I would like to use TimestampProvider but it needs a timer ID. What's a Timer ID? Do I have to configure the timers to run in periodic mode in order to use it? Thank you:)
Ken
Ken
Hi Kenneth,
You can use the systick timer which is always running if you're okay with a resolution of 1ms, otherwise you are gonna have to use a timer in periodic mode.
Klas
Thank you Klas,
I do need microsecond resolution. I couldn't figure out what to use for a timeid constant for the timestampProvider though?
Any suggestions would be appreciated:)
Ken
