I am new at this and am having lot's of problems getting the any demo's to compile.
What I am using are:
1) msp430F5529 experimenter board
2) Tiwi-ub2 board
3) IAR full demo version
4) The latest Bluetopia stack available at the site.
I load up the demo...pick one.....but the SPPLEDemo_Lite for this example and get the following:
Building configuration: SPPLEDemo_Lite - Debug - MSP430F5529 Exp
Updating build tree...
BTPSKRNL.c
BTPSVEND.c
BTVS.c
Warning[Pe186]: pointless comparison of unsigned integer with zero C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Bluetopia\btvs\BTVS.c 167
Warning[Pe186]: pointless comparison of unsigned integer with zero C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Bluetopia\btvs\BTVS.c 429
Warning[Pe186]: pointless comparison of unsigned integer with zero C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Bluetopia\btvs\BTVS.c 643
Warning[Pe186]: pointless comparison of unsigned integer with zero C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Bluetopia\btvs\BTVS.c 729
HAL.c
HCITRANS.c
low_level_init.c
Main.c
SPPLEDemo.c
Warning[Pe177]: variable "HCIVersionStrings" was declared but never referenced C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPLEDemo_Lite\SPPLEDemo.c 356
sprintf.c
Linking
Error[e46]: Undefined external "BSC_QueryStackIdle" referred in Main ( C:\ti\
MSP430_Experimentor\Samples\SPPLEDemo_Lite\Projects\IAR\Debug -
MSP430F5529 Exp\Obj\Main.r43 )
Error[e46]: Undefined external "HCI_Reconfigure_Driver" referred in Main ( C:\ti\
Error[e46]: Undefined external "BSC_AddGenericListEntry_Actual" referred in
SPPLEDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4
R1\MSP430_Experimentor\Samples\SPPLEDemo_Lite\Projects\IAR\Debug -
MSP430F5529 Exp\Obj\SPPLEDemo.r43 )
Error[e46]: Undefined external "BSC_SearchGenericListEntry" referred in
Error[e46]: Undefined external "BSC_DeleteGenericListEntry" referred in
Error[e46]: Undefined external "BSC_FreeGenericListEntryMemory" referred in
Error[e46]: Undefined external "BSC_FreeGenericListEntryList" referred in
Error[e46]: Undefined external "BSC_Initialize" referred in SPPLEDemo ( C:\ti\
Error[e46]: Undefined external "HCI_Version_Supported" referred in SPPLEDemo (
Error[e46]: Undefined external "GAP_Query_Local_BD_ADDR" referred in
Error[e46]: Undefined external "L2CA_Set_Link_Connection_Configuration"
referred in SPPLEDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia
SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPLEDemo_Lite\Projects\IAR\
Debug - MSP430F5529 Exp\Obj\SPPLEDemo.r43 )
Error[e46]: Undefined external "HCI_Command_Supported" referred in
Error[e46]: Undefined external "HCI_Write_Default_Link_Policy_Settings" referred
in SPPLEDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\
v1.4 R1\MSP430_Experimentor\Samples\SPPLEDemo_Lite\Projects\IAR\Debug -
Error[e46]: Undefined external "GAP_LE_Diversify_Function" referred in
Error[e46]: Undefined external "GATT_Initialize" referred in SPPLEDemo ( C:\ti\
Error[e46]: Undefined external "HCI_LE_Read_Buffer_Size" referred in
Error[e46]: Undefined external "GATT_Set_Queuing_Parameters" referred in
Error[e46]: Undefined external "GAPS_Initialize_Service" referred in SPPLEDemo (
Error[e46]: Undefined external "GAPS_Set_Device_Name" referred in
Error[e46]: Undefined external "GAPS_Set_Device_Appearance" referred in
Error[e46]: Undefined external "GAP_Set_Local_Device_Name" referred in
Error[e46]: Undefined external "GATT_Cleanup" referred in SPPLEDemo ( C:\ti\
Error[e46]: Undefined external "GAPS_Cleanup_Service" referred in SPPLEDemo
( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\
Error[e46]: Undefined external "GATT_Un_Register_Service" referred in
Error[e46]: Undefined external "BSC_Shutdown" referred in SPPLEDemo ( C:\ti\
Error[e46]: Undefined external "GAP_Set_Discoverability_Mode" referred in
Error[e46]: Undefined external "GAP_Set_Connectability_Mode" referred in
Error[e46]: Undefined external "GAP_Set_Pairability_Mode" referred in
Error[e46]: Undefined external "GAP_Register_Remote_Authentication" referred in
Error[e46]: Undefined external "GAP_LE_Set_Pairability_Mode" referred in
Error[e46]: Undefined external "GAP_LE_Register_Remote_Authentication"
Error[e46]: Undefined external "GATT_Handle_Value_Notification" referred in
Error[e46]: Undefined external "GAP_LE_Authentication_Response" referred in
Error[e46]: Undefined external "GAP_LE_Generate_Long_Term_Key" referred in
Error[e46]: Undefined external "HCI_Delete_Stored_Link_Key" referred in
Error[e46]: Undefined external "GAP_Authentication_Response" referred in
Error[e46]: Undefined external "SPP_Open_Server_Port" referred in SPPLEDemo (
Error[e46]: Undefined external "SPP_Register_Raw_SDP_Record" referred in
Error[e46]: Undefined external "SPP_Close_Server_Port" referred in SPPLEDemo
Error[e46]: Undefined external "GAP_LE_Set_Advertising_Data" referred in
Error[e46]: Undefined external "GAP_LE_Set_Scan_Response_Data" referred in
Error[e46]: Undefined external "GAP_LE_Advertising_Enable" referred in
Error[e46]: Undefined external "GATT_Register_Service" referred in SPPLEDemo
Error[e46]: Undefined external "GAP_LE_Regenerate_Long_Term_Key" referred
Error[e46]: Undefined external "GAP_LE_Disconnect" referred in SPPLEDemo ( C:\
Error[e46]: Undefined external "GATT_Read_Response" referred in SPPLEDemo
Error[e46]: Undefined external "GATT_Error_Response" referred in SPPLEDemo (
Error[e46]: Undefined external "GATT_Write_Response" referred in SPPLEDemo (
Error[e46]: Undefined external "SPP_Data_Read" referred in SPPLEDemo ( C:\ti\
Error[e46]: Undefined external "SPP_Data_Write" referred in SPPLEDemo ( C:\ti\
Error[e46]: Undefined external "SPP_Respond_Port_Information" referred in
Error while running Linker
Total number of errors: 51
Total number of warnings: 6
I get very similar errors and warnings for the other demos as well.
I have tried reinstalling the bluetopia software, I have manually added search paths to the linker and preprocessor without any success as well.
Any ideas on what needs to happen to get any one of the demos to compile? Any help would be greatly appreciated.
Thanks!
Phil
