Hello Team,
I am currently working with a customer wanting to use the CC2650MODA. Currently, they want to use an external power supply coming from an LDO at 1.8V with a +/- 2% tolerance.
In the datasheet, it calls out 1.8V as the minimum input voltage, however, I wanted to see if there is a tolerance to this value? We wouldn't expect the 1.8V source to go below 1.75V (worst case scenario), but would the CC2650MODA still operate correctly?
Javier Palomo
