Hi Everyone,
While looking into core API document found a HCI command to read RSSI but while testing the A3DP profile didnt found a command to read the RSSI, can you please let us know how to read RSSI??
Santosh.
Hi Everyone,
Santosh.
Hi Suresh,
Thanks for your quick reply.
The link you provided is for HCI commands, can you please let me know which .c/.h file should refer to add or use the HCI commands in SPP profile??
Santosh.
Hi Joseph,
Thanks for your suggestion,
I tried calling the function as below and if I see the result the of read_rssi value, it is always 2
HCI_Send_Raw_Command(BluetoothStackID,0x3f, 0x01fc, 0,0,0,0,read_rssi,0);
Can you pease let me know if it is correct??
Also how can I know the RSSI of the particular Bluetooth device?? Does it gives the rssi of the nearest device by default?
BR,Santosh.
