I am using a TMS3705B as a receiver in a system that generates the field with a separate transmitter. i.e. the 3705 antenna drivers are not used or connected. The data stream from the tag is incorrect in this arrangement. If I use the built in driver transmitter then it works correctly. Is there a fix for this?
