Hi Everyone
We are using the CC1190 as a front-end for one of our RF designs, We have a couple of questions regarding the configuration of the CC1190
1-. Its possible to bypass the receiving LNA? If it is possible how can We do it? The datasheet only says that "Digital control of LNA and PA by HGM pin"
2-. Which parameters We have to check in the datasheet in order order to calculate the following data:
TX antenna delivered power:
from transceiver -> front-end -> antenna
RX transceiver received power:
from antenna -> front-end -> transceiver
Thank you very much for your time!
