In figure 27 how the Rx Time is defined. In the RFStudio at Rx Sniff mode the RFEND_CFG1.Rx.Time=111 i.e. disable.
Hi
When using RX Sniff Mode, the RX timeout is disabled as described in the CC112x/CC120x RX Sniff Mode Applications Report (http://www.ti.com/lit/swra428). When using RX Sniff Mode, the eWOR timer is used. The figure simply shows the different events when running eWOR mode (not Sniff Mode). In this mode the transmitter and receiver needs to be synchronized and an RX timeout is implemented.
BR
Siri
