I am curious if this is possible. I have data stored in an SD card, lets say its 100KB long (much larger than the NFC tags 3Kb SRAM). Is it possible, using a microcontroller, to continuously pull data from the SD card and write it to the tag while the reader is receiving it? I guess the idea is that this could be done without having to remove contact, re-write the tag message and then read again by tapping the tag again.
Thank you.
Erick
