I am using Water Level Sensor in End device, Which needs to Send it's report Coordinator. Water level Sensor will Give one, if it contains water and Zero if there is no water. I found IAS ZONE cluster is comes under this Sensor. And Cluster id is defined in Zstack as ZCL_CLUSTER_ID_SS_IAS_ZONE and i didn't Found Attribute ID of this. Then i went the DOC Zigbee Cluster library, In that attribute ID mentioned as 0x002a. But the Same id number is defined for ATTRID_LIGHTING_COLOR_CONTROL_PRIMARY_6_INTENSITY. Can any one suggest me how to use it in my Program.
