QUESTION 1
How does the CC1200 transceiver keep the Intersymbol Interference under control?
QUESTION 2
Is there a channel equalizer?
Thanks in advance,
Enrico Migliore
QUESTION 1
QUESTION 2
Thanks in advance,
Enrico Migliore
The viterbi decoder handles the ISI.
What is the background for your question?
No. Basically the receiver knows which values a '1' -> '1', '1' -> '0' and so on should have for the programmed modulation formats. The incoming waveform is then compared with this. From this it's possible to see which transition the incoming signal does even with ISI present.
