Hello All
i am in the process of developing a custom PCB using cc2541 .At this point i have succes in the following
- cc2541 power ups and accepts code
- the RF Part is working
- I can connect it to BLE Device Monitor PC App.
- I can do full Attribute read from BLE Device Monitor PC App(see attached file for the attribute read logged data in XML).
<?xml version="1.0" encoding="UTF-8"?> <attributes> <attribute> <handle>1</handle> <type>0x2800</type> <menemonic>GATT Primary Service Declaration</menemonic> <value></value> </attribute> <attribute> <handle>2</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>02:03:00:00:2A</value> </attribute> <attribute> <handle>3</handle> <type>0x2A00</type> <menemonic>Device Name</menemonic> <value>54:49:20:42:4C:45:20:4B:65:79:66:6F:62</value> </attribute> <attribute> <handle>4</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>02:05:00:01:2A</value> </attribute> <attribute> <handle>5</handle> <type>0x2A01</type> <menemonic>Appearance</menemonic> <value>00:00</value> </attribute> <attribute> <handle>6</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>0A:07:00:02:2A</value> </attribute> <attribute> <handle>7</handle> <type>0x2A02</type> <menemonic>Peripheral Privacy Flag</menemonic> <value>00</value> </attribute> <attribute> <handle>8</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>08:09:00:03:2A</value> </attribute> <attribute> <handle>9</handle> <type>0x2A03</type> <menemonic>Reconnection Address</menemonic> <value></value> </attribute> <attribute> <handle>10</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>02:0B:00:04:2A</value> </attribute> <attribute> <handle>11</handle> <type>0x2A04</type> <menemonic>Peripheral Preferred Connection Parameters</menemonic> <value>50:00:A0:00:00:00:E8:03</value> </attribute> <attribute> <handle>12</handle> <type>0x2800</type> <menemonic>GATT Primary Service Declaration</menemonic> <value></value> </attribute> <attribute> <handle>13</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>20:0E:00:05:2A</value> </attribute> <attribute> <handle>14</handle> <type>0x2A05</type> <menemonic>Service Changed</menemonic> <value></value> </attribute> <attribute> <handle>15</handle> <type>0x2902</type> <menemonic>Client Characteristic Configuration</menemonic> <value></value> </attribute> <attribute> <handle>16</handle> <type>0x2800</type> <menemonic>GATT Primary Service Declaration</menemonic> <value></value> </attribute> <attribute> <handle>17</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>02:12:00:23:2A</value> </attribute> <attribute> <handle>18</handle> <type>0x2A23</type> <menemonic>System ID</menemonic> <value>8C:18:28:00:00:29:6A:BC</value> </attribute> <attribute> <handle>19</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>02:14:00:24:2A</value> </attribute> <attribute> <handle>20</handle> <type>0x2A24</type> <menemonic>Model Number String</menemonic> <value>4D:6F:64:65:6C:20:4E:75:6D:62:65:72:00</value> </attribute> <attribute> <handle>21</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>02:16:00:25:2A</value> </attribute> <attribute> <handle>22</handle> <type>0x2A25</type> <menemonic>Serial Number String</menemonic> <value>53:65:72:69:61:6C:20:4E:75:6D:62:65:72:00</value> </attribute> <attribute> <handle>23</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>02:18:00:26:2A</value> </attribute> <attribute> <handle>24</handle> <type>0x2A26</type> <menemonic>Firmware Revision String</menemonic> <value>46:69:72:6D:77:61:72:65:20:52:65:76:69:73:69:6F:6E:00</value> </attribute> <attribute> <handle>25</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>02:1A:00:27:2A</value> </attribute> <attribute> <handle>26</handle> <type>0x2A27</type> <menemonic>Hardware Revision String</menemonic> <value>48:61:72:64:77:61:72:65:20:52:65:76:69:73:69:6F:6E:00</value> </attribute> <attribute> <handle>27</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>02:1C:00:28:2A</value> </attribute> <attribute> <handle>28</handle> <type>0x2A28</type> <menemonic>Software Revision String</menemonic> <value>53:6F:66:74:77:61:72:65:20:52:65:76:69:73:69:6F:6E:00</value> </attribute> <attribute> <handle>29</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>02:1E:00:29:2A</value> </attribute> <attribute> <handle>30</handle> <type>0x2A29</type> <menemonic>Manufacturer Name String</menemonic> <value>4D:61:6E:75:66:61:63:74:75:72:65:72:20:4E:61:6D:65:00</value> </attribute> <attribute> <handle>31</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>02:20:00:2A:2A</value> </attribute> <attribute> <handle>32</handle> <type>0x2A2A</type> <menemonic>IEEE 11073-20601 Regulatory Certification Data List</menemonic> <value>FE:00:65:78:70:65:72:69:6D:65:6E:74:61:6C</value> </attribute> <attribute> <handle>33</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>02:22:00:50:2A</value> </attribute> <attribute> <handle>34</handle> <type>0x2A50</type> <menemonic>PnP ID</menemonic> <value>01:0D:00:00:00:10:01</value> </attribute> <attribute> <handle>35</handle> <type>0x2800</type> <menemonic>GATT Primary Service Declaration</menemonic> <value></value> </attribute> <attribute> <handle>36</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>0A:25:00:06:2A</value> </attribute> <attribute> <handle>37</handle> <type>0x2A06</type> <menemonic>Alert Level</menemonic> <value>00</value> </attribute> <attribute> <handle>38</handle> <type>0x2800</type> <menemonic>GATT Primary Service Declaration</menemonic> <value></value> </attribute> <attribute> <handle>39</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>04:28:00:06:2A</value> </attribute> <attribute> <handle>40</handle> <type>0x2A06</type> <menemonic>Alert Level</menemonic> <value></value> </attribute> <attribute> <handle>41</handle> <type>0x2800</type> <menemonic>GATT Primary Service Declaration</menemonic> <value></value> </attribute> <attribute> <handle>42</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>12:2B:00:07:2A</value> </attribute> <attribute> <handle>43</handle> <type>0x2A07</type> <menemonic>Tx Power Level</menemonic> <value>00</value> </attribute> <attribute> <handle>44</handle> <type>0x2902</type> <menemonic>Client Characteristic Configuration</menemonic> <value></value> </attribute> <attribute> <handle>45</handle> <type>0x2800</type> <menemonic>GATT Primary Service Declaration</menemonic> <value></value> </attribute> <attribute> <handle>46</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>12:2F:00:19:2A</value> </attribute> <attribute> <handle>47</handle> <type>0x2A19</type> <menemonic>Battery Level</menemonic> <value>64</value> </attribute> <attribute> <handle>48</handle> <type>0x2902</type> <menemonic>Client Characteristic Configuration</menemonic> <value></value> </attribute> <attribute> <handle>49</handle> <type>0x2908</type> <menemonic>Report Reference</menemonic> <value></value> </attribute> <attribute> <handle>50</handle> <type>0x2800</type> <menemonic>GATT Primary Service Declaration</menemonic> <value></value> </attribute> <attribute> <handle>51</handle> <type>0x2803</type> <menemonic>GATT Characteristic Declaration</menemonic> <value>10:34:00:E1:FF</value> </attribute> <attribute> <handle>52</handle> <type>0xFFE1</type> <menemonic>Key press state</menemonic> <value></value> </attribute> <attribute> <handle>53</handle> <type>0x2902</type> <menemonic>Client Characteristic Configuration</menemonic> <value></value> </attribute> <attribute> <handle>54</handle> <type>0x2901</type> <menemonic>Characteristic User Description</menemonic> <value></value> </attribute> </attributes>
Now i am facing a problem again.which is that the cc2541 board disconnects after 10~15 Seconds .
with the reason below
GAP Link Terminated: status=0 h=0 reason=0x08
In the forums i have read that this reason is due to supervision timeout i have change it to a larger value but no effect
This is a custom firmware that i have made using the KeyfobDemo App for cc2541.
The notable things i have changed in the firmware is modifying the firmware to use the internal 32K OSC instead of external
Along with that i have tested the same firmware on the orignal Keyfob(cc2541) and it disconnects immediatelty after it connects.
Here is the Log of the BLE Device Monitor from start to disconnect
22:51:23.371 > BLE Host: COM33 115200 baud hardware flowc. 22:51:23.816 > BLE Host found 22:51:23.826 > Scan request ... 22:51:23.827 > GAP Device Init Done 22:51:23.912 > GAP Device Information: status=0 type=0x00 [len=11] 22:51:23.915 > MAC address: BC:6A:29:28:18:8C 22:51:23.916 > Scan resp: ad=0x01 len=2 22:51:23.917 > Scan resp: ad=0x02 len=7 22:51:23.917 > GAP Device Information: status=0 type=0x04 [len=12] 22:51:23.918 > Device found: Keyfobdemo 22:51:27.888 > Scan cancel request ... 22:51:27.903 > Scan finished [4.76 sec] 22:51:27.905 > GAP Device Discovery: 0 devices 22:51:33.915 > Connect request 22:51:34.107 > Gap Link Established: h=0 ci=16 lat=0 to=3200 22:51:34.118 > Keyfobdemo connected 22:51:34.126 > Service discovery started 22:51:34.180 > ATT_ReadByGrpTypeRsp: status=0 n=19 22:51:34.209 > ATT_ReadByGrpTypeRsp: status=0 n=19 22:51:34.248 > ATT_ReadByGrpTypeRsp: status=0 n=13 22:51:34.249 > ATT_ReadByGrpTypeRsp: status=26 n=0 22:51:34.250 > Primary Service Discovery done [0.129 sec] 22:51:34.271 > Characteristic description discovery started 22:51:34.343 > ATT_FindInfoRsp: status=0 n=21 22:51:34.371 > ATT_FindInfoRsp: status=0 n=21 22:51:34.389 > ATT_FindInfoRsp: status=0 n=21 22:51:34.429 > ATT_FindInfoRsp: status=0 n=21 22:51:34.469 > ATT_FindInfoRsp: status=0 n=21 22:51:34.510 > ATT_FindInfoRsp: status=0 n=21 22:51:34.549 > ATT_FindInfoRsp: status=0 n=21 22:51:34.589 > ATT_FindInfoRsp: status=0 n=21 22:51:34.629 > ATT_FindInfoRsp: status=0 n=21 22:51:34.669 > ATT_FindInfoRsp: status=0 n=21 22:51:34.710 > ATT_FindInfoRsp: status=0 n=17 22:51:34.748 > ATT_FindInfoRsp: status=26 n=0 22:51:34.749 > Characteristic Description Discovery done [0.478] sec 22:51:34.761 > Characteristic discovery started 22:51:34.820 > ATT_ReadyByTypeResp: status=0 n=22 22:51:34.849 > ATT_ReadyByTypeResp: status=0 n=22 22:51:34.889 > ATT_ReadyByTypeResp: status=0 n=22 22:51:34.929 > ATT_ReadyByTypeResp: status=0 n=22 22:51:34.969 > ATT_ReadyByTypeResp: status=0 n=22 22:51:35.009 > ATT_ReadyByTypeResp: status=0 n=22 22:51:35.049 > ATT_ReadyByTypeResp: status=0 n=15 22:51:35.087 > ATT_ReadyByTypeResp: status=26 n=0 22:51:35.088 > Characteristic Discovery done [0.327] sec 22:51:35.488 > Attribute read started 22:51:35.545 > ATT_ReadResp: status=0 h=0 n=18, 53 6F 66 74 77 61 72 65 20 52 65 76 69 73 69 6F 6E 00 22:51:35.588 > ATT_ReadResp: status=0 h=0 n=18, 48 61 72 64 77 61 72 65 20 52 65 76 69 73 69 6F 6E 00 22:51:35.628 > ATT_ReadResp: status=0 h=0 n=1, 00 22:51:35.668 > ATT_ReadResp: status=0 h=0 n=1, 00 22:51:35.708 > ATT_ReadResp: status=0 h=0 n=7, 01 0D 00 00 00 10 01 22:51:35.748 > ATT_ReadResp: status=0 h=0 n=2, 00 00 22:51:35.788 > ATT_ReadResp: status=0 h=0 n=1, 64 22:51:35.828 > ATT_ReadResp: status=0 h=0 n=13, 54 49 20 42 4C 45 20 4B 65 79 66 6F 62 22:51:35.868 > ATT_ReadResp: status=0 h=0 n=1, 00 22:51:35.908 > ATT_ReadResp: status=0 h=0 n=8, 50 00 A0 00 00 00 E8 03 22:51:35.948 > ATT_ReadResp: status=0 h=0 n=18, 46 69 72 6D 77 61 72 65 20 52 65 76 69 73 69 6F 6E 00 22:51:35.988 > ATT_ReadResp: status=0 h=0 n=14, 53 65 72 69 61 6C 20 4E 75 6D 62 65 72 00 22:51:36.028 > ATT_ReadResp: status=0 h=0 n=13, 4D 6F 64 65 6C 20 4E 75 6D 62 65 72 00 22:51:36.068 > ATT_ReadResp: status=0 h=0 n=8, 8C 18 28 00 00 29 6A BC 22:51:36.108 > ATT_ReadResp: status=0 h=0 n=14, FE 00 65 78 70 65 72 69 6D 65 6E 74 61 6C 22:51:36.148 > ATT_ReadResp: status=0 h=0 n=18, 4D 61 6E 75 66 61 63 74 75 72 65 72 20 4E 61 6D 65 00 22:51:36.150 > Attribute read done 22:51:39.247 > GAP Link Param Update: 0 0 800 0 1000 22:51:40.858 > Attribute table saved 22:51:49.266 > GAP Link Terminated: status=0 h=0 reason=0x08 22:51:49.279 > Keyfobdemo disconnected
