I'm working on a project of ECG with bluetooth low energy.....Q22FA1280009200 crystal (32 MHz) is not available here..can someone suggest a suitable replacement for it?
It would be much of a help if you mention the exact type of device (part number) you are trying to make the crystal matching to.
Practically most of the crystals with the same SPEC would be find, another thing to take into consideration are the physical
dimensions of the crystal which are sometimes important in order to maintain a PCB layout as close as possible to a
recommended manufacturer's reference design, if such design exists.
it is used in cc2541, used in ECG Bluetooth low energy...
www.ti.com/.../ecg_bluetooth_low_energy.shtml;tisearch=Search-EN-Everything
Every crystal within the spec from "32-MHz CRYSTAL OSCILLATOR" table (cc2541 Datasheet) is OK.
An example of filtered search on Farnell site
