It seems that thermometer profile of BLE stack 1.4.0 does not meet the specifications of Bluetooth SIG
According to bluetooth health thermometer specification "Measurment interval" characteristic should be 2 bytes(containing org.bluetooth.unit.time.second), and "valid range"descriptor should contain 2 uint16.
But in BLE stack "measurment interval" is 1 byte, and "valid range" is 2 bytes
Solution:
- thermometerservice.h
BLE stack 1.4.0: | Should be: |
/** typedef struct |
// Length of bytes #define THERMOMETER_INTERVAL_LEN 1 #define THERMOMETER_TYPE_LEN 1 #define THERMOMETER_IRANGE_LEN 2 |
// Length of bytes #define THERMOMETER_INTERVAL_LEN 2 #define THERMOMETER_TYPE_LEN 1 #define THERMOMETER_IRANGE_LEN 4 |
- thermometerservice.c
//validate range if ((*pValue >= thermometerIRange.high) | ((*pValue <= thermometerIRange.low) & (*pValue != 0))) |
//validate range if ((*(uint16 *)pValue >= thermometerIRange.high) | ((*(uint16 *)pValue <= thermometerIRange.low) & (*(uint16 *)pValue != 0))) |
static uint8 thermometerInterval=30; //default | static uint16 thermometerInterval=30; //default |
// 10. Characteristic Value { { ATT_BT_UUID_SIZE, thermometerIntervalUUID }, GATT_PERMIT_READ | GATT_PERMIT_AUTHEN_WRITE, 0, &thermometerInterval }, |
// 10. Characteristic Value { { ATT_BT_UUID_SIZE, thermometerIntervalUUID }, GATT_PERMIT_READ | GATT_PERMIT_AUTHEN_WRITE, 0, (uint8 *)&thermometerInterval }, |
case THERMOMETER_INTERVAL: *((uint8*)value) = thermometerInterval; break; |
case THERMOMETER_INTERVAL: *((uint16*)value) = thermometerInterval; break; |
