Hi all, I'd like to change the default 8-bit resolution of accelerometer in SensorTag to 12-bit. So I changed the firmware source code by setting RES bit in ACC_REG_ADDR_CTRL_REG1 (0x1B) to 1 and modified the data length. However, after I test it using BLE Device Monitor, the output values remain the same. The accelerometer seems not working after the change. I am using the latest firmware source code in BLE stack 1.4.
So anyone here can help me on this issue? Thank you in advance!!
Chunmeng
