I'm designing my custom board based on CC2650. I'm trying to solder the IC but either using hot air gun ( set to 220 degree) or solder iron after soldering when I plug the 3.3 volts power it gets burnt. I always check all the pins for short circuits and everything is okay. I just could solder one board the it shows the board design is okay. Do you have any idea what can cause this issue? After powering the zinc it uses 1 amp current.
Is the IC very sensitive to temperature?
Thanks.
