I am facing problem in SampleLight/coordinator and SampleSwitch/router. Zigbee network initialization is not successful. They always shw ZDO_INITDEV_NEW_NETWORK_STATE in ZDOInitDevice().
I have checked ZDOInitDevice in ZDApp.c, SW_BYPASS_NV is not pressed in both router and coordinator. I debug something in ZDOInitDevice as follow.
Router:-
1> Function ZDOInitDevice is called only once at starting.
2> NV_RESTORE is not defined, so its not executing code between if defined to endif.
3> Function ZDOInitDevice is returning ZDO_INITDEV_NEW_NETWORK_STATE.
Coordinator:-
1> Function ZDOInitDevice is called periodically around per second.
2> NV_RESTORE is defined, so its executing code between if defined to endif.
3> SW_BYPASS_NV is not pressed.
4> Every time function ZDOInitDevice is returning ZDO_INITDEV_NEW_NETWORK_STATE.
I cannot proceed due to these issues, any help is greatly appreciable.
