Is it possible to load the software sensor tag to a pcb design made by myself to check proper operation? Thank you.
It is not precisely the sensor tag. It is only the minimum system with antenna without allthe sensors.
I don't see big problem if you don't change GPIO for button and LED. Even you change those, you can easily revise the source code of SensorTag to make it run on your own PCB.
