 'C:/Bluetopia/btpsvend/BTPSVEND.c', needed by 'Bluetopia/btpsvend/BTPSVEND.obj'.
gmake: *** No rule to make target 'C:/Bluetopia/btvs/BTVS.c', needed by 'Bluetopia/btvs/BTVS.obj'.
gmake: *** No rule to make target 'C:/Bluetopia/hcitrans/HCITRANS.c', needed by 'Bluetopia/hcitrans/HCITRANS.obj'.
gmake: *** No rule to make target 'C:/Platforms/MSP-EXP432P401R/CC3200AUDBOOST.c', needed by 'Platforms/MSP-EXP432P401R/CC3200AUDBOOST.obj'.
gmake: *** No rule to make target 'C:/Platforms/MSP-EXP432P401R/HAL.c', needed by 'Platforms/MSP-EXP432P401R/HAL.obj'.
gmake: *** No rule to make target 'C:/Platforms/MSP-EXP432P401R/ccs/msp432_startup_ccs.c', needed by 'Platforms/MSP-EXP432P401R/ccs/msp432_startup_ccs.obj'.
gmake: *** No rule to make target 'C:/Platforms/driverlib/cpu.c', needed by 'Platforms/driverlib/cpu.obj'.
gmake: *** No rule to make target 'C:/Platforms/driverlib/cs.c', needed by 'Platforms/driverlib/cs.obj'.
gmake: *** No rule to make target 'C:/Platforms/driverlib/flash.c', needed by 'Platforms/driverlib/flash.obj'.
gmake: *** No rule to make target 'C:/Platforms/driverlib/gpio.c', needed by 'Platforms/driverlib/gpio.obj'.
gmake: *** No rule to make target 'C:/Platforms/driverlib/i2c.c', needed by 'Platforms/driverlib/i2c.obj'.
gmake: *** No rule to make target 'C:/Platforms/driverlib/interrupt.c', needed by 'Platforms/driverlib/interrupt.obj'.
gmake: *** No rule to make target 'C:/Platforms/driverlib/pcm.c', needed by 'Platforms/driverlib/pcm.obj'.
gmake: *** No rule to make target 'C:/Platforms/driverlib/rtc_c.c', needed by 'Platforms/driverlib/rtc_c.obj'.
gmake: *** No rule to make target 'C:/Platforms/driverlib/sysctl.c', needed by 'Platforms/driverlib/sysctl.obj'.
gmake: *** No rule to make target 'C:/Platforms/driverlib/systick.c', needed by 'Platforms/driverlib/systick.obj'.
gmake: *** No rule to make target 'C:/Platforms/driverlib/uart.c', needed by 'Platforms/driverlib/uart.obj'.
gmake: *** No rule to make target 'C:/Platforms/driverlib/wdt_a.c', needed by 'Platforms/driverlib/wdt_a.obj'.
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
I can see that the project use "virtual folder" and i don´t know how to work it.
Thanks for your help
Alberto
