M MAR,
It is recommended to keep the SYNC word enabled as most of the timing inside the transceiver is based of the Sync word. That being said, on the CC1120 and CC1200 it is possible to disable the preamble and only transmit the Sync word, it is furthermore possible to set the packet length to 0 and disable the CRC generation.
I did that using SmartRF Studio and verified that the device transmitted the data using a spectrum analyzer. With the settings below the CC1200 only transmitted 11 bits of data per burst and those 11 bits where configurable by changing the values in the Sync word registers.
/TA
<?xml version="1.0" encoding="ISO-8859-1"?> <!DOCTYPE configuration SYSTEM "C:/Program Files (x86)/Texas Instruments/SmartRF Tools/SmartRF Studio 7/config/xml/configdata.dtd"[]> <dcpanelconfiguration> <Devicename>CC1200</Devicename> <Description>Saved configuration data</Description> <registersettings> <Register> <Name>AGC_CFG0</Name> <Value>0x87</Value> </Register> <Register> <Name>AGC_CFG1</Name> <Value>0x51</Value> </Register> <Register> <Name>AGC_CS_THR</Name> <Value>0xec</Value> </Register> <Register> <Name>AGC_REF</Name> <Value>0x20</Value> </Register> <Register> <Name>ASK_CFG</Name> <Value>0x3f</Value> </Register> <Register> <Name>CHAN_BW</Name> <Value>0xa6</Value> </Register> <Register> <Name>DCFILT_CFG</Name> <Value>0x5d</Value> </Register> <Register> <Name>DEVIATION_M</Name> <Value>0xd1</Value> </Register> <Register> <Name>FIFO_CFG</Name> <Value>0x00</Value> </Register> <Register> <Name>FREQ1</Name> <Value>0x80</Value> </Register> <Register> <Name>FREQ2</Name> <Value>0x5b</Value> </Register> <Register> <Name>FREQOFF_CFG</Name> <Value>0x22</Value> </Register> <Register> <Name>FS_CAL0</Name> <Value>0x0e</Value> </Register> <Register> <Name>FS_CAL1</Name> <Value>0x40</Value> </Register> <Register> <Name>FS_CFG</Name> <Value>0x12</Value> </Register> <Register> <Name>FS_DIG0</Name> <Value>0xaf</Value> </Register> <Register> <Name>FS_DIG1</Name> <Value>0x07</Value> </Register> <Register> <Name>FS_DIVTWO</Name> <Value>0x03</Value> </Register> <Register> <Name>FS_DSM0</Name> <Value>0x33</Value> </Register> <Register> <Name>FS_DVC0</Name> <Value>0x17</Value> </Register> <Register> <Name>FS_PFD</Name> <Value>0x00</Value> </Register> <Register> <Name>FS_PRE</Name> <Value>0x6e</Value> </Register> <Register> <Name>FS_REG_DIV_CML</Name> <Value>0x1c</Value> </Register> <Register> <Name>FS_SPARE</Name> <Value>0xac</Value> </Register> <Register> <Name>FS_VCO0</Name> <Value>0xb5</Value> </Register> <Register> <Name>IF_ADC0</Name> <Value>0x10</Value> </Register> <Register> <Name>IF_ADC1</Name> <Value>0xee</Value> </Register> <Register> <Name>IF_MIX_CFG</Name> <Value>0x1c</Value> </Register> <Register> <Name>IOCFG2</Name> <Value>0x06</Value> </Register> <Register> <Name>IQIC</Name> <Value>0xcb</Value> </Register> <Register> <Name>MDMCFG0</Name> <Value>0x05</Value> </Register> <Register> <Name>MDMCFG1</Name> <Value>0x40</Value> </Register> <Register> <Name>MDMCFG2</Name> <Value>0x0c</Value> </Register> <Register> <Name>MODCFG_DEV_E</Name> <Value>0x00</Value> </Register> <Register> <Name>MODEM_STATUS1</Name> <Value>0x10</Value> </Register> <Register> <Name>PARTNUMBER</Name> <Value>0x20</Value> </Register> <Register> <Name>PARTVERSION</Name> <Value>0x11</Value> </Register> <Register> <Name>PA_CFG1</Name> <Value>0x3f</Value> </Register> <Register> <Name>PKT_CFG1</Name> <Value>0x01</Value> </Register> <Register> <Name>PKT_CFG2</Name> <Value>0x00</Value> </Register> <Register> <Name>PKT_LEN</Name> <Value>0x00</Value> </Register> <Register> <Name>PREAMBLE_CFG0</Name> <Value>0x8a</Value> </Register> <Register> <Name>PREAMBLE_CFG1</Name> <Value>0x00</Value> </Register> <Register> <Name>SYMBOL_RATE0</Name> <Value>0x10</Value> </Register> <Register> <Name>SYMBOL_RATE1</Name> <Value>0x75</Value> </Register> <Register> <Name>SYMBOL_RATE2</Name> <Value>0x3f</Value> </Register> <Register> <Name>SYNC_CFG1</Name> <Value>0x2b</Value> </Register> <Register> <Name>XOSC1</Name> <Value>0x03</Value> </Register> <Register> <Name>XOSC5</Name> <Value>0x0e</Value> </Register> </registersettings> <dcpanel> <Property role="44" name="m_chkRegView">2</Property> <Property role="44" name="m_chkRfParameters">2</Property> <Property role="37" name="m_tabUserMode">1</Property> <Property role="33" name="m_easyModeSettings">-1</Property> <Property role="33" name="m_typicalSettings">-1</Property> <Property role="37" name="m_testFuncPanel">2</Property> </dcpanel> <rfparameters> <Property role="46" name="m_cmbFrontends">0</Property> <Property role="44" name="m_chkHGMorBYP">2</Property> <Property role="46" name="m_cmbEmRevs">-1</Property> <Property role="46" name="Xtal frequency">40.000000</Property> </rfparameters> <conttx> <Property role="45" name="m_rbtModulated">1</Property> <Property role="45" name="m_rbtUnmodulated">0</Property> <Property role="46" name="m_cmbDataFormat">-1</Property> <Property role="44" name="m_chkFreqSweep">0</Property> <Property role="44" name="m_chkChanSweep">0</Property> </conttx> <contrx> <Property role="46" name="m_cmbDataFormat">-1</Property> <Property role="44" name="m_chkAutoScroll">2</Property> </contrx> <packettx> <Property role="42" name="m_edtPktLength">0</Property> <Property role="42" name="m_edtPacketCount">100</Property> <Property role="42" name="m_edtPacketCountEsy">100</Property> <Property role="42" name="m_edtPacketData">f4 </Property> <Property role="42" name="m_edtAccessAddress"></Property> <Property role="44" name="m_chkAddSeqNbr">0</Property> <Property role="44" name="m_chkInfinite">2</Property> <Property role="44" name="m_chkInfiniteEsy">2</Property> <Property role="45" name="m_rbtRandom">1</Property> <Property role="45" name="m_rbtText">0</Property> <Property role="45" name="m_rbtHex">0</Property> <Property role="44" name="m_chkAdvanced">2</Property> <Property role="46" name="m_cmbLengthConfig">0</Property> <Property role="42" name="m_edtFixedPktLength">0</Property> <Property role="42" name="m_edtBitLength">0</Property> <Property role="20" name="m_grp802154g">0</Property> <Property role="42" name="m_edt802154gPktLength"></Property> <Property role="45" name="m_rbt802154g2BCrc">1</Property> <Property role="45" name="m_rbt802154g4BCrc">0</Property> <Property role="44" name="m_chk802154gWhitening">2</Property> <Property role="44" name="m_chkFEC">0</Property> <Property role="46" name="m_cmbPreambleWord">0</Property> <Property role="46" name="m_cmbPreambleCount">0</Property> <Property role="42" name="m_edtSync3">93</Property> <Property role="42" name="m_edtSync2">0b</Property> <Property role="42" name="m_edtSync1">51</Property> <Property role="42" name="m_edtSync0">de</Property> <Property role="42" name="m_edtAddress"></Property> <Property role="44" name="m_chkAddress">0</Property> <Property role="42" name="m_edt802154gHeader">0x181e</Property> <Property role="46" name="m_cmbSyncMode">1</Property> <Property role="52" name="m_spnPktInterval">100</Property> <Property role="44" name="m_chkDefPktInterval">2</Property> </packettx> <packetrx> <Property role="42" name="m_edtPacketCount">100</Property> <Property role="42" name="m_edtPacketCountEsy">100</Property> <Property role="42" name="m_edtAccessAddress"></Property> <Property role="44" name="m_chkInfinite">0</Property> <Property role="44" name="m_chkInfiniteEsy">0</Property> <Property role="46" name="m_cmbViewFormat">0</Property> <Property role="44" name="m_chkSeqNbrIncluded">2</Property> <Property role="42" name="m_edtDumpFile"></Property> <Property role="44" name="m_chkAdvanced">0</Property> <Property role="44" name="m_chk802154gMode">0</Property> </packetrx> <commandpanel> <Property role="44" name="m_chkInsertLength">0</Property> <Property role="42" name="m_edtTxFifo"></Property> <Property role="42" name="m_edtRxFifo"></Property> <Property role="46" name="m_cmbInstrInput">-1</Property> </commandpanel> <packetRxSniffMode> <Property role="42" name="m_edtPreambleLength">4</Property> <Property role="42" name="m_edtCarrierSenseThreshold">-90</Property> <Property role="45" name="m_rbtRssi">1</Property> <Property role="45" name="m_rbtPreamble">0</Property> </packetRxSniffMode> </dcpanelconfiguration>
