hello,
I've followed Siri configuration from this link.
It is working very well until I changed them to a state where there is no SNIFF (continuous RX).
I needed to change the configuration & I guess I did somthing wrong since it seems that my board doesn't Tx any more.
The following is based on the Sniff_Mode_RX.xml file, please advice what am I doing wrong?
I only need to be able to use "Packet Rx" mode from smartRf & to receive the packets from a device configured by siris' Sniff_Mode_TX.xml than to parse some data & Tx that again..
//siri configuration: 915MHz, rx filter:125KHz, symbol rate:62ksps, deviation:20.019531KHZ ,Tx: 4 dbm #define SMARTRF_RADIO_CC1120 #define SMARTRF_SETTING_IOCFG3 0xB0 #define SMARTRF_SETTING_IOCFG2 0x06 #define SMARTRF_SETTING_IOCFG1 0xB0 #define SMARTRF_SETTING_IOCFG0 0x40 #define SMARTRF_SETTING_SYNC3 0x93 #define SMARTRF_SETTING_SYNC2 0x0B #define SMARTRF_SETTING_SYNC1 0x51 #define SMARTRF_SETTING_SYNC0 0xDE #define SMARTRF_SETTING_SYNC_CFG1 0x0B #define SMARTRF_SETTING_SYNC_CFG0 0x17 #define SMARTRF_SETTING_DEVIATION_M 0x48 #define SMARTRF_SETTING_MODCFG_DEV_E 0x2D #define SMARTRF_SETTING_DCFILT_CFG 0x1C #define SMARTRF_SETTING_PREAMBLE_CFG1 0x2C//smartRf defaults 0x18 #define SMARTRF_SETTING_PREAMBLE_CFG0 0x2A #define SMARTRF_SETTING_FREQ_IF_CFG 0x40 #define SMARTRF_SETTING_IQIC 0x00 #define SMARTRF_SETTING_CHAN_BW 0x41 #define SMARTRF_SETTING_MDMCFG1 0x46 #define SMARTRF_SETTING_MDMCFG0 0x05 #define SMARTRF_SETTING_SYMBOL_RATE2 0x9F #define SMARTRF_SETTING_SYMBOL_RATE1 0xBE #define SMARTRF_SETTING_SYMBOL_RATE0 0x77 #define SMARTRF_SETTING_AGC_REF 0x36 #define SMARTRF_SETTING_AGC_CS_THR 0x19 #define SMARTRF_SETTING_AGC_GAIN_ADJUST 0x00 #define SMARTRF_SETTING_AGC_CFG3 0x91 #define SMARTRF_SETTING_AGC_CFG2 0x20 #define SMARTRF_SETTING_AGC_CFG1 0xA9 #define SMARTRF_SETTING_AGC_CFG0 0xC3 #define SMARTRF_SETTING_FIFO_CFG 0x00 #define SMARTRF_SETTING_DEV_ADDR 0x00 #define SMARTRF_SETTING_SETTLING_CFG 0x0B #define SMARTRF_SETTING_FS_CFG 0x12 #define SMARTRF_SETTING_WOR_CFG1 0x08 #define SMARTRF_SETTING_WOR_CFG0 0x21 #define SMARTRF_SETTING_WOR_EVENT0_MSB 0x00 #define SMARTRF_SETTING_WOR_EVENT0_LSB 0x00 #define SMARTRF_SETTING_PKT_CFG2 0x04 #define SMARTRF_SETTING_PKT_CFG1 0x05 #define SMARTRF_SETTING_PKT_CFG0 0x20 #define SMARTRF_SETTING_RFEND_CFG1 0x0F #define SMARTRF_SETTING_RFEND_CFG0 0x00 #define SMARTRF_SETTING_PA_CFG2 0x7F #define SMARTRF_SETTING_PA_CFG1 0x56 #define SMARTRF_SETTING_PA_CFG0 0x7B #define SMARTRF_SETTING_PKT_LEN 0xFF #define SMARTRF_SETTING_IF_MIX_CFG 0x00 #define SMARTRF_SETTING_FREQOFF_CFG 0x22 #define SMARTRF_SETTING_TOC_CFG 0x0B #define SMARTRF_SETTING_MARC_SPARE 0x00 #define SMARTRF_SETTING_ECG_CFG 0x00 #define SMARTRF_SETTING_CFM_DATA_CFG 0x00 #define SMARTRF_SETTING_EXT_CTRL 0x01 #define SMARTRF_SETTING_RCCAL_FINE 0x00 #define SMARTRF_SETTING_RCCAL_COARSE 0x00 #define SMARTRF_SETTING_RCCAL_OFFSET 0x00 #define SMARTRF_SETTING_FREQOFF1 0x00 #define SMARTRF_SETTING_FREQOFF0 0x00 #define SMARTRF_SETTING_FREQ2 0x72 #define SMARTRF_SETTING_FREQ1 0x60 #define SMARTRF_SETTING_FREQ0 0x00 #define SMARTRF_SETTING_IF_ADC2 0x02 #define SMARTRF_SETTING_IF_ADC1 0xA6 #define SMARTRF_SETTING_IF_ADC0 0x04 #define SMARTRF_SETTING_FS_DIG1 0x00 #define SMARTRF_SETTING_FS_DIG0 0x5F #define SMARTRF_SETTING_FS_CAL3 0x00 #define SMARTRF_SETTING_FS_CAL2 0x20 #define SMARTRF_SETTING_FS_CAL1 0x40 #define SMARTRF_SETTING_FS_CAL0 0x0E #define SMARTRF_SETTING_FS_CHP 0x28 #define SMARTRF_SETTING_FS_DIVTWO 0x03 #define SMARTRF_SETTING_FS_DSM1 0x00 #define SMARTRF_SETTING_FS_DSM0 0x33 #define SMARTRF_SETTING_FS_DVC1 0xFF #define SMARTRF_SETTING_FS_DVC0 0x17 #define SMARTRF_SETTING_FS_LBI 0x00 #define SMARTRF_SETTING_FS_PFD 0x50 #define SMARTRF_SETTING_FS_PRE 0x6E #define SMARTRF_SETTING_FS_REG_DIV_CML 0x14 #define SMARTRF_SETTING_FS_SPARE 0xAC #define SMARTRF_SETTING_FS_VCO4 0x14 #define SMARTRF_SETTING_FS_VCO3 0x00 #define SMARTRF_SETTING_FS_VCO2 0x00 #define SMARTRF_SETTING_FS_VCO1 0x00 #define SMARTRF_SETTING_FS_VCO0 0xB4 #define SMARTRF_SETTING_GBIAS6 0x00 #define SMARTRF_SETTING_GBIAS5 0x02 #define SMARTRF_SETTING_GBIAS4 0x00 #define SMARTRF_SETTING_GBIAS3 0x00 #define SMARTRF_SETTING_GBIAS2 0x10 #define SMARTRF_SETTING_GBIAS1 0x00 #define SMARTRF_SETTING_GBIAS0 0x00 #define SMARTRF_SETTING_IFAMP 0x01 #define SMARTRF_SETTING_LNA 0x01 #define SMARTRF_SETTING_RXMIX 0x01 #define SMARTRF_SETTING_XOSC5 0x0E #define SMARTRF_SETTING_XOSC4 0xA0 #define SMARTRF_SETTING_XOSC3 0x03 #define SMARTRF_SETTING_XOSC2 0x04 #define SMARTRF_SETTING_XOSC1 0x03 #define SMARTRF_SETTING_XOSC0 0x00 #define SMARTRF_SETTING_ANALOG_SPARE 0x00 #define SMARTRF_SETTING_PA_CFG3 0x00 #define SMARTRF_SETTING_WOR_TIME1 0x00 #define SMARTRF_SETTING_WOR_TIME0 0x00 #define SMARTRF_SETTING_WOR_CAPTURE1 0x00 #define SMARTRF_SETTING_WOR_CAPTURE0 0x00 #define SMARTRF_SETTING_BIST 0x00 #define SMARTRF_SETTING_DCFILTOFFSET_I1 0x00 #define SMARTRF_SETTING_DCFILTOFFSET_I0 0x00 #define SMARTRF_SETTING_DCFILTOFFSET_Q1 0x00 #define SMARTRF_SETTING_DCFILTOFFSET_Q0 0x00 #define SMARTRF_SETTING_IQIE_I1 0x00 #define SMARTRF_SETTING_IQIE_I0 0x00 #define SMARTRF_SETTING_IQIE_Q1 0x00 #define SMARTRF_SETTING_IQIE_Q0 0x00 #define SMARTRF_SETTING_RSSI1 0x80 #define SMARTRF_SETTING_RSSI0 0x00 #define SMARTRF_SETTING_MARCSTATE 0x41 #define SMARTRF_SETTING_LQI_VAL 0x00 #define SMARTRF_SETTING_PQT_SYNC_ERR 0xFF #define SMARTRF_SETTING_DEM_STATUS 0x00 #define SMARTRF_SETTING_FREQOFF_EST1 0x00 #define SMARTRF_SETTING_FREQOFF_EST0 0x00 #define SMARTRF_SETTING_AGC_GAIN3 0x00 #define SMARTRF_SETTING_AGC_GAIN2 0xD1 #define SMARTRF_SETTING_AGC_GAIN1 0x00 #define SMARTRF_SETTING_AGC_GAIN0 0x3F #define SMARTRF_SETTING_CFM_RX_DATA_OUT 0x00 #define SMARTRF_SETTING_CFM_TX_DATA_IN 0x00 #define SMARTRF_SETTING_ASK_SOFT_RX_DATA 0x30 #define SMARTRF_SETTING_RNDGEN 0x7F #define SMARTRF_SETTING_MAGN2 0x00 #define SMARTRF_SETTING_MAGN1 0x00 #define SMARTRF_SETTING_MAGN0 0x00 #define SMARTRF_SETTING_ANG1 0x00 #define SMARTRF_SETTING_ANG0 0x00 #define SMARTRF_SETTING_CHFILT_I2 0x08 #define SMARTRF_SETTING_CHFILT_I1 0x00 #define SMARTRF_SETTING_CHFILT_I0 0x00 #define SMARTRF_SETTING_CHFILT_Q2 0x00 #define SMARTRF_SETTING_CHFILT_Q1 0x00 #define SMARTRF_SETTING_CHFILT_Q0 0x00 #define SMARTRF_SETTING_GPIO_STATUS 0x00 #define SMARTRF_SETTING_FSCAL_CTRL 0x01 #define SMARTRF_SETTING_PHASE_ADJUST 0x00 #define SMARTRF_SETTING_PARTNUMBER 0x00 #define SMARTRF_SETTING_PARTVERSION 0x00 #define SMARTRF_SETTING_SERIAL_STATUS 0x00 #define SMARTRF_SETTING_MODEM_STATUS1 0x01 #define SMARTRF_SETTING_MODEM_STATUS0 0x00 #define SMARTRF_SETTING_MARC_STATUS1 0x00 #define SMARTRF_SETTING_MARC_STATUS0 0x00 #define SMARTRF_SETTING_PA_IFAMP_TEST 0x00 #define SMARTRF_SETTING_FSRF_TEST 0x00 #define SMARTRF_SETTING_PRE_TEST 0x00 #define SMARTRF_SETTING_PRE_OVR 0x00 #define SMARTRF_SETTING_ADC_TEST 0x00 #define SMARTRF_SETTING_DVC_TEST 0x0B #define SMARTRF_SETTING_ATEST 0x40 #define SMARTRF_SETTING_ATEST_LVDS 0x00 #define SMARTRF_SETTING_ATEST_MODE 0x00 #define SMARTRF_SETTING_XOSC_TEST1 0x3C #define SMARTRF_SETTING_XOSC_TEST0 0x00 #define SMARTRF_SETTING_RXFIRST 0x00 #define SMARTRF_SETTING_TXFIRST 0x00 #define SMARTRF_SETTING_RXLAST 0x00 #define SMARTRF_SETTING_TXLAST 0x00 #define SMARTRF_SETTING_NUM_TXBYTES 0x00 #define SMARTRF_SETTING_NUM_RXBYTES 0x00 #define SMARTRF_SETTING_FIFO_NUM_TXBYTES 0x0F #define SMARTRF_SETTING_FIFO_NUM_RXBYTES 0x00
Siri original configuration from the xml are:
//siri configuration: 915MHz, rx filter:125KHz, symbol rate:62ksps, deviation:20.019531KHZ ,Tx: 4 dbm #define SMARTRF_RADIO_CC1120 #define SMARTRF_SETTING_IOCFG3 0xB0 #define SMARTRF_SETTING_IOCFG2 0x06 #define SMARTRF_SETTING_IOCFG1 0xB0 #define SMARTRF_SETTING_IOCFG0 0x40 #define SMARTRF_SETTING_SYNC3 0x93 #define SMARTRF_SETTING_SYNC2 0x0B #define SMARTRF_SETTING_SYNC1 0x51 #define SMARTRF_SETTING_SYNC0 0xDE #define SMARTRF_SETTING_SYNC_CFG1 0x08 #define SMARTRF_SETTING_SYNC_CFG0 0x17 #define SMARTRF_SETTING_DEVIATION_M 0x48 #define SMARTRF_SETTING_MODCFG_DEV_E 0x2D #define SMARTRF_SETTING_DCFILT_CFG 0x1C #define SMARTRF_SETTING_PREAMBLE_CFG1 0x14 #define SMARTRF_SETTING_PREAMBLE_CFG0 0x2A #define SMARTRF_SETTING_FREQ_IF_CFG 0x40 #define SMARTRF_SETTING_IQIC 0x00 #define SMARTRF_SETTING_CHAN_BW 0x41 #define SMARTRF_SETTING_MDMCFG1 0x46 #define SMARTRF_SETTING_MDMCFG0 0x05 #define SMARTRF_SETTING_SYMBOL_RATE2 0x9F #define SMARTRF_SETTING_SYMBOL_RATE1 0xBE #define SMARTRF_SETTING_SYMBOL_RATE0 0x77 #define SMARTRF_SETTING_AGC_REF 0x36 #define SMARTRF_SETTING_AGC_CS_THR 0x0C #define SMARTRF_SETTING_AGC_GAIN_ADJUST 0x00 #define SMARTRF_SETTING_AGC_CFG3 0x91 #define SMARTRF_SETTING_AGC_CFG2 0x20 #define SMARTRF_SETTING_AGC_CFG1 0xA0 #define SMARTRF_SETTING_AGC_CFG0 0xC3 #define SMARTRF_SETTING_FIFO_CFG 0x00 #define SMARTRF_SETTING_DEV_ADDR 0x00 #define SMARTRF_SETTING_SETTLING_CFG 0x03 #define SMARTRF_SETTING_FS_CFG 0x12 #define SMARTRF_SETTING_WOR_CFG1 0x08 #define SMARTRF_SETTING_WOR_CFG0 0x20 #define SMARTRF_SETTING_WOR_EVENT0_MSB 0x00 #define SMARTRF_SETTING_WOR_EVENT0_LSB 0x2F #define SMARTRF_SETTING_PKT_CFG2 0x04 #define SMARTRF_SETTING_PKT_CFG1 0x05 #define SMARTRF_SETTING_PKT_CFG0 0x20 #define SMARTRF_SETTING_RFEND_CFG1 0x0F #define SMARTRF_SETTING_RFEND_CFG0 0x09 #define SMARTRF_SETTING_PA_CFG2 0x66 #define SMARTRF_SETTING_PA_CFG1 0x56 #define SMARTRF_SETTING_PA_CFG0 0x7B #define SMARTRF_SETTING_PKT_LEN 0xFF #define SMARTRF_SETTING_IF_MIX_CFG 0x00 #define SMARTRF_SETTING_FREQOFF_CFG 0x22 #define SMARTRF_SETTING_TOC_CFG 0x0B #define SMARTRF_SETTING_MARC_SPARE 0x00 #define SMARTRF_SETTING_ECG_CFG 0x00 #define SMARTRF_SETTING_CFM_DATA_CFG 0x00 #define SMARTRF_SETTING_EXT_CTRL 0x01 #define SMARTRF_SETTING_RCCAL_FINE 0x00 #define SMARTRF_SETTING_RCCAL_COARSE 0x00 #define SMARTRF_SETTING_RCCAL_OFFSET 0x00 #define SMARTRF_SETTING_FREQOFF1 0x00 #define SMARTRF_SETTING_FREQOFF0 0x00 #define SMARTRF_SETTING_FREQ2 0x72 #define SMARTRF_SETTING_FREQ1 0x60 #define SMARTRF_SETTING_FREQ0 0x00 #define SMARTRF_SETTING_IF_ADC2 0x02 #define SMARTRF_SETTING_IF_ADC1 0xA6 #define SMARTRF_SETTING_IF_ADC0 0x04 #define SMARTRF_SETTING_FS_DIG1 0x00 #define SMARTRF_SETTING_FS_DIG0 0x5F #define SMARTRF_SETTING_FS_CAL3 0x00 #define SMARTRF_SETTING_FS_CAL2 0x20 #define SMARTRF_SETTING_FS_CAL1 0x40 #define SMARTRF_SETTING_FS_CAL0 0x0E #define SMARTRF_SETTING_FS_CHP 0x28 #define SMARTRF_SETTING_FS_DIVTWO 0x03 #define SMARTRF_SETTING_FS_DSM1 0x00 #define SMARTRF_SETTING_FS_DSM0 0x33 #define SMARTRF_SETTING_FS_DVC1 0xFF #define SMARTRF_SETTING_FS_DVC0 0x17 #define SMARTRF_SETTING_FS_LBI 0x00 #define SMARTRF_SETTING_FS_PFD 0x50 #define SMARTRF_SETTING_FS_PRE 0x6E #define SMARTRF_SETTING_FS_REG_DIV_CML 0x14 #define SMARTRF_SETTING_FS_SPARE 0xAC #define SMARTRF_SETTING_FS_VCO4 0x14 #define SMARTRF_SETTING_FS_VCO3 0x00 #define SMARTRF_SETTING_FS_VCO2 0x00 #define SMARTRF_SETTING_FS_VCO1 0x00 #define SMARTRF_SETTING_FS_VCO0 0xB4 #define SMARTRF_SETTING_GBIAS6 0x00 #define SMARTRF_SETTING_GBIAS5 0x02 #define SMARTRF_SETTING_GBIAS4 0x00 #define SMARTRF_SETTING_GBIAS3 0x00 #define SMARTRF_SETTING_GBIAS2 0x10 #define SMARTRF_SETTING_GBIAS1 0x00 #define SMARTRF_SETTING_GBIAS0 0x00 #define SMARTRF_SETTING_IFAMP 0x01 #define SMARTRF_SETTING_LNA 0x01 #define SMARTRF_SETTING_RXMIX 0x01 #define SMARTRF_SETTING_XOSC5 0x0E #define SMARTRF_SETTING_XOSC4 0xA0 #define SMARTRF_SETTING_XOSC3 0x03 #define SMARTRF_SETTING_XOSC2 0x00 #define SMARTRF_SETTING_XOSC1 0x03 #define SMARTRF_SETTING_XOSC0 0x00 #define SMARTRF_SETTING_ANALOG_SPARE 0x00 #define SMARTRF_SETTING_PA_CFG3 0x00 #define SMARTRF_SETTING_WOR_TIME1 0x00 #define SMARTRF_SETTING_WOR_TIME0 0x00 #define SMARTRF_SETTING_WOR_CAPTURE1 0x00 #define SMARTRF_SETTING_WOR_CAPTURE0 0x00 #define SMARTRF_SETTING_BIST 0x00 #define SMARTRF_SETTING_DCFILTOFFSET_I1 0x00 #define SMARTRF_SETTING_DCFILTOFFSET_I0 0x00 #define SMARTRF_SETTING_DCFILTOFFSET_Q1 0x00 #define SMARTRF_SETTING_DCFILTOFFSET_Q0 0x00 #define SMARTRF_SETTING_IQIE_I1 0x00 #define SMARTRF_SETTING_IQIE_I0 0x00 #define SMARTRF_SETTING_IQIE_Q1 0x00 #define SMARTRF_SETTING_IQIE_Q0 0x00 #define SMARTRF_SETTING_RSSI1 0x80 #define SMARTRF_SETTING_RSSI0 0x00 #define SMARTRF_SETTING_MARCSTATE 0x41 #define SMARTRF_SETTING_LQI_VAL 0x00 #define SMARTRF_SETTING_PQT_SYNC_ERR 0xFF #define SMARTRF_SETTING_DEM_STATUS 0x00 #define SMARTRF_SETTING_FREQOFF_EST1 0x00 #define SMARTRF_SETTING_FREQOFF_EST0 0x00 #define SMARTRF_SETTING_AGC_GAIN3 0x00 #define SMARTRF_SETTING_AGC_GAIN2 0xD1 #define SMARTRF_SETTING_AGC_GAIN1 0x00 #define SMARTRF_SETTING_AGC_GAIN0 0x3F #define SMARTRF_SETTING_CFM_RX_DATA_OUT 0x00 #define SMARTRF_SETTING_CFM_TX_DATA_IN 0x00 #define SMARTRF_SETTING_ASK_SOFT_RX_DATA 0x30 #define SMARTRF_SETTING_RNDGEN 0x7F #define SMARTRF_SETTING_MAGN2 0x00 #define SMARTRF_SETTING_MAGN1 0x00 #define SMARTRF_SETTING_MAGN0 0x00 #define SMARTRF_SETTING_ANG1 0x00 #define SMARTRF_SETTING_ANG0 0x00 #define SMARTRF_SETTING_CHFILT_I2 0x08 #define SMARTRF_SETTING_CHFILT_I1 0x00 #define SMARTRF_SETTING_CHFILT_I0 0x00 #define SMARTRF_SETTING_CHFILT_Q2 0x00 #define SMARTRF_SETTING_CHFILT_Q1 0x00 #define SMARTRF_SETTING_CHFILT_Q0 0x00 #define SMARTRF_SETTING_GPIO_STATUS 0x00 #define SMARTRF_SETTING_FSCAL_CTRL 0x01 #define SMARTRF_SETTING_PHASE_ADJUST 0x00 #define SMARTRF_SETTING_PARTNUMBER 0x00 #define SMARTRF_SETTING_PARTVERSION 0x00 #define SMARTRF_SETTING_SERIAL_STATUS 0x00 #define SMARTRF_SETTING_MODEM_STATUS1 0x01 #define SMARTRF_SETTING_MODEM_STATUS0 0x00 #define SMARTRF_SETTING_MARC_STATUS1 0x00 #define SMARTRF_SETTING_MARC_STATUS0 0x00 #define SMARTRF_SETTING_PA_IFAMP_TEST 0x00 #define SMARTRF_SETTING_FSRF_TEST 0x00 #define SMARTRF_SETTING_PRE_TEST 0x00 #define SMARTRF_SETTING_PRE_OVR 0x00 #define SMARTRF_SETTING_ADC_TEST 0x00 #define SMARTRF_SETTING_DVC_TEST 0x0B #define SMARTRF_SETTING_ATEST 0x40 #define SMARTRF_SETTING_ATEST_LVDS 0x00 #define SMARTRF_SETTING_ATEST_MODE 0x00 #define SMARTRF_SETTING_XOSC_TEST1 0x3C #define SMARTRF_SETTING_XOSC_TEST0 0x00 #define SMARTRF_SETTING_RXFIRST 0x00 #define SMARTRF_SETTING_TXFIRST 0x00 #define SMARTRF_SETTING_RXLAST 0x00 #define SMARTRF_SETTING_TXLAST 0x00 #define SMARTRF_SETTING_NUM_TXBYTES 0x00 #define SMARTRF_SETTING_NUM_RXBYTES 0x00 #define SMARTRF_SETTING_FIFO_NUM_TXBYTES 0x0F #define SMARTRF_SETTING_FIFO_NUM_RXBYTES 0x00
