I've downloaded the heartrate example in the cc2650 launchpad and I'm getting the simulated values in the ble scanner application.
I've stored some numbers in a array and I want those numbers to be transmitted from cc2650 launchpad to ble application. I got to know in heartrate code, the value is getting transmitted from the heartratebpm variable. If I assign my array to the heartratebpm, the readings I'm getting is 252bpm which is not the number stored in my array.
How can I transmit data stored in a array and not the simulated heartrate measurement using the heartrate example. I've attached the code.
Thank you
Praveen Gonsalves
