Is is technically possible / feasible for a server to dynamically add services to its profile after a proprietary authenticated connection is made? I understand this is after service discovery, but the question still stands.
I do see any problem in adding a service at run time. But Mind that the remote device which is already connected will only know this service when it does SDP query again.
It also depends on the stack implementation, So moving it to SSO team for precise answer.
As mentioned earlier there is no problem doing this as long as you realize that the new service will not be known to the remote device until the remote does and SDP query.
