We currently have a production transceiver product using the TI CC1101 with the following settings;
Freq=905Mhz, Modulation=GFSK, Data Rate=115Kb, Freq Deviation=47.7Khz, PKt Size=63 bytes,
Channel Spacing=200Mhz, Rx BW=200Khz, Whitening Enabled, TX Power=+11dBm. We are seeing sensitivity numbers of about -85dBm. This product is also FCC compliant.
We are currently developing a new product which requires much better sensitive, and less power consumption. Our packet size will be similar, and we can afford to lower the Data Rate. We are considering the TI CC1120 or the Silicon Labs Si446x line.
What new enhancements does the CC1120 yield, that can get us there? Are there any recommendations for changing the RF parameters to realize better sensitivity at lower power consumption? Any first-hand experience that you can share would be appreciated.
Thanks in advance.
