SWRU295A user manual. Please explain the difference between figure 25 (Rx_Time_Qual=0) and figure 26 (Rx_Time_Qual=0 & Ant_Div_Term_CFG=1).
In figure 25 the Rx continues although the CS drops and in figure 26 the Rx stops when the CS drops.
Hi
Figure 25 shows what is going on for different RX_TIME_QUAL settings. It is assumed that ANT_DIV_RX_TERM_CFG = 0. The RX_TIME_QUAL setting determines what is happening when the RX timeout expires. When RX_TIME_QUAL = 1, the radio will continue in RX if there is sync found, or if a preamble or CS is present at the time of the timeout. When ANT_DIV_RX_TERM_CFG = 0, the radio will always stay in RX for the minimum time of the RX timeout.
When ANT_DIV_RX_TERM_CFG = 1, the radio will check the carrier as soon as CS_VALID is asserted (it will not wait for the timeout to check). If there is a carrier, it will continue in RX. When the timeout occurs, it will remain in RX or terminate based on the RX_TIME_QUAL setting.
Siri
