Hello
I am currently working on a project that uses the MSP430F5438A in combination with the CC2564B bluetooth chip. As a proof of concept we have worked with the BT-MSPAUDSINK board that did the job very nice.
Now we have designed our own board for the project using an MSP430F5438A. But now we are having a hard time to get the bluetopia code to run on our board. We always get the response of -4 which means that there is a problem with the communication. We have tried for several days and checked hardware over and over again. But the reply is always -4.
We are not sure if it is a hardware problem or a software problem.
We have used the pinout that was used in the example software like this:
/*****< HRDWCFG.h >************************************************************/ /* Copyright 2010 - 2014 Stonestreet One. */ /* All Rights Reserved. */ /* */ /* HRDWCFG - Hardware Configuration header for MSP430 5438 Experimentor */ /* Board. */ /* */ /* Author: Tim Cook */ /* */ /*** MODIFICATION HISTORY *****************************************************/ /* */ /* mm/dd/yy F. Lastname Description of Modification */ /* -------- ----------- ------------------------------------------------*/ /* 08/31/10 Tim Cook Initial creation. */ /******************************************************************************/ #ifndef _HRDWCFG_H_ #define _HRDWCFG_H_ #include <msp430.h> /* Compiler specific Chip header. */ #include "MSP430Utils.h" /* MSP430 defines and Processor Specific Utilities */ /* The following typedef represents all of the allowable clock speeds */ /* that may be specified in the BT_CPU_FREQ macro. */ typedef enum { cf8MHZ_t, cf16MHZ_t, cf20MHZ_t, cf25MHZ_t } Cpu_Frequency_t; /******************************************************************************/ /** The following defines control the UART module used for debug logs. **/ /******************************************************************************/ /* The DEBUG UART port base. Should be set to the address of the */ /* UCA1. */ #define BT_DEBUG_UART_BASE ((unsigned char *)&UCA1CTLW0) /* The DEBUG UART Port Interrupt Vector Number. Used when enable */ /* reception of data on the DEBUG UART port. */ #define BT_DEBUG_UART_IV (USCI_A1_VECTOR) /* The Bluetooth UART Interrupt Vector Register. */ #define BT_DEBUG_UART_IVR (UCA1IV) /* Maximum numbered of buffered characters on the DEBUG UART */ /* receiver. */ #define BT_DEBUG_UART_RX_BUFFER_SIZE 64 /* Maximum numbered of buffered characters on the DEBUG UART */ /* transmitter. */ /* * NOTE * If this value is 0 then this will generate to a Blocking */ /* Write. */ #define BT_DEBUG_UART_TX_BUFFER_SIZE (3*80) /* The DEBUG UART I/O Pin Base. Should be set to the address of the */ /* Input register of the I/O Port where the desired UART's Tx/Rx pins*/ /* are located. For UCA1 this is P5IN. */ #define BT_DEBUG_UART_PIN_BASE (&P5IN) /* The DEBUG UART's Tx Pin Mask. This should be set to BITx where x */ /* is the pin on the BT_DEBUG_UART_PIN_BASE port. For UCA1 Tx is on */ /* Pin 6 on the MSP430. */ #define BT_DEBUG_UART_PIN_TX_MASK (BIT6) /* The DEBUG UART's Rx Pin Mask. This should be set to BITx where x */ /* is the pin on the BT_DEBUG_UART_PIN_BASE port. For UCA1 Rx is on */ /* Pin 7 on the MSP430. */ #define BT_DEBUG_UART_PIN_RX_MASK (BIT7) /* The DEBUG UART Baudrate, must be in range supported by chip. */ #define BT_DEBUG_UART_BAUDRATE 9600L /******************************************************************************/ /** The following defines control the Bluetooth Slow Clock Line. **/ /******************************************************************************/ /* The following is the base address of the GPIO Port where the BT */ /* Slow Clock line is located. */ #define BT_SLOW_CLOCK_PORT_BASE ((unsigned char *)&P11IN) /* The following is the pin number on BT_SLOW_CLOCK_PORT_BASE which */ /* for which the controller's slow clock line is located. */ #define BT_SLOW_CLOCK_PORT_PIN (BIT0) /******************************************************************************/ /** The following defines control the Bluetooth HCI UART Reset Line. **/ /******************************************************************************/ /* The following is the base address of the GPIO Port where the BT */ /* controlller's reset line is located. (Default if Port 8) */ #define BT_DEVICE_RESET_PORT_BASE ((unsigned char *)&P8IN) /* The following is the pin number on BT_DEVICE_RESET_PORT which for */ /* which the controller's reset line is located. */ #define BT_DEVICE_RESET_PORT_PIN (BIT2) /******************************************************************************/ /** The following defines control the Bluetooth HCI UART RTS/CTS Lines. **/ /******************************************************************************/ /* The base address of the Processor Port on which the RTS Pin is */ /* located. (Default=0x200 is address of P1IN). */ #define BT_UART_FLOW_RTS_PIN_BASE ((unsigned char *)&P1IN) /* The base address of the Processor Port on which the CTS Pin is */ /* located. (Default=0x200 is address of P1IN). */ #define BT_UART_FLOW_CTS_PIN_BASE ((unsigned char *)&P1IN) /* The following is the interrupt vector offset of the RTS/CTS Port. */ #define BT_UART_CTS_IV (PORT1_VECTOR) /* The following is the UART RTS/CTS Interrupt Vector Register. */ #define BT_UART_CTS_IVR (P1IV) /* The Bluetooth RTS Output Port Pin Number. */ #define BT_UART_RTS_PIN (BIT4) /* The Bluetooth CTS Input Port Pin Number. */ #define BT_UART_CTS_PIN (BIT3) /* The Bluetooth CTS Interrupt Number. This should be in the form */ /* PXIV_PXIFGY where X is the Port Number (1 in this case) and Y is */ /* the Pin Number on the corresponding port (3 in this case). */ #define BT_UART_CTS_INT_NUM (P1IV_P1IFG3) /******************************************************************************/ /** The following group of defines control the UART module used to talk to **/ /** the Bluetooth Controller chip. **/ /******************************************************************************/ /* The Base Address of the used UART Module. On the MSP430x5xx */ /* family this is set to the address of the Module's Control Word 0 */ /* Register. (All other registers accessed are accessed based on */ /* their offset from this Address Base). */ #define BT_UART_MODULE_BASE ((unsigned char *)&UCA2CTLW0) /* The Bluetooth UART Interrupt Vector Offset. */ #define BT_UART_IV (USCI_A2_VECTOR) /* The Bluetooth UART Interrupt Vector Register. */ #define BT_UART_IVR (UCA2IV) /* The following is the Base Address of the UART Module's Tx/Rx pin's*/ /* Port base. This will be used to configure the Module's Tx/Rx to */ /* be used as peripheral pins. */ #define BT_UART_PIN_PORT_BASE ((unsigned char *)&P9IN) /* The UART Module's Tx Pin Mask. */ #define BT_UART_PIN_TX (BIT4) /* The UART Module's Rx Pin Mask. */ #define BT_UART_PIN_RX (BIT5) /******************************************************************************/ /** The following control the frequency of the processor. **/ /******************************************************************************/ /* The following define controls the speed that the system is */ /* configured to run at. */ #define BT_CPU_FREQ (cf25MHZ_t) /******************************************************************************/ /** The following define the Tick Rate for the Bluetopia NoOS Stack. **/ /******************************************************************************/ #define MSP430_TICK_RATE_HZ ((unsigned int)1000) #define MSP430_TICK_RATE_MS ((unsigned int)1000 / MSP430_TICK_RATE_HZ) /*************************NON CONFIGURABLE SECTION*****************************/ /*************************NON CONFIGURABLE SECTION*****************************/ /*************************NON CONFIGURABLE SECTION*****************************/ /** **/ /** The following sections consist of MACROs that exist to aid in **/ /** configuring the Bluetooth Chip that should never need to be changed **/ /** however for completeness they are included in this file. **/ /** **/ /*************************NON CONFIGURABLE SECTION*****************************/ /*************************NON CONFIGURABLE SECTION*****************************/ /*************************NON CONFIGURABLE SECTION*****************************/ /* The following MACRO is used to configure the Slow Clock Line. */ #define BT_CONFIG_SLOW_CLOCK() GPIOPinTypePeripheralOutput(BT_SLOW_CLOCK_PORT_BASE, BT_SLOW_CLOCK_PORT_PIN) /* The following macro is used to configure the Reset line. */ #define BT_CONFIG_RESET() GPIOPinTypeReset(BT_DEVICE_RESET_PORT_BASE, BT_DEVICE_RESET_PORT_PIN) /* The following is used to Reset the Bluetooth Controller. */ #define BT_DEVICE_RESET() HWREG8((BT_DEVICE_RESET_PORT_BASE) + MSP430F5438_GPIO_OUTPUT_OFFSET) &= (~(BT_DEVICE_RESET_PORT_PIN)) /* The following is used to bring the Bluetooth Controller out of */ /* reset. */ #define BT_DEVICE_UNRESET() HWREG8((BT_DEVICE_RESET_PORT_BASE) + MSP430F5438_GPIO_OUTPUT_OFFSET) |= (BT_DEVICE_RESET_PORT_PIN) /* The following macros are used to configure the RTS/CTS Flow */ /* Control Pins for Hardware Flow Control Emulation. */ #define BT_CONFIG_RTS_PIN() GPIOPinTypeRtsFlow(BT_UART_FLOW_RTS_PIN_BASE, BT_UART_RTS_PIN) #define BT_CONFIG_CTS_PIN() GPIOPinTypeCtsFlow(BT_UART_FLOW_CTS_PIN_BASE, BT_UART_CTS_PIN) /* The following is used to Disable Flow Control with RTS. */ #define BT_DISABLE_FLOW() HWREG8((BT_UART_FLOW_RTS_PIN_BASE) + MSP430F5438_GPIO_OUTPUT_OFFSET) |= (BT_UART_RTS_PIN) /* The following is used to Re-enable Flow Control with RTS. */ #define BT_ENABLE_FLOW() HWREG8((BT_UART_FLOW_RTS_PIN_BASE) + MSP430F5438_GPIO_OUTPUT_OFFSET) &= (~(BT_UART_RTS_PIN)) /* The following macro is used to make CTS Interrupt Negative Edge */ /* Active. */ #define BT_CTS_INT_NEG_EDGE() GPIOIntNegEdge((BT_UART_FLOW_CTS_PIN_BASE), (BT_UART_CTS_PIN)) /* The following Macro returns Non-Zero if CTS Interrupts are */ /* currently Negative Edge Active. */ #define BT_CTS_INT_IS_NEG_EDGE() GPIOIntEdgeIsNeg((BT_UART_FLOW_CTS_PIN_BASE), (BT_UART_CTS_PIN)) /* The following macro is used to make CTS Interrupt Positive Edge */ /* Active. */ #define BT_CTS_INT_POS_EDGE() GPIOIntPosEdge((BT_UART_FLOW_CTS_PIN_BASE), (BT_UART_CTS_PIN)) /* The following macro is used to read the CTS Pin. */ #define BT_CTS_READ() (GPIORead(BT_UART_FLOW_CTS_PIN_BASE) & (BT_UART_CTS_PIN)) /* The following macro is used to configure the UART Module's Pins */ /* for use by the module. (Rather than GPIO). */ #define BT_CONFIG_UART_PINS() GPIOPinTypeUART(BT_UART_PIN_PORT_BASE, BT_UART_PIN_TX,BT_UART_PIN_RX) #endif
Furthermore we have two pins to control the level shifter between the mcu and the CC2564B. Those are the 1V8 enable and Level_shift_enab lines. The hardware can be viewed in the next 2 links:
We would be very glad to get some insights of some more experienced people who have worked with the bluetopia stack before.
My sincerly.
