TMS37145TEAIE/TMS37145TEAIEG differences are preprogrammed with either PWM or PPM communication formats,
PWM or PPM format will affect the reader reads the TMS37145TEAIE data?
Hey Huang,
We've pinged the German Apps team that supports this part, and they should get back to you soon.
I believe it's just a software setting. I'll see if I can find another E2E post with the code.
JD
Hey Huang,
I don't think I really understood the question, but yes, PWM or PPM timing selection does affect the read out. The LF- downlink does look different, so that you will not be able to read a PPM transponder with a PWM downlink and vice versa. There will be no response at all, because the respective transponder detects the downlink as invalid.
Hope that helps!
Best regards
Max
