With CC2564B, is it possible to generate PCM output signal without A3DP connection of BT device?
“Purpose” – during production line, to check if BT(CC2564B) module is properly connected, and to check if the connector is OK or not.
For doing this, I tested PCM loopback mode. PCM loopback mode itself worked fine.
However, there is no signal output at PCM_OUT (I checked with a scope), because there is no signal input at PCM_IN.
So, if you have a good idea of checking PCM_OUT signal, without BT connection, please let me know.
Thanks and regards,
Hayden
